14th May 2011, 02:15 | #11964 | Link | |
I looked at your INF file and all the M2TS files look like they've resized correctly except this one: [00008] AUDIO=0010001 PGS=11111111110000000000000000 M2TS_TARGET=15969050483 USE_ORIGINAL=1 NSTART=27000000 NEND=376107840 NSIZE=17139953664 FLINK=0 MLINK=0 Looking at your log I see this: - [20:11:10] Extracting A/V streams [VID_00008] - [20:20:10] Reencoding: VID_00008 (5 of 38) - [20:20:10] Reencoding secondary video [TRK_02] - [20:36:23] Collecting video information - [20:36:23] Keeping original video (no reencode) - [20:36:23] Reencoding audio tracks (if req'd) - [20:38:03] Multiplexing M2TS - [20:46:31] Extracting A/V streams [VID_00011] - [20:46:36] Reencoding: VID_00011 (6 of 38) - [20:46:36] Collecting video information That's the only file that didn't reencode. The question is: Why did it keep the original video when it is obviously larger than the target? Keeping the original put that segment a little over 1GB larger than it should have -- which is pretty significant. I'll rerun mine again and see how that file comes out... Last edited by jdobbs; 14th May 2011 at 13:05. |
14th May 2011, 07:55 | #11965 | Link |
MOVIE-ONLY/ALTERNATE OUTPUT mode: DVD-5 Audio & Video not synched
@jdobbs
RE: - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio Aloha again jdobbs. I hope you are doing well. Just thought I'd let you know that Blu-ray to DVD-5 encodes do not have synched audio & video (e.g., action occurs first followed by sound, lips then words, etc). I am using version v0.37.08 and I do select in Setings: Target size BD-5 (DVD-5) in Output Options. Some recent titles I have tried are: Skyline, 127 Hours, & Jackass 3. Fyi, I have not tried B-r to DVD-9. Hope this info helps. Mahalo again for all you do jdobbs. |
14th May 2011, 12:38 | #11966 | Link |
Posts: n/a
The Matrix Revolutions has a glitch that may or may not cause issues in BD-RB. http://www.google.com.au/#sclient=ps...d37e06fcb306d6
Check http://www.amazon.com/Warner-Replace...sin=B000OPPBEQ If the error is in the source, and the glitch itself was encoded, then that wouldn't cause BD-RB any issues, but if the .m2ts is corrupt, then that might be a different story. |
14th May 2011, 13:17 | #11968 | Link |
@The_Unknown
Here is the log for 00008 on my system: - [19:38:01] Extracting A/V streams [VID_00008] - [19:45:02] Reencoding: VID_00008 (5 of 38) - [19:45:02] Reencoding secondary video [TRK_02] - [20:02:24] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 185,957 frames - Bitrate: 13,108 Kbs - [20:02:24] Reencoding: VID_00008, Pass 1 of 2 - [21:31:57] Reencoding: VID_00008, Pass 2 of 2 - [00:28:48] Video Encode complete - [00:28:48] Reencoding audio tracks (if req'd) - [00:30:20] Multiplexing M2TS and here is the INF entry: [00008] AUDIO=1000000001 PGS=11111111111111111111111 M2TS_TARGET=16255915495 RATE=13108 NSTART=27000000 NEND=376107840 NSIZE=15795542016 FLINK=0 MLINK=0 I can't imagine why it would act differently on yours. Notice that the source size is different on yours than it is on mine. |
14th May 2011, 13:37 | #11969 | Link | |
14th May 2011, 16:49 | #11970 | Link |
New release of BD Rebuilder v0.38.02 (beta)
I have updated the first post of this thread with an updated version of BD-RB (v0.38.02). Changes for this release:
