Old 20th August 2010, 15:59   #2421  |  Link
krosswindz
Out of curiosity does any one have a Parallels Workstation Extreme and can try DGNV tools in the parallels VM. AFAIK Parallels Workstation Extreme should be able to see Nvidia GPU and should support CUDA as well. I dont have a copy of it, it would be interesting to see if some one could try to use DGNV tools in it.
krosswindz is offline   Reply With Quote
Old 20th August 2010, 22:34   #2422  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Originally Posted by Sharktooth View Post
that's it. you can use RD while frameserving but you cant start frameserving within a remote desktop session.
Makes sense. I will use a VNC session for starting frameserving jobs. Thanks Sharktooth.
I have another problem with DAR of source files. I don't know if it is a problem of DGDecNV or Megui. But since it never occured with DGindex, FFMSindex nor DGAVCdec I guess it might be a problem with DGDecNV.
I'm transcoding a couple of older mpeg2 DVB captures and it seems that Megui does not recognize the correct DAR when DGdecNV is used. F.e. a source mpeg2 file (just the video stream as mpv, no program stream) PAL 720x576, correct DAR is ITU 4:3 (1:1.367521) for this file, but when serving it with DGdecNV instead of DGindex the DAR is simply set to 1,25 (720/576).
Also opening the .dgi file in Meguis Avisynth script creator takes VERY long with mpeg2 source files. Looking at hdd activity it seems that the whole source file is scanned somehow before the preview window is shown and the script generator can be used.
If this is a megui issue, I apologize and will post it in the megui-thread.
LeXXuz is offline   Reply With Quote
Old 20th August 2010, 22:45   #2423  |  Link
Originally Posted by LeXXuz View Post
I have another problem with PAR of source files. I don't know if it is a problem of DGDecNV or Megui. But since it never occured with DGindex, FFMSindex nor DGAVCdec I guess it might be a problem with DGDecNV.
Can you please post a link to a sample that does this?
Does it open quickly in bare DGIndexNV?
Old 20th August 2010, 23:53   #2424  |  Link
LeXXuz
LeXXuz's Avatar
Here it is.
Sequence header look fine to me, DGIndexNV also seems to get correct ar:
MeGui's Avisynth script creator shows DAR 1:1,2222 (704/576) with DGIndexNV and ITU 4:3 PAL with DGIndex as it should.
When I drag&drop the .dgi file to DGIndexNV the related .m2v loads almost instantly. So yes.
Old 21st August 2010, 09:05   #2425  |  Link
Sharc
Here it is.
MeGui's Avisynth script creator shows 1:1,2222 (704/576) with DGIndexNV and ITU 4:3 PAL with DGIndex as it should.
PAR of your 704x576 picture is 12:11 (1.0909) as one can estimate from the circle distortion of the ARD logo. DAR (display aspect ratio) is 4:3. So when you playback the file at 4:3 it will be resized correctly (undistorted). So everything is fine I would say.
Old 21st August 2010, 10:01   #2426  |  Link
LeXXuz
LeXXuz's Avatar
I think it's not. MeGUI sets the wrong SAR to x264. The aspect ratio of the output is slightly too small and the picture looks slightly narrowed in width. With DGIndex everything is fine.
EDIT: It is the DAR Megui is having trouble with. Sorry for any confusion.
Just opened a 16:9 anamorphic encode and MeGUI sets DAR to 1,25 instead of ITU 16:9 PAL. As a result, x264 encoder is fed with SAR setting of 5:4 instead of 31:17 as it should.
Old 21st August 2010, 11:05   #2427  |  Link
Sharc
Your sample is mpeg2, not AVC. The PAR is not explicitely signalled in the stream. So you might have to add --sar 12:11 in the x264 CLI when you re-encode it with x264.
Nevertheless your sample should display undistorted (here it does) when you play it back at forced 4:3, e.g. with VLC.
When I play it back with DGindex the ARD logo looks slightly squeezed (narrowed) as expected for a 12:11 or 128:117 PAR (ITU).
Possibly your playback device assumes a par of 16:15 (generic PAR for PAL 4:3), means it will stretch your picture by 6.7% rather than about 9%. Hence a slight (but almost unnoticeable) distortion may persist.
