21st February 2007, 14:32 | #541 | Link |
AviSynth plugger
qwerpoi,
thanks for update. Some time ago I think about adding to Avisynth 2.6 some new syntax rules, in particular comment blocks.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
21st February 2007, 15:08 | #543 | Link |
Thanks for the new version qwerpoi! French translation updated
The enhanced video editing capabilities sound very nice! And the new way of saving all AvsP markers as comments in the script is really a simple yet very good idea! About the color syntaxing bugs I mentionned, I still have some apparently.. I tried the fix you mentionned for the filters.dat, but didn't seem to work (?) as the file was not overwritten ; I made a mod in my filters definition so that the file gets overwritten. I don't think there is a problem with words recognition anymore. But for the color syntax behaviour itself I still have the same strange problem: - Initial condition: Default: font = standard, black Internal function: font = bold, orange - Start AvsP -> as defined above - Change Default from standard to bold -> ok - Change Default from bold to standard -> stay bold - Reload AvsP -> ok (now standard, as per the initial condition) - Change Internal function to standard -> ok (!) - Change Internal function to bold -> ok - Change Internal function to standard (again) -> ok - Change Default to bold -> ok for Default, but Internal function is now bold as well! This above shows you that there is some dependencies between the items in font and colors.. Also, for the Advance->Brace Highlight for instance, if I want to change the font size to say 20 instead of the default (10), it stays at 10, even if I reload AvsP |
22nd February 2007, 00:02 | #545 | Link | ||||||
Thanks for the speedy translation update! Quote:
22nd February 2007, 01:35 | #546 | Link |
Angel of Night
The funny thing is, I was going to ask for a vdub-style slider, and all th sudden here it is! Wow, telepathic feature requests do work. In all seriouness, excellent update, it's amazing how much work got put into it.
Is it possible to have a switch to release avisynth? That would help for some very memory-intensive scripts, at which point I could hopefully go back to working after an allocation failure without having to recycle avsp. (Or just to leave it for something else for a while.) Should I just modify the source myself for such a thing? |
22nd February 2007, 03:24 | #547 | Link | ||
23rd February 2007, 13:06 | #552 | Link |
Angel of Night
It's probably because you already have something open. You have to start from a completely clean slate, closing all files and having only a single empty tab open. It's a proof-of-concept thing, I guess, so it's not very robust.
23rd February 2007, 13:28 | #553 | Link |
Thanks, that seemed to do the trick. Only issue i have now is that its seems to have stretched the progress/slider bar vertically with teh 4 scripts open, so i can barely see any video preview, and no way to set it back to normal manually.
23rd February 2007, 15:22 | #554 | Link |
Feature Request: Support for *.dga files.
@qwerpoi, DG has released DGAVCDEC to enable AVC/H.264 indexing & decoding. Can AvsP be updated to load *.dga files as AVCSource(..) instead of DirectShowSource(..)?
23rd February 2007, 15:53 | #555 | Link | |
(!sig) |
23rd February 2007, 16:20 | #556 | Link |
One usefull feature that would be nice to have is deletframe copyframe and freezeframe commands attached to a keystroke: ie. if u press d that it will delete the frame the slider is set on at that time and c to make a duplicate of the current frame.
Just don't have a clue if that's even feasible. |
23rd February 2007, 16:57 | #558 | Link | |
Angel of Night
avsp.InsertText('DeleteFrame(' + avsp.GetFrameNumber() + ')') Save as '[9] DeleteFrame.py' or so, restart AvsP and use Configure Shortcuts to assign it to whatever you like. A function key will probably be easiest. Repeat with the other variations. |
23rd February 2007, 17:31 | #559 | Link | |
Tried it, get an error when I try the keycombo I set the macro to: "Error in Macro: Cannot concatenate 'str' and 'int' objects" |
