Old 22nd January 2012, 09:38   #10641  |  Link
ese232
http://imageshack.us/f/10/ver1165.jpg/
http://imageshack.us/f/535/ver117.jpg/
hi,
the same computer, same video.
What can I do?
ese232 is offline   Reply With Quote
Old 22nd January 2012, 10:57   #10642  |  Link
Trayman
Trayman's Avatar
@ese232 What source do you have Bluray, DVD or Downloaded ?
//Trayman
Trayman is offline   Reply With Quote
Old 22nd January 2012, 11:02   #10643  |  Link
ese232
//Trayman
downloaded but i think HDTV record.
Old 22nd January 2012, 11:03   #10644  |  Link
Trayman
Trayman's Avatar
Then we are not allowed to help you according to the forum rules. Sorry!
//Trayman
Old 22nd January 2012, 11:04   #10645  |  Link
stasi
hi,
What can I do?
I had the same error on earlier versions of Ripbot. Try to delete the locale folder under tools\mkvtoolnix. And try a shorter input filename.
stasi is offline   Reply With Quote
Old 22nd January 2012, 13:41   #10646  |  Link
Chudz
Hey I just re-encoded a Bluray Remux and something weird happened. It seems to have not re-encoded just repackaged it or something.
I am using default settings with RipBot264 "CQ: 22" etc only thing I change is the crop to get rip of black borders and denoise FILM.
The file size at the end of the encode was 16.5gb :S Here is the MediaInfo for the source:
General
Unique ID : 219575428819153978712911125335292378048 (0xA530B078AE5D83A8B03807E8C255FBC0)
Complete name : C:\Users\Chudz\Downloads\Aliens Special Edition 1986 Blu-ray CEE Remux 1080p AVC DTS-HD MA 5.1-ALeSiO.mkv
Format : Matroska
Format version : Version 2
File size : 33.1 GiB
Duration : 2h 34mn
Overall bit rate mode : Variable
Overall bit rate : 30.7 Mbps
Movie name : Aliens Special Edition 1986 Blu-ray CEE Remux 1080p AVC DTS-HD MA 5.1-ALeSiO
Encoded date : UTC 2011-07-16 07:58:39
Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@0.0
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 34mn
Bit rate mode : Variable
Bit rate : 28.2 Mbps
Maximum bit rate : 36.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.568
Stream size : 30.4 GiB (92%)
Title : Aliens Special Edition 1986 Blu-ray CEE 1080p AVC
Language : English
Default : No
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Duration : 2h 34mn
Bit rate : 1 852 Kbps / 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : DTS-HD MA 5.1
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Title : SDH
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Title : CEE
Language : Russian
Default : No
Forced : No
Text #3
Format : PGS
Title : Kinomania
Language : Russian
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:02:06.751 : en:Chapter 02
00:05:15.731 : en:Chapter 03
00:08:34.346 : en:Chapter 04
00:10:52.109 : en:Chapter 05
00:15:13.620 : en:Chapter 06
00:17:25.001 : en:Chapter 07
00:20:54.126 : en:Chapter 08
00:25:02.500 : en:Chapter 09
00:25:57.471 : en:Chapter 10
00:30:03.718 : en:Chapter 11
00:32:53.887 : en:Chapter 12
00:35:56.862 : en:Chapter 13
00:38:03.530 : en:Chapter 14
00:45:40.070 : en:Chapter 15
00:52:28.519 : en:Chapter 16
00:54:48.076 : en:Chapter 17
00:56:09.114 : en:Chapter 18
01:00:11.106 : en:Chapter 19
01:04:47.507 : en:Chapter 20
01:10:10.997 : en:Chapter 21
01:12:51.992 : en:Chapter 22
01:16:22.868 : en:Chapter 23
01:21:22.252 : en:Chapter 24
01:23:17.199 : en:Chapter 25
01:26:21.134 : en:Chapter 26
01:31:22.059 : en:Chapter 27
01:34:37.421 : en:Chapter 28
01:37:25.255 : en:Chapter 29
01:38:40.706 : en:Chapter 30
01:41:23.243 : en:Chapter 31
01:45:03.462 : en:Chapter 32
01:47:15.552 : en:Chapter 33
01:51:41.402 : en:Chapter 34
01:52:58.604 : en:Chapter 35
02:02:10.363 : en:Chapter 36
02:05:54.046 : en:Chapter 37
02:07:41.987 : en:Chapter 38
02:13:15.528 : en:Chapter 39
02:17:29.615 : en:Chapter 40