- Changed the specified --vbv-maxrate on BD-25 backups to 32000 -- this has been reported to eliminate certain buffering issues. (v0.38.2) - Corrected an error in which a stream that was referenced as non-angled in one MPLS was not being correctly updated if referenced later as an angle. - Fixed an issue in which problems with a single DVD subtitle could cause the entire job to fail. - Changed the default color for ALTERNATE/DVD subtitles to white and shades of gray. - Modified IGS checks to prevent any part of the feature cannot be excluded from reencoding. - Updated the DVD subtitle logic to handle certain types of graphic PGSs. This should also prevent errors in multiplexing those PGSs. - Corrected an error in which DVD subtitles were not synched properly when ALTERNATE_PAL was in effect. - Added code to prevent the combination of primary and secondary (PiP) video streams from exceeding the BD total video limit. - Added additional checks to reduce vbv-maxrate if the combined total bitrate of all audio would put it above blu-ray maximums. - Corrected an issue in which ALTERNATE movie-only output sizing could be dramatically off when using the two-pass target size selection. - Updated the included version of DVDAUTHOR to version 7.0. This corrects "bad image" errors on certain types of graphic PGSs that were not supported in the previous version. - Updated the included version of X264.EXE to the latest release (r1995). - Updated the included version of X264-64.EXE to the latest release (r1995). - Other minor corrections and cosmetic fixes. Last edited by jdobbs; 14th May 2011 at 19:51. |
14th May 2011, 17:34 | #11971 | Link | |
BluRay Maniac
ChapterGen - manipulate with chapters in various i/o formats, with CLI support Official website or Doom9 thread |
14th May 2011, 19:15 | #11973 | Link |
@jdobbs: just an update for my HP5 issue. I was able to START the backup but not finish it. x264 crashed (my rig isnt overclocked) on stream VID_00033 wich is indicated as follows: VC-1, 1080i 29.97**, 587.15MB I suppose that pgs fix or whatever it was doenst work yet for full disc mode ?
14th May 2011, 19:18 | #11974 | Link |
@jdobbs
Thanks for the latest update. I tried again the Alternate PAL DVD backup from a 720p source using latest v0.38.01 The problem reported here is still there: The subs just flash up. Something is still wrong with the time stamps: Start and end times are almost identical. Code:
<spu start="00:02:06.14" end="00:02:06.15" image="C:\TEMP\BD REBUILDER\WORKFILES\DVDSUBS\4608_00014.png" transparent="101010" xoffset="202" yoffset="478" /> <spu start="00:02:08.82" end="00:02:08.83" image="C:\TEMP\BD REBUILDER\WORKFILES\DVDSUBS\4608_00015.png" transparent="101010" xoffset="104" yoffset="484" /> <spu start="00:02:11.90" end="00:02:11.91" image="C:\TEMP\BD REBUILDER\WORKFILES\DVDSUBS\4608_00016.png" transparent="101010" xoffset="126" yoffset="478" /> <spu start="00:02:15.70" end="00:02:15.71" image="C:\TEMP\BD REBUILDER\WORKFILES\DVDSUBS\4608_00017.png" transparent="101010" xoffset="138" yoffset="484" /> |
14th May 2011, 19:47 | #11975 | Link | |
14th May 2011, 19:50 | #11976 | Link | |
I loaded your latest release and give it a try in there. If it doesn't work here, I'll manually set it to 23400 MB to force a reencode. |
14th May 2011, 21:19 | #11979 | Link | |
INI per your request
RE: - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-9, 720x480/576, AC3 Audio Here is the INI B-r to DVD-9 using Jackass 3. Results are same as B-r to DVD-5. Audio & video are not synched. ----------------------- [Options] VERSION=0.37.0.8 MODE=1 ENCODE_QUALITY=0 ONEPASS_ENCODING=0 AUTO_QUALITY=1 MINIMIZE_TO_TRAY=1 TARGET_SIZE=8032 AUTO_BURN=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 MOVIEONLY_TYPE=2 ALTCRF=20 ALT_TARGET=1000 ALTMETHOD=0 QUICK_EXTRAS=1 [Paths] SOURCE_PATH=H:\ANYDVD HD BLU-RAY RIPS\JACKASS_3\ WORKING_PATH=H:\BD-REBUILDER\DVD-9, 720X480_576, AC3 AUDIO\ ----------------------- Here is the INF: [Status] LABEL=JACKASS_3 VERSION=v0.37.08 (beta) SOURCE_SIZE=24442490880 SOURCE_VIDEO_SIZE=24442490880 TARGET_SIZE=8422162432 REDUCTION=.344570546158674 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=2 