3rd November 2012, 16:25 | #15302 | Link |
My script is very specific to my machines. I hardcode my paths into the installer and my scripts that install do so from very specific locations on my network. So they wouldn't help anyone else which is why I don't bother releasing them.
3rd November 2012, 16:27 | #15303 | Link | |
I have one DVD where the DVD menu is not working correctly. The main menu is working perfectly fine, however, If I go into the languages selection I cannot select various options with the mouse (the mouse cursor acts like the option isnīt there) and they are also not highlighted. It works fine with the keyboard up/left/down/right keys, though. What do you need from me to fix it? I can upload the DVD menu if you want, I already have it RARed on my HDD. Last edited by iSunrise; 3rd November 2012 at 16:31. |
3rd November 2012, 16:34 | #15304 | Link | |||
Yes, but with lower deinterlacing quality. Quote:
3rd November 2012, 16:44 | #15305 | Link | |
3rd November 2012, 17:11 | #15306 | Link |
Broadband Junkie
So as far as madVR is concerned, what does that mean for native 4:2:2 video which is interlaced?
Will such video continue to be de-interlaced by madVR in the next build? Does the '4:2:0 only' error mean that madVR will/does sub-sample 4:2:2/4:4:4 chroma to 4:2:0 before passing it off to deinterlacing? What are the options for real-time playback 4:2:2 MPEG-2 & H.264 deinterlacing of better quality than DXVA2? |
3rd November 2012, 18:06 | #15307 | Link |
madVR downconverts 4:2:2 video to 4:2:0, so DXVA deinterlacing is performed with highest quality. The "4:2:0 complaint" is a bug, as I said, it will be fixed in the next build. Simply ignore it. IMHO deinterlacing of 4:2:2 and 4:4:4 content is extremely unimportant because it's very rare. As a result I'm not interested in getting headaches about it right now. There are still many far more important things to do.
3rd November 2012, 22:06 | #15309 | Link | ||
3rd November 2012, 22:07 | #15310 | Link |
MPC-HC Developer
@dansrfe: Read this post http://forum.doom9.org/showthread.ph...81#post1598981
4th November 2012, 09:41 | #15313 | Link |
Quick question: Right now I'm using MPC-HC+ffdshow+madVR+Directvobsub and I'm upscaling the video using ffdshow (to desktop resolution) so that subs wouldn't look like crap on low resolution videos but because of this, I can't benefit from madVR's HQ scaling algorithm since the video is already upscaled by ffdshow. Are there any other alternatives in which case I can get HQ subs without having to do the upscaling using ffdshow and instead use madVR for that? Using MPC-HC's internal subtitle renderer is out of the question because it fails to render even not-so-advanced typesetting properly (yes, I know MPC-HC uses the same code as Directvobsub but they most certainly draw subs differently).
4th November 2012, 09:47 | #15314 | Link | ||
4th November 2012, 10:05 | #15315 | Link | |
Playing with MKV files...
If you haven't tried the renderer on the current-release MPC-HC I suggest you give it a shot. I personally would very much like the know the filename/see the subtitle script of a file that does not render its subs correctly.
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8 |
4th November 2012, 11:26 | #15317 | Link | |
4th November 2012, 11:27 | #15318 | Link |
madshi
Thank you very much for DVD playback! No need to convert DVDs to .mkv now! Please have a look. I start playback then seek, then switch 23->59 (Film -> Video) and audio starts stuttering, and madvr drops frames. It happens only when audio is Dts-HD MA. The log: https://dl.dropbox.com/u/43376972/madVR%20-%20log%204-11-12.zip Thaks! |
4th November 2012, 11:37 | #15319 | Link | |
According to the log the rendering queue never fills again (stays at max 2/8) after the switch to 59. Are you sure your GPU is fast enough for 59 playback? |
