27th January 2007, 13:27 | #41 | Link |
version 0.3 is out with the IME fix!!
http://www.sendspace.com/file/gsw5lc Backup the .evo files first then run "Reconstruct Menu". It will copy the .MAP files, fix the XPL file and then it will call Zotty's awesome aca decrypter to fix the .aca files. EDIT: if someone downloaded 0.3 earlier, please delete that and re-download it again. Just fixed some minor bugs. Last edited by Emon; 27th January 2007 at 17:22. |
27th January 2007, 22:17 | #46 | Link |
Still having problem with the new 0.3. I tried King Kong and although everything seems to go ok in the process, getting all kinds of bugs (Menu still not useable, go to chapter and player either closes, crashes or lose video). I don't think this is all the player.
27th January 2007, 23:03 | #48 | Link |
Ripped Serenity with the new 0.3 version. I can navigate the menu with the keyboard but there's no mouse functionality. Subtitles are on and even turning them off in menu doesn't work. I can change subs at will but can't shut them off. Not a big deal since I can just edit them out but might be huge for others. Navigation works great. I can skip to different titles and jump around in the movie just fine.
I'm going to try KK now. Edit: The app refuses to acknowledge that KK exists. When I hit backup it gives me syntax usage tips. Tried Riddick and it's ripping now. The KK disc looks clean, I can browse it in Windows, but the app just doesn't recognize it. Last edited by t00ld00d; 27th January 2007 at 23:13. Reason: Update |
27th January 2007, 23:14 | #49 | Link | |
thanx Emon, awesome work! |
28th January 2007, 01:46 | #50 | Link |
Riddick ripped fine. When I try to rebuild menus I get a series of errors eventually culminating in aca.exe crashing when scanning the ADV_OBJ directory. Apparently aca.exe sets the .map files to read-only so after failing once all the .map files have to be reset. Then it will fail because the .vti file already exists. Then fails on discid.dat. If I get rid of discid.dat it completely crashes.
28th January 2007, 01:50 | #51 | Link | |
28th January 2007, 02:26 | #52 | Link |
Excuse my ignorance, but can you use the aca decrypter part with hd dvds that have already been stored on a hard drive? Or do you have to start the process all over using the discs? The program keeps looking for an /aacs directory that doesn't exist in my backups???
28th January 2007, 03:30 | #53 | Link |
Old fart
For me it copies everything fine, but stops at the line:
Title Key File MAC:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Where X is the key file number. Mark Edit: The problem appears to be in aca_decrypter for me. If I use it in command line mode it crashes at the same spot that stops in backuphddvdgui.
Oh no Mr. Bill! Last edited by markrb; 28th January 2007 at 03:47. |
28th January 2007, 18:52 | #55 | Link |
Problem
I am trying to use this on Reds and Superman Richard Donner release and am having trouble with this release. I get
Backup HD-DVD V1.00 (C# Port) Starting Usage: BackupHDDVD SourceDrive DestinationDirectory Example: BackupHDDVD f: e:\movie\somemovie How do I fix this? |
28th January 2007, 18:57 | #56 | Link | |
28th January 2007, 18:58 | #57 | Link | |
28th January 2007, 19:17 | #58 | Link | |
28th January 2007, 19:25 | #60 | Link |
I think, trouble in command line arguments.
May be "Superman Richard Donner", "King Kong" perceived by programm as several params ("King" and "Kong"). You need to copy your data to HDD and delete all spaces in path, or replace them with "_". Last edited by Oleg_Jdev; 28th January 2007 at 19:27. |
