23rd March 2015, 22:11 | #28481 | Link | |
2. Stop seeking. 3. Haven't tried other renderers. 4. I think it only happens with high-resolution (720p+) H264 files. 5. Files are properly muxed with MKVmerge, quite a few of them by myself. 6. I had it enabled on my desktop, but not on my laptop. 7. Strangely enough, the one time I remember that the issue didn't go away no matter what, I checked the statistics and no dropped frames were being reported whatsoever. 8. LAV as splitter, ffdshow as both video and audio decoder. Windows 7 x64. Sorry that I can't give much useful info, the issue isn't always reproducible. |
23rd March 2015, 22:59 | #28483 | Link | |
Hardware decode also typically give off less heat, hence less noise. So for typical 1080p content, it is up to user liking IMO. I personally stick with software. If the CPU is not fast enough for your content, then there's no other option but to enable some kind of hardware acceleration/decode. Sent from my 306SH |
24th March 2015, 01:08 | #28484 | Link |
Gotcha guys.. Thx for the infos.
I need dxva on my pathetic 2520m laptop. The cooler is so crummy that using software lav + gpu catmull scale will push 80C, whereas dxva lav+madvr-dxva scaling only pushes 60C That's 20C difference.. and it's only a 1366x768 output..
Ghetto | 2500k 5Ghz |
24th March 2015, 09:45 | #28486 | Link |
i got this:
http://abload.de/img/haswellr9270l9kca.png defiantly not a interop fix. maybe be abit faster maybe not. using a haswell CPU and a r9 270 |
24th March 2015, 13:38 | #28487 | Link |
QB the Slayer
I tested the 15.3 Beta... and yet again on my rig, with settings pushed to the max, madVR performance dropped. All I do to recover the performance is roll-back the driver to 13.251 (I don't do a catalyst re-install)
QB
24th March 2015, 17:50 | #28488 | Link | |
Do try it. I think it might be a problem with the decoder, since no one else seems to be having this issue. If it's not really linked to madVR, we should move to a separate thread.
Also check GPU memory usage (with GPU-Z (freeware) or similar) and try lowering the queues' sizes. I would strongly advise you to switch to LAVFilters completely to avoid compatibility issues and just use a decoder that is actively developed. |
26th March 2015, 15:15 | #28491 | Link |
should be this: http://forum.doom9.org/showpost.php?...postcount=2770
it's out of the mpc-be thread. |
26th March 2015, 22:05 | #28493 | Link |
No, it is still the same.
madVR options explained |
27th March 2015, 02:43 | #28494 | Link |
Few quick questions please.
Just tried error diffusion - option 2 (latest madvr - Zoomplayer - Lav). I can see the small description next to it saying its different opt 1, but was just wondering is opt 2 a better option. I notice its slightly more expensive to run. 2nd. I tried option 2 because all of a sudden option 1 was showing thin vertical black lines on the screen. Took me ages to narrow down what was causing it. First I thought zoomplayer, so reset and loaded settings backup, and then moved onto madvr doing the same. I then started to go thru all the options one by one in madvr settings window and got to changing from error diffusion opt1 (my default) to opt 2 made the lines go away once I pressed apply. Back to opt1 and apply and the lines come back. No idea why, it just started today. Anyone have any thoughts on this? screengrab: http://i57.tinypic.com/2a7tpbb.jpg NV driver: 347.88 WHQL > HDMI > 50inch plasma TV 3rd question. The crash I mentioned above didn't manage to send via the web. I've only ever seen it send maybe twice in all the time I've been using madvr (which is years), and its tried many times. Zoom player Max v10 (my player) has access to the web, so do I need to allow some madvr exe access also via my PC firewall (Eset Smart Security 8). I hadn't had a crash for ages so just forgot to follow up why madvr crash reporter never managed to connect. Thanks in advance guys. Last edited by JonnyRedHed; 27th March 2015 at 08:27. Reason: forgot the image |
27th March 2015, 11:30 | #28496 | Link | |
http://bugs.madshi.net/view.php?id=250 i don't think mode 2 is better it's just different. just choice what looks better to you, if you don't see a difference don't use it. |
27th March 2015, 13:55 | #28498 | Link |
Didn't MPDN have similar problems with Optimus that were later fixed? I do not follow that topic closely, but I vaguely remember a black screen issue with too large queue size. I am not sure if that was Optimus specific. But you could test with all queues at minimum size in madVR.
MPC-HC 2.1.7.2 |
27th March 2015, 14:21 | #28499 | Link |
that's what i know:
http://forum.doom9.org/showthread.ph...optimus&page=3 maybe MPDN has a better chance in fixing this it is a hole new problem while mpc-hc and player like that are normal playback software that is usually set to low powerstate/iGPU to spare power. people can try min queue size but some feature may totally fail with that. |
27th March 2015, 14:30 | #28500 | Link | |
