30th August 2006, 12:10 | #61 | Link |
The fish knows everything
...from what I understand that this filter is being made only for viewing and not for processing.
I' searching for a filter that helps with 'banding' when compressing! (in YV12 mostly)... any advice ? |
30th August 2006, 12:46 | #62 | Link |
Banding is best fought during post processing. Whatever method you'll try to use in preprocessing, it's more than likely that the effects will get lost during the compression, unless you're using a very high bitrate.
30th August 2006, 12:53 | #63 | Link |
@ Manao: it still helps however. And, most important, this filter doesn't reallly destroy details in picture.
I use this filter for HD content which I transcode to avc. I can't see more banding added compared with filtered but not yet encoded video. Maybe AVC has less chance to create banding, dunno |
30th August 2006, 12:56 | #64 | Link |
yes you're right..,
most of the time I get it when I'm compressing to much, but sometimes I get banding even when all i/p/b-frames are 2 and 3 quant. with(H263/MPEG)... so I guess in that case it's not about the bitrate... and I try to found out why and how to fix this/if I can . Thx 4 the reaply and Keep up the good work respect |
30th August 2006, 16:52 | #65 | Link | |
Posts: n/a
31st August 2006, 09:57 | #66 | Link | |
(but they wont look much like 2/3 quant) ...but when you're compressing at a 640x480 res. without using a denoiser, - costum matrix, or settings like 'lumi masking', trelis ... and others that can be helpfull with the compressabilyty , -without Bvop's or with but never higer than 1/1.0/1.0... etc. the bitate can't be so low... to go higher with the bitate it wouldn't be smart as it won't be much of a compression anymore... after all this way the clip is almost perfect: -no blocks -no artifacts -no mosquito noise -the only thing is the 'banding' I get (hoping to fix that to) anyway... I'm really sorry to post my question here, I didn't meen to mess much with the thread. 4 the replys |
18th September 2006, 21:35 | #68 | Link | |
x264 developer
The only way it will work is if the encoder and bitstream also use the higher colordepth, i.e. h264 hp. |
5th February 2008, 21:47 | #69 | Link |
Two examples of gradfun2db in action (preprocessing, but it has a very nice effect when banding is this visible, even after encoding):
http://xs124.xs.to/xs124/08062/gradfun2db558.png (this image is actually after a few scene changes from the last one) http://xs124.xs.to/xs124/08062/gradfun2db2838.png |
6th February 2008, 02:32 | #70 | Link |
Fighting spam with a fish
Here is a question, how do you deal with the color residue leftover after a debanding filter has been applied?
Sure, the hard edges have been removed, but often times there is still a soft band of color lingering in its wake. This only happens on some sources I know, mainly any with strong banding, but I am wondering how to deal with those select few. |
6th February 2008, 06:09 | #72 | Link |
So, say that I have gradfundb(1.4) and it removes the hardedges, but it leaves the color.
If I raise it to (1.5) or (1.6) and use AddGrain(), then that should take care of it? Wouldn't that hurt compressibility? Or is it negligible? |
8th February 2008, 17:04 | #75 | Link |
although i havent tried it, but this filter would work great to help hide decoding artifacts from Divx videos and as such to provide a much cleaner source which doesnt appear to have much compression in the video file, like MPEG 2 and lossless (to be prefered, as there isnt any).
24th March 2008, 04:34 | #76 | Link |
Hello. I am trying to figure out what to do to get rid of banding (actually almost everybody in this thread)..
So I have this after encoding (Banding is mainly visible in the sky) : What do you think I should try? Last edited by vaioslar; 24th March 2008 at 04:45. |
24th March 2008, 18:31 | #80 | Link | |
--->http://rapidshare.de/files/38916572/...muxed.rar.html Last edited by vaioslar; 24th March 2008 at 18:34. |
