9th June 2009, 21:07 | #3181 | Link |
Here is a test clip that shows stuck on the progress bar @ 0% during both first and second passes.
Attached is a screenshot of the 'SHOW_ENCODER=1' parameter inserted into the INI which you requested.
MBK |
9th June 2009, 22:01 | #3182 | Link |
Just out of curiosity, I changed the Target Size (copying Movie Only to BD9) from the default of 7910 to 8250 (based on mouo's settings) and got the progress bar to stick. I don't know why that single change would cause this issue. I did the exact same movie under the default settings and it worked fine.
9th June 2009, 22:19 | #3183 | Link | |
MBK |
9th June 2009, 22:31 | #3184 | Link | |
9th June 2009, 23:07 | #3185 | Link |
Hi. I got a couple of questions:
1. How does BD-RB decide what bitrate to use on extras? I tried doing "the dark knight" in full backup mode, and I found that it used a 5000kbit/sec bitrate on a VC1 extra that was originally 10000kbit/sec, so that's 50% less. Is this normal? configurable? 2. Off-topic, does anyone know the exact size in bytes that can be written to a BD-R25? Thanks everyone, and jdobbs - keep up the good work! -purpleman2k |
10th June 2009, 00:17 | #3186 | Link |
All well and good....
But the issue remains, and it is a very real one. The original bluray in eac3to is shown correctly. The backup isn't, therefore something is wrong with the backup. eac3to likely does a much deeper (proper) analysis than tsmuxer. I haven't used bdinfo before to check although I am aware that tsmuxer reports no problem. Pretty weird. |
10th June 2009, 01:20 | #3188 | Link | |
One possibility: X264 will determine the playback rate from the frame server used. If your codec is reporting it incorrectly it may get passed through... I've never see it happen though, and I'm not even sure that it is possible. I can always force the framerate with --fps easy enough and will, but I have no confidence that it will have an effect. Last edited by jdobbs; 10th June 2009 at 01:49. |
10th June 2009, 01:26 | #3189 | Link | |
--aud is included in the BD-RB command line --fps shouldn't make a difference, but I can easily add it --keyint 250 is a violation of the BD and AVCHD standards. I'd say the Panasonic is the issue... |
10th June 2009, 01:35 | #3190 | Link | |
10th June 2009, 02:31 | #3191 | Link | |
Then I went into settings and changed the CUSTOM_TARGET_SIZE box to 8250, re-ran the Backup and it didn't stick. So basically, if I changed to TARGET_SIZE manually in the config file, it sticks. If I change the CUSTOM_TARGET_SIZE in the settings window (GUI) it works as it should. If I don't make any changes to the default settings for a movie only copy to BD9, it works normally. I don't know what this means, but I hope it helps. |
10th June 2009, 06:40 | #3193 | Link | |
10th June 2009, 07:31 | #3194 | Link | |
RE: Overall Progress STUCK= 50%
edited Config File-- SHOW_ENCODER=1 now encoding the International == Movie Only set Custom Target = 24300 (for BD25) Keep HD Audio Encoding process just went to PASS 2/2 both GUI Overall Progress & x264 DOS window show progress 50+% and counting so NOW it's working ?? |
10th June 2009, 08:31 | #3195 | Link | |
This time the progress bar kept updating after pass 2 commenced (current progress = 13.20% and overall progress = 56.60%). Previous the progress bar would stick at the end of pass 1 on 100% and 50% respectively. I'll try again with the original custom setting (TARGET_SIZE=8240) and see if the problem occurs again. |
10th June 2009, 10:46 | #3196 | Link |
No it doesn't error out, it keeps running and finishes. It may be the test clip I'm using which causes what you're seeing.
I'll do a movie-only of a actual Bluray with SHOW-ENCODER=1 set and see if it gets stuck @ 50%. I was thinking it might be what GaPony might be suspecting about the custom target size, however with that same setting the last encoding did not have the progress bar stuck. Anyways, I'll post the screenshot of the show encoder again when I do the Bluray.
MBK |
10th June 2009, 14:29 | #3198 | Link | |
I'm just going to go back to the original way I grabbed the window. Last edited by jdobbs; 10th June 2009 at 14:32. |
10th June 2009, 15:12 | #3199 | Link | ||
EDIT: I posted it in the H.264 forum. Quote:
Did you get around to removing --stats and --pass from crf encodes as well? Last edited by turbojet; 10th June 2009 at 16:44. |
