4th April 2004, 10:47 | #21 | Link | |
And I saw on one PC that I'm not able to export to text (start CQME, open a matrix file, export, select "Text (CSV)"... no dialog appears, although it should "onClick"). Very strange. But the only W2K Domain Controller with user login I tested so far. |
4th April 2004, 12:45 | #22 | Link | |
Squeeze it!
(In case if you refer to that issue). I just PNed you about the Alternate (F2) Diagram and how it interprets the manual settet values .... |
4th April 2004, 13:49 | #23 | Link |
Oh, I shall know my own program... I thought the export file dialog appears when I click onto the radiobox, but it appears when I click on the OK button. So I will have to check the logic, if I shall enable the OK button when I click on the radiobox and the matrix name is not empty...
And yes, indeed, also the scan order is read transposed, stupid me. |
4th April 2004, 20:23 | #24 | Link | |
btw, really nice tool. |
5th April 2004, 07:09 | #25 | Link |
Good program, it's very helpful.
I may have a bug though - it seems that the diagrams for the scanning process don't math the scanning order. The image goes like this 1 2 6 3 5 4 etc. While the program seems to create the "scan order" bars by reading like this: 1 3 4 2 5 6
Stuff was here at some point. |
5th April 2004, 13:15 | #26 | Link |
That is just the effect what "transposed" means: x <=> y, mirrored at the main diagonal...
__ http://www.ligh.de/software/CQME_1.0a.zip contains most fixes, and the enhanced documentation. |
5th April 2004, 13:23 | #27 | Link |
Yes, but you talked about that in relation to exporting / importing something.
When I hit F2 and get the scan graph, it looks like the values have been scanned incorrectly. Am I right, or are they supposed to be scanned transposed?
5th April 2004, 13:28 | #28 | Link |
Squeeze it!
@SoonUdie
Yep, thats exactly the point I mailed to LigH via PN yesterday, .... and what he explained above by "transposed" x <=> y. This should be fixed now if I understand LigH right. LigH ...., did you also fixed the export to TmpgEnc.ini as there the ordering seemed to be "transposed" but not when doing just exporting to text file. |
5th April 2004, 14:22 | #31 | Link |
ligh, did you try to set nerodigital matrices?
5th April 2004, 14:24 | #32 | Link |
Fixed:
Nero Digital is too complicated currently: I would have to copy a whole preset branch inside an XML file, just to create new matrices. |
8th April 2004, 20:01 | #33 | Link | |
8th April 2004, 23:07 | #34 | Link | ||
Opensource will not take over the world. But it will sure improve the lives of most of it! _______________________________________________ Inkscape - Scallable Vector Graphics for everyone. The GIMP - Free raster graphics and photo editing software. Planeshift - Free 3D MMORPG. Cause everyone needs some fun. |
13th April 2004, 00:38 | #36 | Link |
Ligh:
Service Temporarily Unavailable The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later. Apache/1.3.27 Server at www.ligh.de Port 80
Anata wa baka da! REPENT! |
13th April 2004, 02:42 | #37 | Link | ||
13th April 2004, 13:34 | #38 | Link |
"Service Temporarily Unavailable":
I don't have manual access to my lend server. So please wait for my provider to fix it... __ "Double buffering": I'm working on it. Probably I'll have to render the metafile offscreen, and draw the created bitmap. __ "Resizing the window layout": I still don't know how it shall be done (not just technically, this would be at least possible - but most important: which controls and which control dimensions shall resize, which shall not; are there minimum sizes for some control dimensions; which shall keep their proportions relatively to which others...). I made all the controls so fixed, it would take much time to rewrite everything, especially if you would insist in resizing the bar graph panels. Last edited by LigH; 13th April 2004 at 13:40. |
13th April 2004, 18:39 | #39 | Link |
It crashed as soon as I ran it.
Zurgriffsverletzung bei Adresse BFF7B9A6 in Modul 'KERNEL32.DLL'. Schreiben von Adresse 0000000. Exception EReadError in Modul CQME.EXe bei 00001910B. Fehler beim Lesen von ZigZagImage.Picture.Data: Zurgriffsverletzung bei Adresse 0042264A in Modul CQME.EXE blah blah blah.... I have 98SE.
Anata wa baka da! REPENT! Last edited by lordadmira; 13th April 2004 at 18:41. |
