Old 1st July 2010, 07:29   #41  |  Link
lilhobo
no mp3 option?
lilhobo is offline   Reply With Quote
Old 1st July 2010, 07:33   #42  |  Link
ehushagen
There is, but only as long as you choose .mkv as your extension.
ehushagen is offline   Reply With Quote
Old 1st July 2010, 17:00   #43  |  Link
JohnAStebbins
RandomEngy, handbrake has supported mp3 in mp4 files since march.
http://trac.handbrake.fr/changeset/3167
JohnAStebbins is offline   Reply With Quote
Old 1st July 2010, 18:24   #44  |  Link
lilhobo
yeah but they might have taken it out along with xvid
Old 2nd July 2010, 17:22   #45  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Cool, I'll add it in next version.
RandomEngy is offline   Reply With Quote
Old 2nd July 2010, 18:14   #46  |  Link
lilhobo
can we have legacy AVI container please LOL
Old 2nd July 2010, 19:17   #47  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
VidCoder is a HandBrake wrapper and HandBrake is not bringing AVI back. It's an outdated and difficult to maintain container format.
Old 10th July 2010, 23:38   #48  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 0.5.1.
* Fixed Target Size functionality.
* Added Lame MP3 audio option when using MP4 container.
* Added ability to choose log verbosity and toned down the default logging verbosity from 2 to 1.
* Fixes x264 settings on the iPad preset.
* Made preset system more robust to encoding crashes.
Old 4th August 2010, 06:36   #49  |  Link
wpoulson
Posts: n/a
Thanks Random Energy for the great product.
I have a question about the constant quality setting. First, what is the reason for the differing scale value between Vidcoder and Handbrake, since Vidcoder uses the Handbrake engine? The Vidcoder default is 20, I think, and if I recall correctly, I think the Handbrake default is 60.something. Is the Vidcoder default the exact same as the Handbrake default. In your opinion, is there any benefit encoding at a setting of 18 vs 20?
Also, for anyone out there that might be able to answer this question...I recently mass encoded a large number of video files with Vidcoder. Most of the files compressed by 50% or more; however, there were a few that compressed by very little. I know every file is different, but does this sound like an incorrectly encoded file? It seems like most encodings will shrink file size by 50-66%.
I had some problems when trying to pass-through DTS or AC-3 5.1. The file would show instantaneously completed, but there was nothing really done. As a general plan, I decided to encode to MKV and keep the original audio for anything above 2-channel and go ahead and convert to aac the 2-channel AC-3. I have been demuxing the original VOB and encoding the video only in Vidcoder and later merging everything together. Can you provide a few words on how to successfully accomplish everything in Vidcoder for passing through DTS or DD 5.1?
Thanks
Warren
Old 4th August 2010, 16:11   #50  |  Link
JohnAStebbins
You must have been using an old version of handbrake. The '60' setting is from a scale that represented the inverse percentage of the full range of possible RF values available from the encoder (x264 RF values range from 0-51). It's inverse because 0 RF is highest quality. This % scale was less meaningful then using the ratefactor directly, so the latest handbrake nightlies have eliminated the % scale. The conversion is 51 - (% * 51). So 60 is equivalent to 20.4.
No way to tell without more information about the sources. Activity logs would help also.
Sounds like a potential vidcoder bug. Again, activity logs would show us what is happening.
Old 22nd August 2010, 14:03   #51  |  Link
ValorSolo
Nevermind, my error
Microsoft Windows XP
Home Edition
Version 2002
Service Pack 3
AMD Sempron(tm) Processor 3000+
1.79 GHz, 1.87 GB of RAM
ValorSolo is offline   Reply With Quote
Old 23rd August 2010, 15:02   #52  |  Link
ValorSolo
My last 3 encodes have all been defective.
The audio starts in sync, but gets out of sync as the movie progresses.
The audio track is faster than the video track.
I've encoded the same movies with RipBot264, and they stay in sync, through-out the film.
And all the movies I encoded with VidCoder before the issue appeared, were all in sync, as well.
