30th March 2009, 16:03 | #141 | Link |
bluray output is meant for when you burn this stuff to an actual recordable bluray disc. I'm not sure if its in this thread or not, but panasonic's bd-35 and a few other players from both panasonic and other companies will only play this content on a recordable dvd if its output in a specific way that makes the player think its an avchd disc. You could see what I mean if you download the clipinf editor tool from the same guy that does the clown bd program. You can actually use that tool to change at least one part of tsMuxer's output that identifies it as an avchd and change it to bluray or vice-versa. I wouldn't suggest you change it though if you want it to work, just a tool that you could use to see what I mean.
30th March 2009, 17:45 | #142 | Link | |
30th March 2009, 19:04 | #143 | Link |
Duh!
In previous versions of tsmuxer, the "Blu Ray output" was actually an AVCHD/BD output.
Now, tsmuxer is capable of producing 2 outputs: - "Blu Ray": 100% BD compliant, ment to be burnt on BD media (very few SAP will read the output on DVD media) - "AVCHD": the usual AVCHD/BD stuff |
30th March 2009, 19:09 | #144 | Link | |
Duh!
Just wanted to let you know that I tried this and it works like a charm. Thanks pal. |
1st April 2009, 01:50 | #147 | Link | |
What is BD-V? (Sorry if that's a stupid question...sounds to me like BD-Video...but I still don't know what the firmware fixes/enhances.) |
1st April 2009, 09:30 | #148 | Link |
Programmer (or just 教务长)
I can see that panasonic uses this way of saying that they addressed some problems with some commercial BD discs.
Previous updates are similar (for BD30): Improvements 1. AVCHD and BD-V Playability 1. BD-V Playability 1. Playability and Stability 1. BD-V(24p) Playability 1. BD-V(PiP) Playability 2. HDMI Compatibility 3. Audio output level (Low Frequency Effect) improvement 1. BD-V Playability 2. DVD-RW Playability 1. Playability and Stability |
10th August 2009, 02:31 | #149 | Link |
I just tried to play a AVCHD that was authored using tsMuxeR 1.10.6. The 1280x720 h.264 stream was encoded using x264 --preset slower. I specified --level 4.1 which made the stream have ref=8. According to the profile this is an acceptable ref frame number. Has anyone has any problems playing 1280x720 with 8 ref frames? As far as I can tell that was the only difference in the encodes. The one with 5 ref frames works fine. Thanks.
10th August 2009, 10:17 | #150 | Link | |
Try to encode it with --trellis 0, --bframes 4 and may be it is a good idea to explicitly set --keyint to 24 (or 25... depends on your source).
This works just fine in Playstation3 (1280x720@23,976fps) Quote:
10th August 2009, 13:42 | #151 | Link |
This is the encoder settings for the video that will not play on my Panasonic BD-35:
cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.2 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=24 / keyint_min=1 / scenecut=40 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=3698 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=24000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 |
10th August 2009, 14:17 | #153 | Link |
Here is the .bat file that I used to encode.
In case you don't want the .bat file here is the pasted 1st and 2nd pass: Code:
"%x264_PATH%" --preset slower --tune film --pass 1 --bitrate %VIDBITRATE% --stats "%SOURCE_FOLDER%\%SOURCE_FILENAME%.stats" --level 4.1 --keyint 24 --min-keyint 1 --vbv-bufsize 30000 --vbv-maxrate 24000 --no-fast-pskip --nal-hrd --output NUL "%INPUT_VIDEO%" 2> "%SOURCE_FOLDER%\%SOURCE_FILENAME%-1pass.txt" "%x264_PATH%" --preset slower --tune film --pass 2 --bitrate %VIDBITRATE% --stats "%SOURCE_FOLDER%\%SOURCE_FILENAME%.stats" --level 4.1 --keyint 24 --min-keyint 1 --vbv-bufsize 30000 --vbv-maxrate 24000 --no-fast-pskip --sar 1:1 --aud --nal-hrd --output "%SOURCE_FOLDER%\%SOURCE_FILENAME%-output.h264" "%INPUT_VIDEO%" 2> "%SOURCE_FOLDER%\%SOURCE_FILENAME%-2pass.txt" Last edited by rack04; 10th August 2009 at 14:22. |
10th August 2009, 14:49 | #154 | Link |
Encode is running now... I'll let you know in few minutes if it plays in my Playstation 3 (nothing else to test with )
Dean Code:
Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Bit rate : 4 000 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.181 Writing library : x264 core 69 r1198 a1ed468 Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0 x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.2 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offse t=-3 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_ada pt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=24 / keyint_min=1 / scenecut=40 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=2400 0 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 I used the raw 264, added audio and authored with multiAVCHD. Last edited by deank; 10th August 2009 at 14:59. |
10th August 2009, 14:58 | #155 | Link |
The reason that I think that it is the number of ref frames causing the problem is because using --preset slow works and --preset slower doesn't.
The only difference that I can see between these presets that may cause a problem is the number of ref frames. Using --preset slower and --level 4.1 the number of reference frames for 1280x720 is decreased to 8. Using --preset slow and --level 4.1 the number of reference frames for 1280x720 is held at 5. Unless mbtree has something to do with standalone playback. The one I encoded that works used an older version of x264 and the one that doesn't uses the newest version with mbtree. |
10th August 2009, 15:05 | #156 | Link |
To rull out if ref is affecting your player you can try the same preset that you used but decrease ref to 7, then to 6 and finally to 5 and test each result - then you will know for sure
10th August 2009, 17:00 | #157 | Link | |
I have attached the ISO that I created for the ref frame test. If anyone has access to a Panasonic BD30 please burn the ISO to DVD+RW and test with your player. Thanks. http://www.megaupload.com/?d=N0E5FD6H Disclaimer: The ISO I have attached is of the open source film "Big Buck Bunny". Last edited by rack04; 10th August 2009 at 17:10. |
10th August 2009, 22:56 | #159 | Link | |
davidcw |
