29th January 2008, 02:49 | #221 | Link |
In bytes we trust
is mediainfo "compatible" with large files?
im having problems with large files, like 25gb. it "freezes" and looks like is reading the entire file, the hard disk light keep "on" the video is an avi file, dv codec, exported from sony vegas. with 13gb files, it take about 13 seconds to identify, but works. |
29th January 2008, 10:46 | #222 | Link | |
I will release a version today (0.7.5.8), please test it with the biggest AVI you have, this should be a lot quicker (lot of speed improvements), and give me your feedback. Zen, developper of MediaInfo.
Want to know all about your media files? http://mediaarea.net/MediaInfo |
4th February 2008, 22:45 | #223 | Link |
Swallowed in the Sea
@vlada: you want more ?
General #0 Complete name : D:\Tor_\Script ED new_h264.mkv Format : Matroska File size : 5.11 MiB PlayTime : 36s 959ms Bit rate : 1160 Kbps Encoded date : UTC 2008-01-23 20:13:57 Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video #0 Codec : AVC Codec/Family : AVC Codec/Info : Advanced Video Codec Codec profile : High@L5.1 Codec settings, CABAC : Yes PlayTime : 36s 920ms Bit rate : 1107 Kbps Width : 640 pixels Height : 336 pixels Display Aspect ratio : 1.905 Frame rate : 25.000 fps Chroma : 4:2:0 Interlacement : Progressive Writing library : x264 - core 57 svn-699C Encoding settings : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / fpel_cmp=sad / subme=7 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1177 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 |
6th February 2008, 01:15 | #224 | Link |
Just a little note about a misspelled codec name:
Video #0 Codec : WinNow Codec/Info : WinNow Videum Hardware Compression PlayTime : 9s Bit rate : 14 Mbps Width : 448 pixels Height : 336 pixels Display Aspect ratio : 4/3 Frame rate : 30.000 fps Resolution : 24 bits StreamSize : 15.0 MiB It's the WNV1 codec. |
6th February 2008, 07:50 | #225 | Link |
Found another typo:
(Quictime in the Format/Info line) Code:
General #0 Complete name : F:\DL\WGet\Game Trailers\quantic_video.mov Format : QuickTime Format/Info : Quictime movie Format/Family : MPEG-4 File size : 70.0 MiB PlayTime : 35s 35ms Bit rate : 17 Mbps StreamSize : 18.8 KiB Encoded date : UTC 2008-01-22 15:17:13 Tagged date : UTC 2008-01-22 15:21:21 |
6th February 2008, 11:49 | #226 | Link |
Ah... typos
Corrected, will be OK in next version.
6th February 2008, 18:19 | #228 | Link | |
(I am completly rewriting the GUI, for being cross-platform...)
6th February 2008, 20:28 | #229 | Link |
I also have a suggestion/request:
Could you make a simplified version of the GUI that is only capable of displaying the info as plain text output. No fancy options. Just a 'browse for file' button, a text field, and perhaps a copy-to-clipboard button. Preferably statically linked with the mediainfo lib, so that everything is in a single executable file.
MPC-HC 2.2.1 |
6th February 2008, 23:37 | #230 | Link | ||
- You configure MediaInfo for showing Text by default (in the main configuration window) - in Win Explorer, right clic on the file, "MediaInfo", and you have the text (I must put a button "copy to clipboard here...). Anyway, a guy wrote a tools which can be what you want: http://fileforum.betanews.com/detail.../1183386892/1/ (not supported by me) Quote:
I can't manage tens of versions with CLI/GUI/DLL, Windows/Linux/Mac, 32/64 bits...
7th February 2008, 01:18 | #231 | Link | |
7th February 2008, 12:06 | #232 | Link |
Thanks Atak_Snajpera, that is exactly what I had in mind. A simple and small tool that doesn't require installation.
MPC-HC 2.2.1 |
7th February 2008, 13:46 | #233 | Link |
Kurtnoise13
That's great. Many thanks. Also the consistency of video strem information in different containers is now much improved: Many thanks for your work. If I could have one more request: Would it be possible to display delay and stretch of audio in MKV? It is very important when converting such file. Last edited by vlada; 8th February 2008 at 11:57. |
8th February 2008, 09:24 | #234 | Link | |
Also, a way to change the font from hard to see grey to black would be good too. Oh, any chance to give it an argument? I'd like to be able for it to load a file by either commandline or creating a right click "MediaInfo" option. Other than that, I like its simpleness and speed. Last edited by Schrade; 8th February 2008 at 09:30. |
13th February 2008, 17:24 | #235 | Link | |
13th February 2008, 18:44 | #236 | Link |
Allowing to open a file through command line would be a useful addition. That would for example allow a user to open a file in MediaInfoRaw through a "Send to" shortcut.
Edit: typo
MPC-HC 2.2.1 Last edited by clsid; 13th February 2008 at 22:05. |
13th February 2008, 20:44 | #237 | Link |
Life's clearer in 4K UHD
Very good idea
13th February 2008, 22:11 | #238 | Link |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th February 2008 at 22:29. |
13th February 2008, 23:44 | #239 | Link | ||
Thanks for adding it. I'll definitely use it now. It's so speedy! Last edited by Schrade; 13th February 2008 at 23:51. |
13th February 2008, 23:59 | #240 | Link |
Thanks
Edit: A little request. Could you make the window a bit wider? 50% or so. Now some stuff is getting word wrapped.
MPC-HC 2.2.1 Last edited by clsid; 14th February 2008 at 00:58. |
