12th January 2014, 22:35 | #12581 | Link |
Oh my.. hundreds of pages dating back six years or more? How will I ever find what I need?
I hope you'll all excuse me for perhaps asking an already answered question, but the amount of posts here is staggering and just too much to siff through. My query: I want to convert 7.1 TrueHD to 7.1 DTS-MA or even 5.1 DTS if need be. I have access to the DTS suite and a bunch of other codec packs (all legit), but am not very knowledgable beyond ye'r basic Handbrake... Anyone care to take my hand? Pretty please? How about a shove in the right direction, coupled with some strong hints...? |
15th January 2014, 11:54 | #12583 | Link |
I am trying to demux 2D video track from 3D BluRay disc (that disc contains both 2D and 3D movie versions, i.e. there are options "Play 2D" and "Play 3D" in disc menu when I am running TotalMedia Theater).
This is what I am getting when listing disc info with eac3to: http://pastebin.com/BbJEWyQP How do I find out which .mpls file refers to 2D version of the movie? |
16th January 2014, 07:28 | #12586 | Link |
47.952fps@71.928Hz
It is the Left-Eye stream that's only 2D. It's presented in AVC/H264 while the Right-Eye (the 3D data; difference) is presented in MVC.
For 3D Blu-ray discs, most MPLS will present everything in 3D fashion. As long as everything is transferred to 3D. Some discs have all the special features and trailers transferred to 3D (AVC/MVC) while some will only have the main movie in 3D (AVC/MVC). But, generally, if you're selecting by MPLS, you can just run the .MPLS through eac3to to get the information of how it's read. Reading from a playlist file (MPLS) is different from reading from an actual file (M2TS/MKV/etc). Through MPLS, you don't get numbers in front of the stream, instead you just get hyphens ("-") and have to count which stream(s) you want to use. In case of 3D blu-rays, skip over the "right-eye" data and use only the Left-eye data (AVC/H264). This will give you 2D data, every time. I believe the only software that gives you a 3D.mkv file (with AVC/MVC) is MakeMKV. But, even then, all media players will only decode/play the 2D (Left-eye) data unless they are specifically designed for 3D playback (3dat.tv's StereoScopic Player; Bino; etc). If you're playing back from a Blu-ray player that has file playback file system, it's very unlikely that it supports MVC at all so it will either A) playback as 2D or B) not play at all. The best thing to do is grab the smallest file possible (like a trailer) and test it with your playback system. MPC (and other variations), VLC, and most other media players don't support MVC playback.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
16th January 2014, 16:00 | #12587 | Link |
Can eac3to combine 6 separate mono WAV files into a 5.1 WAV file? I've tried doing it with other software but I haven't found a way to get it working properly. Adobe Audition 3.0 reduces the volume of each track for no apparent reason, Adobe Audition CS6 raises the volume of each track for no reason.
EDIT: Never mind, managed to do with using SoX.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 Last edited by DragonQ; 16th January 2014 at 16:41. |
17th January 2014, 12:52 | #12589 | Link |
Trying to convert many audio files in a folder mainly same format to output as wav files. Where any typing needed is minimal than is required now with eac3to such as eac3to "input" "output" "input" "output" "input" "output" "input" "output" etc Ways to make this task easier as like other software's do it.
