15th March 2009, 15:35 | #8541 | Link |
Kid for Today
depending on the sountrack being 1.5mbit DTS core or FLAC(from DTSHD in eac3to), the sound levels are much different ?!
I can hardly hear dialogs in DTSHD FLAC and need to increase the center channel to like 140% I've got all DRC disabled in AC3Filter and it's the same story w/ ffdshow/sonic 4.2 for DTS core, so what gives ?! it happens in all the DTSHD>FLAC tracks I've built, and forcing dialog normalization in ea3to doesn't do anything(same CRC whether it's enabled or not) OTOH transcoding LPCM in FLAC gives proper sound levels, identical to DTS core if anyone's got a clue, I'd love to hear it. thanks! |
15th March 2009, 18:40 | #8542 | Link |
I am not sure since what version the following problem is (I had V3.12 and just tried V3.14), but eac3to can not read m2ts files anymore. So when I point to the root of the ripped BD, I get the report as usual. But when I add the title index, eac3to reports there is an error reading xxxxx.m2ts. I am using CrossOver on Mac OS-X 10.5. For the record, this has always worked perfectly fine with older versions. CrossOver has not been updated in the meantime.
16th March 2009, 00:02 | #8545 | Link |
Madshi, not sure if this is a bug report or a feature request but anyway...
If I feed eac3to a duff audio file it reports "The format of the source file could not be detected." but the return code is 0. Could it be changed to non-zero please? It seems to be rc 1 for other source file errors. Thanks. |
16th March 2009, 03:45 | #8547 | Link |
eac3to can't see Nero 7 or Arcsoft TMT
I have Nero 7 installed and just picked up a copy of Arcsoft TMT a friend had and didn't want, primarily to play HD-DVD's since my included PDVD7 with my LG BD/HD-DVD drive only plays BD.
Anyway eac3to can't see either giving the following error messages Nero Audio Decoder (Nero 7) is not working correctly http://www.nero.com/eng/store-blu-ray.html CAUTION: You need Nero 7. Nero 8 won't work with eac3to. ArcSoft DTS Decoder doesn't seem to be installed http://www.arcsoft.com/products/totalmediatheatre According to what I have read the DTS decoder is via the filter ASAudioHD.ax which according to this DS filter chain, is installed Also I know Nero 7 is installed since I use it regularly. This is on Vista Home Premium 32 Anything else I should be looking out for? Thanks [edit] OK some progress. Looks like a path or environment variable issue. Copied all the DLL's from Arcsoft's directory to the eac3to directory and now the Arcsoft DTS decoder works fine. Still no joy with Nero though Out of interest what DS filter is eac3to looking for when it checks for Nero? Thanks [EDIT again!] Have gone through this thread again and it seems you need not only Nero 7 but the nero HD-DVD plugin. That's no longer been sold so I guess I am stuck with using libav which seems to be fine Last edited by lchiu7; 16th March 2009 at 11:35. |
16th March 2009, 12:19 | #8549 | Link | |
Also you can use an .avs (AviSynth script) and BeHappy to convert directly to flac without the intermediate multichannel wav file.
16th March 2009, 21:27 | #8550 | Link | |
http://forum.slysoft.com/showthread.php?t=25818&page=56 |
16th March 2009, 21:42 | #8551 | Link |
Having an issue with a specific movie - The Game Plan. The video appears to rip just fine but the audio track is a mess I have gone after the DTS and the AC3 5.1 tracks to no avail. When I rip it I get normal fine audio and then a few minutes into the track it loops back to the beginning! If I FFWD a bit I get normal dialog again - then a few mins later it loops back to the starting music again. After about the 3rd time I gave up I have now ripped it 3 times trying various things to include two copies of the movie to no avail. Has anyone else done this one and what issues if any did you encounter? I am on 3.14 and haven't ever seen this before. Ideas or suggestions?
Here's my log -> http://pastebin.com/m2d93e154 |
16th March 2009, 23:26 | #8552 | Link | |
eac3to v3.14 command line: "D:\Vtemp\programs\eac3to\eac3to.exe" "test.pcm" "E:\Vtemp\test1.wav" -6 -24 -little -96000 -override -log=1.txt ------------------------------------------------------------------------------ RAW/PCM, 5.1 channels, 1:38:26, 24 bits, 13824kbps, 96khz Reading RAW/PCM... Writing WAV... Creating file "E:\Vtemp\test1.wav"... The original audio track has a constant bit depth of 24 bits. Caution: The WAV file is bigger than 4GB. <WARNING> Some WAV readers might not be able to handle this file correctly. <WARNING> eac3to processing took 9 minutes, 41 seconds. Done. Code:
eac3to v3.14 command line: "D:\Vtemp\programs\eac3to\eac3to.exe" "E:\Vtemp\test1.wav" -log=t1.txt ------------------------------------------------------------------------------ The format of the source file could not be detected. <ERROR> I've created two test files (the original is 10GB) containing the first 15MB of the wav file. I've edited the first six samples of test2.wav and it can be processed. I've left test3.wav as is and it can't be detected. The lengths in the header remain as they are from the original file. I found that if I change the lengths in the RIFF and data chunks in test3.wav to zero then eac3to will detect it. However this doesn't work with the full sized original. Thank you! |
17th March 2009, 09:41 | #8555 | Link |
Eac3to recognize (and can decode with Nero, without plugins) .aac files. Is AAC format with ADTS headers.
Can't recognize AAC inside mp4 container (.mp4 or .m4a). The use of the faad decoder (aac/m4a, inside libav) or NeroAacDec is in the todo list of madshi like he say. Edit: By the moment you can use the Faad decoder included in UsEac3to
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 17th March 2009 at 09:47. |
17th March 2009, 13:51 | #8556 | Link |
21 years and counting...
I have Nero7 on my system to use the e-ac3 decoder. I want to get rid of Nero, because I use other tools for burning stuff and Nero just occupies to much space and resources.
How can I get rid of Nero but keep the e-ac3 decoder and/or the necessary libraries/files? Is that possible? Last edited by LeXXuz; 17th March 2009 at 14:51. |
17th March 2009, 14:39 | #8557 | Link |
Aging Video Hobbyist
Easiest just to de- and re-install with only Showtime, taking care to skip the Scout & other unneeded junk, though I think there remains an indexing service you still have to Disable by hand.
17th March 2009, 19:38 | #8558 | Link |
I hadn't even noticed that the files it was making were .m4a.
Thanks for the continued support tebasuna51. Edit: I just noticed that eac3to displays a 2.0 channel AAC track in mkv as being 24KHz when its really 48KHz. Last edited by Snowknight26; 17th March 2009 at 23:35. |
18th March 2009, 01:21 | #8560 | Link |
Then is a AAC-HE (with Spectral Band Replication) the high frequencies (24-48KHz) are in the SBR part, not always recognized. With the appropriate decoder you can recover the 48 KHz.
eac3to |
