19th January 2010, 20:20 | #21 | Link | ||||||||||||||||||
The button should be disabled until at least one track is added. This must be a bug, I will look into it. Quote:
Removing files by right clicking is unnecessary, select a parent check box and click the button. Again, double work is not needed. Quote:
19th January 2010, 20:37 | #24 | Link |
@sheck
the problems lies with mkvextract.exe not returning version info
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
19th January 2010, 21:07 | #27 | Link |
Instead of making a console output screenshot output can be redirected to a file, it works like this:
mkvinfo --version > aaa.txt In Win 7 you can directly redirect to the clipboard: mkvinfo --version | clip The text can then be posted. Posting a attachment needs approval which can take hours or longer so file hosters are better used instead, it's also easier on the forum database which stores everything, posts, big logfiles and pictures. I don't know if big posts, logfiles and attachments are an issue for the forum hosting. A file hoster is smart and deletes files not requested for some time. Filedropper or mediafire would be such file hosters.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 19th January 2010 at 21:16. |
19th January 2010, 23:56 | #29 | Link |
mkvmerge --version works with MKVToolNix 3.1.0
20th January 2010, 00:10 | #30 | Link |
Hmm, 3.1 version of mkvextract does not report version at all on my PC. This is weird. I'll have to change some code then.
@MuLTiTaSK Is that an unofficial build ? Where can I get more info on that version ? Last edited by sheck; 20th January 2010 at 00:18. |
20th January 2010, 00:54 | #32 | Link |
DVD Magistrate
no version of mkvextract gives me a version number...that is the issue. Why is it checked for anyway. Tried the V3.1 as well. It is the cause. How about not checking and just tell user at first run minimum versions are needed.
20th January 2010, 05:25 | #35 | Link |
V 0.3.0.0 Released
This version has some fixes:
* Extract button is disabled til mkvtoolnix path is correct and there is at least one file added. * MKVcleaver will only check if mkvextract.exe exists. No other checks done. * Remove button will only be enabled if one or more files are checked. * Path to mkvtoolnix is now stored in custom.ini file. No other settings are saved in this release. * Settings are not reset, if an error occurred or if the cancel button was pressed and no files were processed. In all other cases settings will be reset. To DO: * Fix Get Detailed Info context menu * Add ability to Maximize Everything else will be added by majority requests. Last edited by sheck; 20th January 2010 at 05:34. |
22nd January 2010, 06:19 | #36 | Link |
@sheck
Hi! This tool is impressive in its deceptive simplicity. Have I missed something? Why is it that when extracting PSG subtitles, the resultant file is given an extension of ".unknown", rather than the typical ".SUP" - and doesn't include the language name in the title? Last edited by setarip_old; 22nd January 2010 at 08:03. |
22nd January 2010, 19:33 | #37 | Link | |
In any case, open cmd and run this command mkvmerge -i "mkv file" It will tell you which codec is used for PSG subtitles. Open custom.ini and add that codec and extension as described in help file. Next time MKVcleaver will add the custom extension you assigned to it. You can do it with any codec that is detected as unknown. As for the language code, it's because a lot of files don't have language codes set and so MKVcleaver doesn't add language to the file name. It goes by track # and track type for 100% compatibility with all files. Last edited by sheck; 22nd January 2010 at 22:38. |
22nd January 2010, 21:50 | #38 | Link |
Thanks for the insight regarding commandline mkvmerge.
Regarding adding the Language name to the extracted stream title - Can't you adjust your program to pick it up if it appears in the left pane - and only use ".unknown" for those PGS streams that don't? BTW - Dyslexia or old age (or both) - Of course I meant "PGS" and not "PSG" ;>} |
22nd January 2010, 21:59 | #39 | Link | |
I could be missing why you want this function. Maybe if you explain in detail what exactly you want, I could reconsider. EDIT: I will add that if a lot of people would like languages in the file names. Last edited by sheck; 23rd January 2010 at 04:34. Reason: EDIT: |
batch extract, extractor, matroska, mkv, mkv batch, mkv decoder, mkvextract |
