28th December 2008, 18:04 | #7562 | Link |
There is DTS audio track extracted from BD by using eac3to.
Info from eac3to: DTS, 5.1 channels, 1:59:41, 24 bits, 768kbps, 48khz Info from Delaycut: ====== INPUT FILE INFO ======================== File is dts Bitrate (kbit/s) 768 Act rate (kbit/s) 754.500 File size (bytes) 689363968 Channels mode C+L+R+SL+SR Sampling Frec 48000 Low Frec Effects LFE: Present Duration 02:01:49.359 Frame length (ms) 10.857522 Frames/second 92.102051 Num of frames 673207 Bytes per Frame 1024.0000 Size % Framesize 0 CRC present: NO ============================================= As consequence at attempt to connect this sound as external unsync appears. If to include it in mkv that everything is all right. What's wrong with this file and how this can be corrected? |
28th December 2008, 20:32 | #7564 | Link | |
Matroska find' ich toll
big thanks for your good work on it. please. dont change to nero9 (i dont like it and i wont install it anymore) nero7, the decoder works!! hubble |
28th December 2008, 20:54 | #7569 | Link | |
use 'r'
28th December 2008, 21:02 | #7570 | Link | |
How to fix header? Last edited by AnryV; 28th December 2008 at 21:07. |
28th December 2008, 21:05 | #7571 | Link | |
Can't see anything in the changelog that would make upgrading worthwhile to me. Last edited by madshi; 28th December 2008 at 21:07. |
28th December 2008, 22:08 | #7575 | Link |
use 'r'
Try DTSSource.ax filter maybe it helps you:
http://www.doom9.org/Soft21/Filters/test.rar |
28th December 2008, 22:40 | #7576 | Link | |
28th December 2008, 23:38 | #7578 | Link | |
hi Madshi,
just wondering if possible in a future update, can the audio edit function be used to insert silence for a +delay, rather than looping the audio at that point - would be superb if that could be done for at least AC3 and DTS specifically, this fn from 2.84 rel notes... Quote:
cheers and keep up the great work, m Last edited by magic144; 28th December 2008 at 23:41. |
29th December 2008, 02:27 | #7579 | Link | |
madshi, I was curious as to why there isn't support for .m2ts and .ts outputs? Demuxing video or simply creating an .mkv is great (from a blu-ray disc or whatnot), but sometimes creating a .m2ts or .ts is handy. Just a suggestion. Thanks for the great work thus far |
eac3to |