USE_LAVF=0 QUICK=0 ENCODE_STEP=0 COMPLETED=15 REBUILD_COMPLETE=1 [00246] AUDIO=0001 PGS=10000 M2TS_TARGET=2561768330 NSIZE=0 FLINK=-1 MLINK=0 [00261] M2TS_TARGET=315235938 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00248] M2TS_TARGET=1450368151 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00262] M2TS_TARGET=121215441 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00250] M2TS_TARGET=710343615 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00263] M2TS_TARGET=123753774 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00252] M2TS_TARGET=226345602 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00264] M2TS_TARGET=82513807 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00254] M2TS_TARGET=199992670 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00265] M2TS_TARGET=58769070 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00256] M2TS_TARGET=204404585 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00266] M2TS_TARGET=172693421 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00258] M2TS_TARGET=1408526944 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00267] M2TS_TARGET=62545872 AUDIO=0001 NSIZE=0 FLINK=-1 MLINK=0 [00260] M2TS_TARGET=723685210 AUDIO=0001 NSIZE=0 FLINK=0 MLINK=0 ----------------------- Here is the LOG: [21:43:18] BD Rebuilder v0.37.08 (beta) - Source: JACKASS_3 - Input BD size: 22.76 GB - Approximate total content: [01:39:44.561] - Windows Version: 5.1 [2600] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-9, 720x480/576, AC3 Audio - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21:43:18] PHASE ONE, Encoding - [21:43:18] Extracting A/V streams [VID_00246] - [22:06:54] Reencoding: VID_00246 (1 of 15) - [22:06:54] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 43,582 frames - Bitrate: 8,552 Kbs - [22:06:54] Reencoding: VID_00246 - [00:04:52] Video Encode complete - [00:04:52] Reencoding audio tracks (if req'd) - [00:10:24] Multiplexing M2TS - [00:10:24] Extracting A/V streams [VID_00261] - [00:11:26] Reencoding: VID_00261 (2 of 15) - [00:11:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 5,511 frames - Bitrate: 8,552 Kbs - [00:11:26] Reencoding: VID_00261 - [00:24:16] Video Encode complete - [00:24:16] Multiplexing M2TS - [00:24:16] Extracting A/V streams [VID_00248] - [00:28:38] Reencoding: VID_00248 (3 of 15) - [00:28:38] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 24,621 frames - Bitrate: 8,552 Kbs - [00:28:38] Reencoding: VID_00248 - [01:20:04] Video Encode complete - [01:20:04] Multiplexing M2TS - [01:20:04] Extracting A/V streams [VID_00262] - [01:20:27] Reencoding: VID_00262 (4 of 15) - [01:20:27] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,105 frames - Bitrate: 8,552 Kbs - [01:20:27] Reencoding: VID_00262 - [01:25:37] Video Encode complete - [01:25:37] Multiplexing M2TS - [01:25:37] Extracting A/V streams [VID_00250] - [01:27:49] Reencoding: VID_00250 (5 of 15) - [01:27:49] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12,167 frames - Bitrate: 8,552 Kbs - [01:27:49] Reencoding: VID_00250 - [02:00:05] Video Encode complete - [02:00:05] Multiplexing M2TS - [02:00:05] Extracting A/V streams [VID_00263] - [02:00:30] Reencoding: VID_00263 (6 of 15) - [02:00:30] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,131 frames - Bitrate: 8,552 Kbs - [02:00:30] Reencoding: VID_00263 - [02:05:36] Video Encode complete - [02:05:36] Multiplexing M2TS - [02:05:36] Extracting A/V streams [VID_00252] - [02:06:19] Reencoding: VID_00252 (7 of 15) - [02:06:19] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,873 frames - Bitrate: 8,552 Kbs - [02:06:19] Reencoding: VID_00252 - [02:14:51] Video Encode complete - [02:14:51] Multiplexing M2TS - [02:14:51] Extracting