Old 1st September 2009, 16:06   #2261  |  Link
PeteP
Log files as requested. More to come ... just (finally) found the link to the preview version.
Last edited by PeteP; 1st September 2009 at 17:36. Reason: new logs with preview version
PeteP is offline
Old 2nd September 2009, 20:05   #2262  |  Link
stax76
stax76's Avatar
Thanks for the files, I have work on a couple of things and it will take some time.
stax76 is offline
Old 4th September 2009, 10:50   #2263  |  Link
avinash_chintu
avinash_chintu's Avatar
Thanx stax76, can please let me know the increase and decrease of brightness in staxrip
avinash_chintu is offline
Old 4th September 2009, 12:10   #2264  |  Link
stax76
stax76's Avatar
Hi, it's a bit difficult, I'll have to write a tutorial on how to use AviSynth filters in StaxRip, this tutorial will be be a thread in this forum.
stax76 is offline
Old 4th September 2009, 15:05   #2265  |  Link
flebber
Practising Schemer
Your answer is here http://avisynth.org/mediawiki/Tweak
flebber is offline
Old 4th September 2009, 16:52   #2266  |  Link
TBKHomeworld!
another instructional video...
So I read a lot of folks have audio syncing issues. I have found an extremely easy way to resolve this problem if you are converting directly from the source DVD. This solution works with any final codec choice as 99.9% of the time it is a problem with the source and NOT the resulting file.
Anyway, I have the video over on my site http://www.tbkhomeworld.com/staxrip/
Here is the direct link to the youtube video: http://www.youtube.com/watch?v=srjPDfxNsLo
Hope this helps a few folks who are stuck.
TBKHomeworld! is offline
Old 4th September 2009, 18:26   #2267  |  Link
stax76
stax76's Avatar
Thanks TBKHomeworld!, looks fantastic.
stax76 is offline
Old 5th September 2009, 17:17   #2268  |  Link
arrirc
Aminei
arrirc's Avatar
Set Credits
Adds parameters to command line based video encoders. (Parameters = --zones %pos_frame%,%eval:%source_frames%-1%,q=40)
Hello stax
Regarding encoding the title section in lower settings than the main movie, I found the above following your direction in one of the previous post. Now is it possible to change the command to customize the target bitrate for the title section or may be encoding it in greyscale?
Thanks again
arrirc is offline
Old 5th September 2009, 17:41   #2269  |  Link
stax76
stax76's Avatar
What is title section? 'Set Credits' can be customized using the menu editor.
stax76 is offline
Old 5th September 2009, 17:52   #2270  |  Link
MoboTech
Hey TBKHomeworld!, can you add video tutorial on how to add water mark? please! I can't figure it out.
MoboTech is offline
Old 6th September 2009, 05:30   #2271  |  Link
arrirc
Aminei
arrirc's Avatar
Sorry, I meant the "Credits Part" generally placed at the end of the movie
arrirc is offline
Old 6th September 2009, 05:40   #2272  |  Link
avinash_chintu
1.)Click on filters.
2.)U will get Add Filters in that u can find Misc.
3.)Click on it and then u can find child partation as Convert to YV12.
4.)Click on it to add.
5.)Replace the following code in convert to YV12
clip=last X=50 Y=20 logo=ImageSource("C:\Users\PC Name\Desktop\image.jpg") logomask=ImageSource("C:\Users\PC Name\Desktop\image_mask.jpg")  last=clip Overlay(logo, X, Y,mask=logomask, opacity=1.0)
and click ok
this is place where i located my water mark.In the same way u can give the destination of the image ur self, where it is located.
6.)opacity=1.0 u can choose ur own opacity from 1.0 to 0.1.
And click ok
thats alll...........
Old 6th September 2009, 17:50   #2273  |  Link
Dark Alchemist
I am looking for an alternative to Winnydows and stumbled upon this application. It looks like it has potential for my purposes but as soon as I installed it and went to convert a .mp4 I have to the IPod format it crashed. As soon as I select it as my source, and clicked okay to go back to the main program, it just crashes every single time.
I have 7zipped the folder it created. Maybe I am doing something wrong not being familiar with this application?
Dark Alchemist is offline
Old 6th September 2009, 20:48   #2274  |  Link
Ryo94
Hi Stax,
Just tried the new beta and really rocks, thanks a lot!
I only have 2 question:
1. If you change the output directory you have to add the extension to the file (ie, avi or mkv) is this a bug or it have a purpose?
2. There is any chance to add to the windows preview the ability to display frame n° and timestamp like in VD?
Ryo94 is offline
Old 6th September 2009, 21:30   #2275  |  Link
stax76
stax76's Avatar
@arrirc
Did find how to customize it using the menu editor?
@Dark Alchemist
Please use a hosting service or send it to frank_skare{}yahoo*de
You mean changing the target file path? In any case a extension is added. What operating system do you use?
You mean displaying VirtualDub progress within StaxRip? It can be done with some ugly hacking but since XviD is a old format I hardly add relating new features.
stax76 is offline
Old 6th September 2009, 21:52   #2276  |  Link
Ryo94
Thanks for reply Stax,
Yes, if I change the target path I have to add the extension of the file manually otherwise I'll get a warning message saying "the current assistant or warning cannot be skipped" and the target path is marked in orange, after add the extension to the file (avi, mkv...) I can continue without problems. I'm using Windows XP SP3.
Frame number and time while you navigate the video in the preview.
It will be useful to seek and select a particular fragment of a movie for test the output quality before encode the whole movie.
Something like this
Ryo94 is offline
Old 6th September 2009, 22:21   #2277  |  Link
stax76
stax76's Avatar
Works on Win 7, I'll try to fix it.
Maybe you or somebody else can post AviSynth code for it.
stax76 is offline
Old 6th September 2009, 23:38   #2278  |  Link
Dark Alchemist
@Dark Alchemist
Done -> http://www.mediafire.com/?sharekey=5...4e75f6e8ebb871
Old 7th September 2009, 01:38   #2279  |  Link
MoboTech
and click ok
And click ok
about the image mask
lets say i'm making a logo as my watermark, what color should the background be for the regular image and the mask image?
and does both need the logo on?
MoboTech is offline
Old 7th September 2009, 03:20   #2280  |  Link
arrirc
Aminei
arrirc's Avatar
@arrirc
Hello stax
As you said, I did find it in the Menu obtained by right clicking on the preview window. So if I mark the "credits section" with the in and out point marker, will it be encoded in a lower and different bit rate than the rest of the movie?
Thanks again.
arrirc is offline
gui, h.264, h.265, hevc, mkv, x264, x265