02:22:24.701 : en:Chapter 41
02:23:16.711 : en:Chapter 42
02:30:16.005 : en:Chapter 43
02:31:36.461 : en:Chapter 44
And the MediaInfo for the Encoded file:
General
Complete name : F:\Movies\Aliens Special Edition.mp4
Format : MPEG-4
Format_Commercial_IfAny : XDCAM EX 25
Format profile : Base Media
Codec ID : isom
File size : 16.4 GiB
Duration : 2h 34mn
Overall bit rate : 15.2 Mbps
Encoded date : UTC 2012-01-22 10:27:32
Tagged date : UTC 2012-01-22 10:27:32
Cover : Yes
Video
Format : AVC
Format profile : High@L4.0
Format settings, ReFrames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 34mn
Bit rate : 14.9 Mbps
Maximum bit rate : 25.0 Mbps
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.300
Stream size : 16.1 GiB (98%)
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2012-01-22 10:44:10
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 34mn
Bit rate : 320 Kbps
Maximum bit rate : 331 Kbps
Compression mode : Lossy
Stream size : 354 MiB (2%)
Language : English
Encoded date : UTC 2012-01-22 10:43:30
Menu
00:00:00.000 : Chapter 01
00:02:06.751 : Chapter 02
00:05:15.731 : Chapter 03
00:08:34.346 : Chapter 04
00:10:52.109 : Chapter 05
00:15:13.620 : Chapter 06
00:17:25.001 : Chapter 07
00:20:54.126 : Chapter 08
00:25:02.500 : Chapter 09
00:25:57.471 : Chapter 10
00:30:03.718 : Chapter 11
00:32:53.887 : Chapter 12
00:35:56.862 : Chapter 13
00:38:03.530 : Chapter 14
00:45:40.070 : Chapter 15
00:52:28.519 : Chapter 16
00:54:48.076 : Chapter 17
00:56:09.114 : Chapter 18
01:00:11.106 : Chapter 19
01:04:47.507 : Chapter 20
01:10:10.997 : Chapter 21
01:12:51.992 : Chapter 22
01:16:22.868 : Chapter 23
01:21:22.252 : Chapter 24
01:23:17.199 : Chapter 25
01:26:21.134 : Chapter 26
01:31:22.059 : Chapter 27
01:34:37.421 : Chapter 28
01:37:25.255 : Chapter 29
01:38:40.706 : Chapter 30
01:41:23.243 : Chapter 31
01:45:03.462 : Chapter 32
01:47:15.552 : Chapter 33
01:51:41.402 : Chapter 34
01:52:58.604 : Chapter 35
02:02:10.363 : Chapter 36
It took 10 Hours as well apparently I left it on when I went to bed.
Chudz is offline   Reply With Quote
Old 22nd January 2012, 13:58   #10647  |  Link
jandor
jandor's Avatar
@Trayman
I understand you now.
Also I never caught a movie like that.
Perhaps you must use the VobBlanker: http://download.videohelp.com/jsoto/vobblanker.htm
Or ReJig (IFO Mode): http://www.videohelp.com/tools/ReJig
jandor is offline   Reply With Quote
Old 22nd January 2012, 16:30   #10648  |  Link
james2432
I tried ripping bluray subtitles from a bluray. It ripped the .sup file but when I looked in the .mkv the subtitles were not merged into it.
I manually had to rip the sup file to srt and mux it in with SupRip and mkvmerge from the .sup file that was created by ripbot
File Type: txt job1_MuxFiles cmd.txt (337 Bytes, 30 views)
james2432 is offline   Reply With Quote
Old 23rd January 2012, 14:24   #10649  |  Link
Ronski
Jimmy,I'll be interested to hear how you get on , I don't use home group either and have a Windows home server 2011, which is on 24/7 so old like to make use of it for distributed encoding overnight.
Originally Posted by JimmyK814 View Post
I've been a user of RipBot264 for years and have not a single complaint. The only thing I haven't been able to solve is how to encode E-AC3 from TrueHD or DTSMA to preserve 7.1 channels and keep the file sizes small. That's a discussion for another day...
My latest problem is trying to get the distributed encoding to work. I was very excited to see this as an option to get around the typical 2 hour 720p encodes.
While I know it's overkill to have a home domain, I have for many many years and it serves me well. I have Windows 7 desktops and recently changed to a Windows 2008 r2 server, up from Win2k3.