A/V streams [VID_00264] - [02:15:07] Reencoding: VID_00264 (8 of 15) - [02:15:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,424 frames - Bitrate: 8,552 Kbs - [02:15:07] Reencoding: VID_00264 - [02:18:33] Video Encode complete - [02:18:33] Multiplexing M2TS - [02:18:33] Extracting A/V streams [VID_00254] - [02:19:09] Reencoding: VID_00254 (9 of 15) - [02:19:09] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,390 frames - Bitrate: 8,552 Kbs - [02:19:09] Reencoding: VID_00254 - [02:26:58] Video Encode complete - [02:26:58] Multiplexing M2TS - [02:26:58] Extracting A/V streams [VID_00265] - [02:27:10] Reencoding: VID_00265 (10 of 15) - [02:27:10] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,009 frames - Bitrate: 8,552 Kbs - [02:27:10] Reencoding: VID_00265 - [02:29:59] Video Encode complete - [02:29:59] Multiplexing M2TS - [02:29:59] Extracting A/V streams [VID_00256] - [02:30:38] Reencoding: VID_00256 (11 of 15) - [02:30:38] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,498 frames - Bitrate: 8,552 Kbs - [02:30:38] Reencoding: VID_00256 - [02:38:16] Video Encode complete - [02:38:16] Multiplexing M2TS - [02:38:16] Extracting A/V streams [VID_00266] - [02:38:48] Reencoding: VID_00266 (12 of 15) - [02:38:48] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,980 frames - Bitrate: 8,552 Kbs - [02:38:48] Reencoding: VID_00266 - [02:45:56] Video Encode complete - [02:45:56] Multiplexing M2TS - [02:45:56] Extracting A/V streams [VID_00258] - [02:50:14] Reencoding: VID_00258 (13 of 15) - [02:50:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 23,914 frames - Bitrate: 8,552 Kbs - [02:50:14] Reencoding: VID_00258 - [03:44:38] Video Encode complete - [03:44:38] Multiplexing M2TS - [03:44:38] Extracting A/V streams [VID_00267] - [03:44:50] Reencoding: VID_00267 (14 of 15) - [03:44:50] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,050 frames - Bitrate: 8,552 Kbs - [03:44:50] Reencoding: VID_00267 - [03:47:16] Video Encode complete - [03:47:16] Multiplexing M2TS - [03:47:16] Extracting A/V streams [VID_00260] - [03:49:28] Reencoding: VID_00260 (15 of 15) - [03:49:28] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12,231 frames - Bitrate: 8,552 Kbs - [03:49:28] Reencoding: VID_00260 - [04:16:33] Video Encode complete - [04:16:33] Multiplexing M2TS [04:16:33]PHASE ONE complete [04:16:33]PHASE TWO - Rebuild Started - [04:16:33] Rebuilding stream 00246 [1 of 15] - [04:16:33] Rebuilding stream 00261 [2 of 15] - [04:16:33] Rebuilding stream 00248 [3 of 15] - [04:16:33] Rebuilding stream 00262 [4 of 15] - [04:16:33] Rebuilding stream 00250 [5 of 15] - [04:16:33] Rebuilding stream 00263 [6 of 15] - [04:16:33] Rebuilding stream 00252 [7 of 15] - [04:16:33] Rebuilding stream 00264 [8 of 15] - [04:16:33] Rebuilding stream 00254 [9 of 15] - [04:16:33] Rebuilding stream 00265 [10 of 15] - [04:16:33] Rebuilding stream 00256 [11 of 15] - [04:16:33] Rebuilding stream 00266 [12 of 15] - [04:16:33] Rebuilding stream 00258 [13 of 15] - [04:16:33] Rebuilding stream 00267 [14 of 15] - [04:16:33] Rebuilding stream 00260 [15 of 15] - [04:16:33] Building ALTERNATE OUTPUT Structure - [04:22:25] Converting 1 subtitles to DVD format. - [04:23:07] Starting MPLEX. - [04:32:43] Multiplexing 1 subtitles into stream. - [04:41:08] Building DVD File Structure. [04:50:20] - Encode and Rebuild complete - WORKFILES folder removed. [04:50:27]JOB: JACKASS_3 finished. ----------------------- |
14th May 2011, 21:48 | #11980 | Link | |
Edit: jdobbs, may I ask what --vbv-maxrate was previously set to (30000?)? I promise not to start a debate over this here in the bug thread, just wondering for informational and learning purposes. Thanks. Last edited by A.Fenderson; 14th May 2011 at 21:54. |