Just a note: In case you intend to author the clip to blu-ray format at some later stage you would have to add 8 pixels black borders to the right and left each, such that the picture width becomes 720.
Old 21st August 2010, 11:35   #2428  |  Link
LeXXuz
LeXXuz's Avatar
But DAR should. The question is why does MeGUI set the correct DAR with DGIndex (I guess it gets this information from the sequence headers of the mpeg stream) while it simply sets hight/width as DAR when using DGIndexNV, which is not correct.
In short, I think MeGui should get the same results (and for some reason it does not), no matter what indexing method is used, no?
Old 21st August 2010, 11:40   #2429  |  Link
Sharc
I can't comment on MeGui as I am not very familiar with it.
Maybe someone else .....
Old 21st August 2010, 11:49   #2430  |  Link
stax76
stax76's Avatar
This is clearly a MeGUI and not a DGDecNV problem. Detecting the correct PAR for every possible source and source filter is very difficult, remember there are countless possible source formats and numerous possible source filters. I've changed and tweaked my detection probably more then 100 times in the last 8 years.
Old 21st August 2010, 11:51   #2431  |  Link
I could pass hints if it's thought to be a significant enough issue.
Old 21st August 2010, 12:11   #2432  |  Link
Groucho2004
I just looked at megui's source code - it reads the d2v file that DGIndex creates and gets the value from the entry "Aspect_Ratio".
DGI files (from DGDecNV) do not provide this property.
Old 21st August 2010, 12:17   #2433  |  Link
Originally Posted by hydra3333 View Post
Sure.
Please remove the SetMTMode() and report results.
Old 21st August 2010, 12:17   #2434  |  Link
stax76
stax76's Avatar
@Groucho2004
That's not robust anyway because 16:9 is sometimes defined in IFO only but not in VOB.
            If Filepath.GetExt(p.SourceFile) = ".d2v" Then
                Dim content = File.ReadAllText(p.SourceFile)
                If content.Contains("Aspect_Ratio=16:9") Then
                    p.SourceAnamorphic = True
                Else
                    Dim ifoFile = GetIfoFile()
                    If File.Exists(ifoFile) Then
                        Dim dar2 = MediaInfo.GetVideo(ifoFile, "DisplayAspectRatio")
                        If dar2 = "1.778" Then
                        End If
                    End If
                End If
Old 21st August 2010, 12:22   #2435  |  Link
Groucho2004
Originally Posted by stax76 View Post
@Groucho2004
I know, I just answered a question.
Old 21st August 2010, 12:30   #2436  |  Link
Groucho2004
Actually, that would be a nice feature.
Old 21st August 2010, 12:39   #2437  |  Link
Thinking more about it...
Hints are needed only for things that can change on a per-frame basis. I should just add the aspect ratio information to the DGI file.
Old 21st August 2010, 13:21   #2438  |  Link
hydra3333
Commented it out like this
#SetMTmode(mode=5,threads=1) # start with mode=5 forAVIsource http://forum.doom9.org/showthread.php?p=1067216#post1067216
and it works fine now.
I'd thought mode=5 was supposed to be the most "compatible" however leaving it off seems to be even more so Hurrah !
Out of interest, is that the end solution or a workaround ?
Old 21st August 2010, 14:52   #2439  |  Link
You can't multithread the NV-based DGSource(). I don't know for sure the technical reason or if there would be some way to allow it. I believe that the CUDA context must be associated with a single thread. Whether floating contexts changes anything I simply don't know at this time and haven't had time to look into it. So for now, just don't multithread DGSource.
It's probably a bad idea in general to multithread any source filter.
Old 22nd August 2010, 01:47   #2440  |  Link
hydra3333
ok yes, someone recommended mode=5 for source filters however looks like not this one.
if multi-threading is "out" when using NV then multi-core boxes like my 4-core effectively become single-core boxes inside avisynth... hence it must be swings and roundabouts for overall speed.
in this specific case there is no problem, since not much is being done and x264 multi-threads anyway - however if there's a lot of processing to be done inside avisynth then NV's single-threading requirement may end being a "chokepoint" for overall performance.
unless there's a way around it I don't know of (i'd thought to use MT, the 1st line of a script had to contain a setMTmode).
oh well, at least we know. thanks.