I've tried for the better part of a week to get the client/server model to work with no luck. I always get the ENCODING/IDLE "dance" at start-up. I think the automatic discovery of the RipBot264temp is my biggest problem. Whenever I share the folder, it is shared as \\COMPUTERNAME\RipBot264temp on whichever workstation I choose. Whenever the programs tries to access the folder it is looking for \\DOMAIN\RipBot264temp.
I've tried many hacks to try to allow it to find the share correctly, even creating folders on the server and trying to make \\DOMAIN\RipBot264temp a valid path. I have yet to get into DFS pointers which may work. I know this was designed with HomeGroups in mind, and I'm guessing the HomeGroup and Domain are picked up in the same fashion and that is why his happens, but I wondered if it would be possible for a configuration option where perhaps you could say the share is located on the same IP address as Server X.
I'm not sure that I completely understand if each workstation is supposed to have it's own share, or if one is shared by all workstations.
Is there any way to make this work without a HomeGroup? I would be more than willing to help out with any beta testing and give a donation.
Any help is much appreciated! Maybe I'm just being stupid about this...
Jim
Ronski is offline   Reply With Quote
Old 23rd January 2012, 17:09   #10650  |  Link
iSeries
Hi Atak,
Is there any chance you could add some 2.0 AC3 options for MKV (or even just 2.0 192kbps)? I realise that bitrate for bitrate AAC is superior, however my blu ray player only supports AC3 or DTS within MKV files.
iSeries is offline   Reply With Quote
Old 23rd January 2012, 20:19   #10651  |  Link
Ronski
Hi Atak, could you add the option to sleep when finished encoding, or even just the option to run a BAT file will suffice please?
Can't use the Sleep when idle option in W7, as MS can't seem to work out that 4 cores running at 100% is not idle, and it just goes to sleep whilst encoding, so i have to disable sleep when using Ripbot.
Old 24th January 2012, 00:47   #10652  |  Link
squezer
Hi, Atak,
thx for you work at first.
Please, why is ripbot v1.17 auto-renaming my Sony camcorder´s files from "anything.m2ts" to just "video.mkv" ?
Before it worked as expected from test1.m2ts to test1.mkv, test2.m2ts to test2.mkv etc...
I have usually 16 files from one recorded miniDVD, its boring to rename them back manualy.
Could you fix it for me, please?
squezer is offline   Reply With Quote
Old 24th January 2012, 06:30   #10653  |  Link
JimmyK814
I'm excited to get it working. I imagine there are higher priorities right now, especially if it's working for non-domain people just fine. I'm quite grateful for the wonderful piece of software. I don't mind being patient and waiting for a while.
JimmyK814 is offline   Reply With Quote
Old 24th January 2012, 06:35   #10654  |  Link
hoju3508
@Chudz, it did re-encode your source.
http://valid.canardpc.com/cache/banner/1756465.png
hoju3508 is offline   Reply With Quote
Old 24th January 2012, 06:42   #10655  |  Link
hoju3508
@james2432, that's correct. RipBot demuxes the audio, subtitles and video out into individual files for re-encoding. You can use mkvmerge to combine them again into a mkv container if that's what you want.
BTW, MPC-HC plays mkv with .sup files without any problems. I'm not sure about media players like Dune or Popcorn Hour.
Old 24th January 2012, 12:30   #10656  |  Link
soneca
The Dune HD plays perfectly subtitles(.sup) embedded in the mkv created with RipBot.
soneca is offline   Reply With Quote
Old 24th January 2012, 18:40   #10657  |  Link
Ryushin
Ryushin's Avatar
I'm using the latest update from January 20th, to encode both Last Man Standing and Last Boy Scout:
http://www.blu-ray.com/movies/The-La.../10754/#Review
Both use the VC-1 encodes. Both have pix-elated corruption every minute or so. I'm rolling back to 1.16.5 to encode these.
Is there any information I can provide to help solve the issue with this?
Ryushin is offline   Reply With Quote
Old 24th January 2012, 20:21   #10658  |  Link
Balthazar2k4
Thanks Ryushin for testing that. I have been meaning to try it for days now, but just been too busy.
Balthazar2k4 is offline   Reply With Quote
Old 24th January 2012, 20:21   #10659  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
can you upload 10 min sample (video.mkv from temp folder) to www.mediafire.com. zip file into smaller chunks because mediafire may reeject one huge file.
Old 25th January 2012, 07:26   #10660  |  Link
Ryushin
Ryushin's Avatar
Six and a half hours later.... (my poor dsl line)
http://depositfiles.com/files/qzln88dk6
I did not realize that depositfiles.com download was so awful. I won't use them again. Let me know if you want to download it directly from my server. It only has a 896kb uplink though.