General
Complete name : F:\Die Hard.mkv
Format : Matroska
File size : 551 MiB
Duration : 2h 13mn
Overall bit rate : 578 Kbps
Writing application : HandBrake svn3345
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container profile=Unknown@3.0
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 13mn
Nominal bit rate : 412 Kbps
Width : 718 pixels
Height : 368 pixels
Display aspect ratio : 2.35:1
Original display aspect ratio : 2.35:1
Frame rate mode : Variable
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.065
Writing library : x264 core 95 r1592 95aacc4
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=412 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : A_AAC
Duration : 2h 13mn
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Language : English
Home Edition
Version 2002
Service Pack 3
Old 29th August 2010, 18:43   #53  |  Link
ValorSolo
First off, the issue above only occurred if the source audio was dts.
I selected the ac3 track and it encoded fine, with no sync issues.
I do have a question, though.
Looking at the encoding setting above, I see that "threads=1, sliced threads=0".
Is there a way to change the threads in VidCoder?
And a feature request, although not very likely, but here goes.
A "Create Sample" button, to fully test settings before encoding.
In options, the user can specify starting point and stopping point.
Then clicking the button will create a small sample video.
Just a thought. It would be helpful.
Home Edition
Version 2002
Service Pack 3
Old 30th August 2010, 22:43   #54  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Not sure what's up with the sync issue. You can already create a sample encode though. Just open the Preview window and press the "Play" button. You can change the length of the sample in the options.
Old 31st August 2010, 06:12   #55  |  Link
ValorSolo
I'm familiar with the preview feature, and use it regularly.
But I was referring to creating a sample file in an output directory.
Unless there is a way to save the file created for the preview.
I'll take a look and see if it's possible.
And thanks for replying.
Would you happen to know the answer to my question about setting the threads in VC?
EDIT: I was able to locate the preview file at C:\Documents and Settings\~USERNAME~\Application Data\VidCoder\Preview.mkv on XP.
Home Edition
Version 2002
Service Pack 3
Old 6th September 2010, 17:49   #56  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
I'm not sure what exactly you mean by "changing the threads". HandBrake by default will auto-detect the number of cores in your system and spawn threads to use as many as it can. This is what VidCoder does. Do you want it to do something different?
Old 6th September 2010, 22:59   #57  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 0.6.0.
* Overhauled Advanced x264 panel to bring it up to date and streamline a few things.
* Reworked the Destination UI to be a bit cleaner than a plain textbox. Added more error checking on the Destination box.
* Broke out Current/Average FPS to a popup dialog box when hovering over the progress bar.
* Added "Same as Source" option for audio sample rate. Also did refactoring to store sample rate as a raw number in Hz.
* Visual refresh for Input/Output preview boxes: added gradients, shadows and moved the label inside the box.
* Added tab navigation for titles in the Chapter Markers dialog, and made the text selected by default after tabbing to another title.
* Changed auto-naming to avoid choosing the same name as the input file.
* Updated to latest HandBrake SVN (3501)
* Added icon to the "Play" button for generating preview clips and changed text to "Play Preview Clip".
* Added (No chapters found) marker when there is only one chapter, instead of the "Chapters 1 - 1" UI.
* Added tooltips explaining why the .mp4 extension or the Add Source Subtitle buttons are disabled.
* Tweaked color of paused progress bar.
* Fixed problem where batch file encodes were not automatically assigned the right extension.
* Fixed bug preventing chapter marker UI from showing/hiding when "Include Chapter Marker" checkbox is toggled.
* Fixed crash when using custom chapter names across titles with different chapter numbers. Disabled custom chapter names carrying over from title to title.
* Fixed bug that caused the Pixel Aspect Ratio to display as 0/0 when first switching to Custom Anamorphic.
* Fixed UI issues that could occur when the source scan failed.
Old 12th September 2010, 14:22   #58  |  Link
flebber
Practising Schemer
The new version seems to be coming along well. Running a few test encodes now. Really this next thing I can do this myself, but thought a good preset to add would be a default divxplus HD.
flebber is offline   Reply With Quote
Old 18th September 2010, 21:05   #59  |  Link
TOMillr
Like your tool, thanks for the hard work. However, how about adding an option to just do a pass-through for the video track (like you can do on a AC3 file)?
TOMillr is offline   Reply With Quote
Old 20th September 2010, 07:34   #60  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
However the HandBrake core libraries don't have video passthrough, so I can't put it in VidCoder.
