Old 23rd January 2014, 00:52   #21561  |  Link
truexfan81
truexfan81's Avatar
yeah so people with weird sized videos, your downscale setting will be more important as it will actually get used
truexfan81 is offline   Reply With Quote
Old 23rd January 2014, 01:24   #21562  |  Link
Stereodude
1080p (catmull-rom)
Why would you prefer catmull-rom over some of the other downscaling options?
Stereodude is offline   Reply With Quote
Old 23rd January 2014, 02:37   #21563  |  Link
kasper93
MPC-HC Developer
Because it's the best. Just read the thread, everything has been said already.
kasper93 is offline   Reply With Quote
Old 23rd January 2014, 02:42   #21564  |  Link
Stereodude
That's not what I've read elsewhere. And with 21k posts it's not a very realistic option to read the whole thread.
Old 23rd January 2014, 04:00   #21565  |  Link
kasper93
MPC-HC Developer
So to make it clear. You want me to search the thread for you because you're too lazy, or what? Just search for "Catmull-Rom" and you will get all related posts. CR with AR and Linear Light enabled produce the most accurate and natural looking picture. I tested it a lot myself and I like CR best. Here is comparison to Lanczos done by @6233638 http://forum.doom9.org/showpost.php?p=1606829&postcount=16482
And remember that there is no best option, some people like sharp image with aliasing, some like softer image but without artifacts. You need to compare results yourself, it's not that hard.
Old 23rd January 2014, 04:01   #21566  |  Link
drew_afx
speaking of upscaling by powers of 2..
Has anyone cared about upscaling 1080p video(or film) to UHD (2160p) and downscaling back to monitor resolution (1080p)?
Visual difference I found were CGs (pixelated fonts etc) blending
in with rest of the picture although seeming a bit blurry (probably
due to outlines being blended with adjacent pixels).
More importantly, digital noises seemed less intrusive to my eyes.
drew_afx is offline   Reply With Quote
Old 23rd January 2014, 04:01   #21567  |  Link
mandarinka
mandarinka's Avatar
However, it might be possible for them to use nnedi3 to scale 2x (which should be faster) and then use another algorithm to scale the resulting image to your display resolution, while still benefiting from some of nnedi3's quality improvements.
Nnedi3 can only do 2x enlargement - it isn't a scaler, but interpolator (hence why it is used for deinterlacing and anti-aliasing). All it can do is interpolate an image into a double-height version. If you stack that two times (once for reach dimension), you will get a 2x upscaled image.
So to do general rescaling with it, you need to combine it with a conventional resampler that will change the resolution to desired values.
For example, if you have 640x360 source, nnedi3 can only give you these sizes: 640x720, 1280x360, 1280x720, 2560x720, 1280x1440, 2560x1440 ...
Also since nnedi3 is a (complex) interpolator, not a scaler, it can lead to various sorts of artifacts, since basically, the filter is "guessing" what is in the extra pixels. It can make mistakes, like blurring/connecting adjacent sharp lines for example.
mandarinka is offline   Reply With Quote
Old 23rd January 2014, 07:28   #21568  |  Link
leeperry
Kid for Today
Originally Posted by truexfan81 View Post
nnedi3 only upscales by powers of 2 (ie, 2x, 4x, 8x...).
so if I wanna upscale a 4:3 360*288 video to 1080p, I want it to be 1440*1080 in the end so ideally I would like to go 4X360 + 2X288? Apparently mVR will only do 2X
The Avisynth ppl call it SuperSampling, it's like processing audio in 48int/64fp and then dithering back to 24int.
Old 23rd January 2014, 08:34   #21569  |  Link
do you really think that matter with a 288 p. 2x is all what is needed for most video
huhn is online now   Reply With Quote
Old 23rd January 2014, 09:47   #21570  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
This is the one and only reason you should ever do this. (Similarly, watching cheaply made aliased junk like YuGiOh.) Anti-aliasing is one of the primary purposes of EDI, but it's much faster to use regular denoising shaders or filters if you don't have extreme aliasing. At that resolution, anti-aliasing would probably not be realtime, anyway; you'd have to re-encode, and you could manually do just the subtitles.
With any luck XySubFilter will eventually do anti-aliasing for VobSub and PGS, so there's no need to do it on the full screen. I feel your pain!
Garbage in, garbage out. It'll look different, but it'll never look good. Just stick with one iteration+jinc.
(If you have a cartoony palette with lots of aliasing though, hq4x or double nnedi might be useful. But rarely for natural video.)
Old 23rd January 2014, 09:49   #21571  |  Link
Qaq
AV heretic
How about Nnedi de-interlacing? I suppose Nnedi can provide better results than motion/vector adaptive?
Qaq is offline   Reply With Quote
Old 23rd January 2014, 09:54   #21572  |  Link
but field matching is way better and 60fps bob with nnedi is pretty unrealistic
Old 23rd January 2014, 10:02   #21573  |  Link
madshi
For video mode deinterlacing madVR will continue to rely on DXVA for the near future. At some point (not soon) I'm going to look into the whole deinterlacing topic again. But for now no changes in that area. FWIW, motion adaptive video mode deinterlacing (= weaving for static image areas) and something like nnedi3 are not mutually exclusive.
Old 23rd January 2014, 11:34   #21574  |  Link
James Freeman
How will an HD picture look upscaled to 2560x1440?
Any sharpness loss?
Anyone directly compared between the two (side by side)?
James Freeman is offline   Reply With Quote
Old 23rd January 2014, 11:58   #21575  |  Link
Any sharpness loss?
just try it out with the avisynth script
Old 23rd January 2014, 15:13   #21576  |  Link
LigH
LigH's Avatar
Any sharpness loss?
Before asking questions about "sharpness" again, understand what it means.
I am not a big fan of the Gibbs phenomenon caused by bicubic, Lanczos, or similar "sharp" interpolations.
New German Gleitz board
Old 23rd January 2014, 15:18   #21577  |  Link
sheppaul
DxVA2 Scaler seems not working in full screen mode with 1080p videoes.
Demo mode (it can be enabled in CCC) does not work in full screen.
sheppaul is offline   Reply With Quote
Old 23rd January 2014, 15:26   #21578  |  Link
James Freeman
Again? Isn't it the reason why this thread exists?
Yes, I have read about ringing artifacts and Gibbs phenomenon (I also see them).
I merely want to know from first hand experience how does it look watching 1080p content on a 1440p monitor, and how well MadVR's upscalers doing their job.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410.
Old 23rd January 2014, 15:47   #21579  |  Link
madshi
"How does it look" compared to what? Your real question is probably this:
Is it better to watch 1080p content on a 30" 1080p display? Or is it better to watch 1080p content on a 30" 1440p display, using madVR upscaling?
If this is your question, then I can't answer it because I have no way to test that. The only way you could fairly test this is if you had two 30" display, one with 1080p physical resolution and one with 1440p physical resolution, so you could play the same movie on both and compare directly. Without such a direct comparison, I find it hard to say whether upscaling is beneficial or not. That said, it depends on the upscaling factor. The bigger the scaling factor, the higher the chances upscaling can be beneficial. With scaling factors south of 1.2x I would guess that upscaling is not beneficial, maybe even harmful. However, if you approach a 2.0x factor, upscaling is going to look *a lot* better. So playing back 1080p content on a 4K display should look noticeably better than playing back 1080p content on a 1080p display of the same size. But this is only true if you sit close enough to see the difference. If you sit far enough away, the difference will vanish into thin air...
Old 23rd January 2014, 15:48   #21580  |  Link
madshi
Which GPU? Which OS? Can anybody reproduce this problem?
(Don't care about demo mode.)
