17th September 2010, 14:56 | #12401 | Link |
Audio & video enthusiast
Here are some pics from sample 2 when I play it using DXVA.
I have marked the artefacts in pictures. When I play it using software decoding there are no artefact at all, I think that problem is that my HD4200 just doesn't have enough power to decode 1080i material, this one is my first and only interlaced video at moment. Last edited by NiFa; 17th September 2010 at 15:13. |
17th September 2010, 16:00 | #12402 | Link | ||
4:2:0 hater
17th September 2010, 16:12 | #12403 | Link |
It did, next version of LAVFSplitter will support multi-channel raw PCM tracks, thanks!
Doesn't even need a audio decoder when your hardware directly supports the format. Needs a filter when you, for example, want to play a 5.1 track on stereo hardware. But ffdshow with raw audio input enabled can do the job of down-mixing it. Edit: Actually, i lied. I just found a 7.1 PCM track, and my dev system is only setup for 5.1 through a AC3 encoded SPDIF link, and it still plays just fine without any filter. Although i'm not sure if the DD-Live encoding didn't somehow accept 7.1 while a standard sound renderer wouldn't, oh well.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 17th September 2010 at 16:28. |
17th September 2010, 16:31 | #12404 | Link | |
I shall indeed. Before I started playing with madVR I was using EVR CP. I was playing with EVR Sync trying to match your config to get subs working before you told me what the issue was and forgot to set it back. It does look really good. I'm gonna have to sit and do some comparisons when I get a chance.
17th September 2010, 16:32 | #12405 | Link | |
17th September 2010, 20:35 | #12406 | Link |
Hi guys,
would somebody please comment on this issue I've posted a few days ago? http://sourceforge.net/tracker/?func...41&atid=867360 I would like to know whether it's really ffdshow bug, or whether it's just a mistake on my side that can be fixed? Thanks a lot. |
18th September 2010, 02:44 | #12407 | Link | |||
Unavailable
18th September 2010, 14:40 | #12408 | Link |
4:2:0 hater
@devs
Have you considered removing some deinterlacers, more specifically kernelDeint, DGBob and TomsMoComp? These are barely faster than Yadif (at least on my system), provide less quality (IMO) and I don't know of anybody that actually uses them inside ffdshow. Same with realaac, it's not even listed as an available filter. |
18th September 2010, 18:27 | #12410 | Link |
ffdshow doesn't seem to like a 6.1 FLAC stream I have in one of my mkv's, using ffdshow to decode and when using madFlac.
Sample: http://www.mediafire.com/?1dpylzi343f3otc ffdshow revision 3357. Last edited by DJ_Phatic; 18th September 2010 at 18:45. |
19th September 2010, 00:00 | #12411 | Link |
war59312.com
ffdshow build 3576 (x86 and x64) is refusing to save its directshow merit level.
I cant get WMP to use ffdshow for x264 .avi files for the life of me. Update: ok have to run config as admin, always been the case ? OK but on very high and wmp still is not using ffdshow.. Ok got that working using Win7DSFilterTweaker by disabling media foundation, too bad that breaks thumbnails though... Last edited by war59312; 19th September 2010 at 00:27. |
19th September 2010, 13:47 | #12412 | Link | ||
19th September 2010, 19:32 | #12413 | Link |
4:2:0 hater
Done.
To all, I've successfully enabled libavcodec's AAC decoder again. It has decoded everything I've thrown at it, LC, HE v1 and HE v2. Please test and report any issues! Build: http://www.mediafire.com/?z83xtyw4xay6l7f |
19th September 2010, 19:56 | #12414 | Link |
I can confirm it plays back all of my samples, and those which are unsupported by libfaad2! What are the downsides of ffmpeg's aac decoder? If there aren't any maybe libfaad should be removed.
19th September 2010, 20:29 | #12415 | Link |
4:2:0 hater
16-bit integer output instead of 32-bit floating point in libfaad2. I guess some audio purists will be against removing it even if it plays things libfaad2 can't play.
Oh I've found something it doesn't decode, AAC-LTP. Nobody uses this, but still. Last edited by STaRGaZeR; 19th September 2010 at 20:33. |
19th September 2010, 20:55 | #12416 | Link |
Why are we so eager to remove things? Choice is a good thing.
Is libfaad holding ffdshow development in any way back? Does it take too long to compile, does it need hacks to get it working etc.? FYI, there's a feature list of ffmpeg's AAC decoder in aacdec.c. |
19th September 2010, 21:18 | #12417 | Link |
4:2:0 hater
Why keep two decoders when one of them does at least the same as the other? Useless waste of time, space, etc. This isn't the case here, but that's the reason.
I see LTP is a SoC project, good to know |
19th September 2010, 21:20 | #12418 | Link |
removing options may be good
well.
put it like this: I play interlaced material with ffdshow maybe four times a year. In case i do, i want highest possible quality. Activating deinterlacing is the one thing, CHOOSING a proper Deinterlacer is another. YOU HAVE TWELVE DIFFERENT DEINTERLACING OPTIONS IN THERE. Thatīs the first time I get an advice which Deinterlacer to use (Yadif). Actually, two Deinterlacers are enough: one which fits most users - giving best quality. And maybe one with special options, for example the one which is allowing 50fps output. Well, you know, maybe just give some sort of speed/quality ranking in the help annotations might be enough. Like the ones for the sharpening algorithms. They are perfectly, even if the best methods like asharpen are not explained at all ... *roll eyes* Would be perfect if a deinterlace insider writes some descriptions explaining what is the difference between these Deinterlacers. So, MANY users will just select a deinterlacer by chance. makes no sense. Mabye ask the authors of the deinterlacers to write a short description. If they donīt react, maybe hide these deinterlacers in some sort of special/advanced option field. So, yeah, I donīt know every deinterlacer. so just remove the ones which are "bad"/"not so good", or at least mark the recommended deinterlacers and explain why they are recommended. this would make ... sense :-) Xergon Last edited by xergon; 19th September 2010 at 21:28. |
19th September 2010, 21:27 | #12419 | Link | |
If our goal is to be as close to the ffmpeg source as possible, then there's a lot more to strip out of ffdshow than libfaad. We should wait for more input on this matter from the other devs. By the way, nice work with the AAC integration! Now give deband to the 64-bit folks |
