10th February 2008, 14:39 | #681 | Link |
HDConvertToX author
latest build of x264 have added AQ automatically if not set "--aq-strenght 0" (the same on automkv, but fixed in next version)
the avinaptic problem is due to "--nal-hrd -aud" parameter used for compatibility with ps3/bluray BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
10th February 2008, 15:29 | #682 | Link | |
I'm not using keyint 13 for fun.. it's a test. With the default command line from ripbot264 and automkv I still got the buffer underflowns.. and it's not for all the movies.. just one. Still trying to figure what cause the problem. I think it's a bug in x264. for now, I'm trying settings like Sagitaire suggested. (--qcomp 0.50) I did a test with keyint 24 and --qcomp 0.50, vbv-max 26000.. still got the error.. now keyint 24, vbv 30000 --qcomp 0.45 will know in 3.5 hours Last edited by survivant001; 10th February 2008 at 15:34. |
10th February 2008, 19:04 | #683 | Link | |
Can we have a second "more conventional" Level 4.1 profile for computers, xbox, popcornhour and such. I don't like the fact I can not open it in avinaptic. PS3 is such a strange animal. |
10th February 2008, 21:27 | #685 | Link | ||
10th February 2008, 21:45 | #686 | Link | |
Using your variation of the standard bitrate formula doesn't work with the files I have tested (you are not applying the overhead to the audio). To me it seems that adding a 5,2% compensation to the duration for the overhead (m2ts + avchd structure) does the trick using the standard bitrate formula. BUT the audio bitrate must be used within the calculation, substracting the audio file size will not work (I don't know why, maybe because the audio is not the same duration as the movie, I'm not sure) (yes, I am using audio stream copy). Btw: you forgot to apply the overhead to the audiofilesize (audiofilesize*1.065), but as I said above, even with applying the overhead (I use 1.052) to the audio filesize the video bitrate comes out to high. So, the only way I was able to make it work was by using the audio bitrate. The standard bitrate formula is: ((Size - (Audio * Length )) / Length) *8° = Video bitrate Example with a 2h40 movie: L = 160 x 60 = 9600s Duration = 9600 * 1.052 = 10099.2 (5.2% overhead) S= 4480 x 1024= 4'587'520 A= 640k / 8° = 80KB/s (640k ac3) V= (((4'587'520 - (10099.2 * 80))/10099.2)*8°) = 2994 I am testing this with some more movies with different durations, but until now it seems to be fine. Last edited by Bigmango; 10th February 2008 at 22:05. |
10th February 2008, 22:41 | #687 | Link |
After some more testing it seems that the best way is to just substract 5.5% overhead from the media size. This will work if you use an audio bitrate and also if you substract the audio file size doing an audio stream copy.
Example (same 2h40 movie as above, 748405 is 730Mb audio size): V= ((4'587'520*0.945 - (9600 * 80))/9600)*8° = 2973 and V= ((4'587'520*0.945 - 748405)/9600)*8° = 2989 I think 5.5% is good as it keeps a small margin, 5% is not enough if using audio stream copy. Edit: fyi, with this 2h40 movie a video bitrate of 2996 will match 4480Mb exactly (using audio stream copy). Last edited by Bigmango; 10th February 2008 at 22:48. |
10th February 2008, 22:52 | #688 | Link | |
What do you think about this? tempcalc:=(size*1048576/duration*8/1.052-audiobitrate*1.052)/1000; So I get 3032 Kbps instead of 2994
10th February 2008, 22:58 | #689 | Link | |
What do you think about just substracting 5.5% from the media size (as per my 2nd post) ? Edit: in my example 4480Mb = m2ts + avchd structure (final tsremux blu-ray output, ready to burn to DVD) Last edited by Bigmango; 10th February 2008 at 23:10. |
10th February 2008, 23:12 | #690 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 10th February 2008 at 23:21. |
10th February 2008, 23:35 | #691 | Link | |
Now I have 3h07 in the pipe (about 40 minutes more encoding), and after this I am doing a 1h55 movie encode. I have no 90 minutes movie at hand currently, but will test it as soon as I get the opportunity. |
10th February 2008, 23:51 | #692 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 10th February 2008 at 23:55. |
11th February 2008, 00:32 | #693 | Link |
Ok, so the 3h07 movie is done. 5.5% overhead is not enough, it needs a 6% overhead which will give it a 2435 bitrate.
I still don't have the right formula, but this is some info for you (audio is always 640k) based on real ripbot encodes (not calculations): With a 3h07 movie to match 4480Mb exactly (full avchd structure( m2ts + tsremux blu-ray)) you need a 2440 bitrate. With a 2h40 movie you need a 2996 bitrate to match 4480Mb. These are the maximum bitrates the calculation must give for these movie lenghts. I will test some more with shorter movies. Last edited by Bigmango; 11th February 2008 at 00:34. |
11th February 2008, 00:37 | #694 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 11th February 2008 at 00:50. |
11th February 2008, 01:10 | #695 | Link | |
If it can help you, these are the frame numbers of the above movies: 3h08: 269650 frames (max bitrate to reach 2440) 2h40: 229707 frames (max bitrate to reach 2996) |
11th February 2008, 01:20 | #696 | Link | |
11th February 2008, 01:38 | #697 | Link | |
I found these bitrates by encoding the movies 2 times (and a 3rd encode confirms the bitrate is right). So this is the exact max bitrate. BTW, I have 1 question: the 3h08 movie quality is very good @ 2440k, but I get some small blockyness sometimes on faces (but everything else is perfect). I am now encoding the movie again to improve this, with ESA, RDO lvl2, and p4x4. I think the PS3 will support this, but is p4x4 AVCHD compliant ? Also, would 4 b, 4 ref frames work ? |
11th February 2008, 08:05 | #698 | Link | |
85 min = 4482 MB (m2ts + bluray) We are almost at home
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 11th February 2008 at 08:10. |