eac3to converting using cli by dropping a folder that contains music files only. eac3to "drive\folder path" "drive\folder path" -wav Or input as a text.txt file each audio file on a separate line. "drive:\folder path\A audio file.ext" "drive:\folder path\An audio file.ext" "drive:\folder path\Again Another audio file.ext" "drive:\folder path\Another audio file.ext" eac3to "drive:\folder path\text file to process.txt" "drive:\folder path\" -wav All of the above be able to convert many source audio files to wav files. Where bitrate, kHz, channels etc remain exactly the same as the source. For eac3to to append source file name to each destination file for each file with a replaced .wav extension Last edited by Nexin; 17th January 2014 at 13:27. |
17th January 2014, 13:29 | #12590 | Link |
Audio File/s or other eac3to known format output to filename.txt
I'm also needing a way to generate a report to a filename.txt file. So far I have tried eac3to "drive:\folder path\file name.ext" >"drive:\folder path\file name.txt" where the outputs has non ascii\unicode characters such as many boxes before file details. If could do this using cli for eac3to to parse a folder of many audio files. Need report to have same info as see with eac3to "drive:\folder path\file name.ext" All of the above stumbles when drop a folder to cli with "HD DVD / Blu-Ray Disc Structure not found" a way to overcome so can work with folder or folders that contain many audio files. eac3to because it is the only software that can clearly see whole dts mlp ma more than any other software's including foobar2000 and mediainfo for audio files. Although sometimes foobar2000 will see 5.1 audio where eac3to will see only 2.0 same again in reverse eac3to will where foobar2000 won't using latest releases for eac3to and foobar2000 with win xp sp3 Last edited by Nexin; 17th January 2014 at 13:33. |
18th January 2014, 08:13 | #12591 | Link |
Has this project ended ? Madshi first post of this thread last edited the start of last year ''Last edited by madshi; 20th January 2013 at 17:44''
Anyone have idea how better to do the two above posts. With eac3to or other tools for the same formats as straight conversions |
18th January 2014, 08:30 | #12592 | Link |
47.952fps@71.928Hz
No, Madshi said he's focusing his energy on madVR for now (until it reaches a 1.0 version) and then will return to this project.
------- Have you tried a batch file? (From an example provided with SoX...) eac3to_batch.bat Code:
@echo off %~dp1 CD %~dp1 FOR %%A IN (*.dts) DO "C:\eac3to\eac3to.exe" "%%~nxA" "%%~nA.wav" -log="%%~nA_WAV.txt" I'm not entirely sure how to do an advanced batch file that includes multiple extensions. Someone more crafty can chime in. In case of Matroska containers use (*.mkv) and add the stream number after the "%%~nxA" or leave out the stream number if it's the first audio stream you wish to convert. Code:
@echo off %~dp1 CD %~dp1 FOR %%A IN (*.mkv) DO "C:\eac3to\eac3to.exe" "%%~nxA" 2: "%%~nA.wav" -log="%%~nA_WAV.txt" Code:
@echo off %~dp1 CD %~dp1 FOR %%A IN (*.mkv) DO "C:\eac3to\eac3to.exe" "%%~nxA" 2: "%%~nA.wav" -downStereo -log="%%~nA_WAV.txt" Code:
@echo off %~dp1 CD %~dp1 FOR %%A IN (*.mkv) DO "C:\eac3to\eac3to.exe" "%%~nxA" 2: "%%~nA.wav" -log="%%~nA_WAV.txt" FOR %%A IN (*.dts) DO "C:\eac3to\eac3to.exe" "%%~nxA" "%%~nA.wav" -log="%%~nA_WAV.txt" FOR %%A IN (*.ac3) DO "C:\eac3to\eac3to.exe" "%%~nxA" "%%~nA.wav" -log="%%~nA_WAV.txt"
18th January 2014, 08:53 | #12593 | Link |
Maybe Madshi when returns to the project may make it better with more options. Maybe things like use surcode as decoder if better than ffmpeg for mlp etc. Ability to see AOB as files and disc with AOB files parse from .ifo or .bup for chapters. DVD parsing, folder parsing for any audio format file that eac3to can work with. As you say using sox maybe eac3to could work with that more, I didn't think of sox until you mentioned it.
Thanks Sparktank your solution on reading seems it may work for any multiple files from folders and otherwise. Also be able to pipe the source file names to destination files which is needed and again for making log files. Sure if someone has other scripts to improve or better yours then I'm ready to try those also |
19th January 2014, 15:27 | #12594 | Link |
@if "%EMode%"=="" Set EMode=OFF @ECHO %EMode% if "!"=="" ( SETLOCAL DISABLEDELAYEDEXPANSION Set "DISLOC=1" ) Set "EXTLIST=*.mkv *.dts *.ac3 *.mka" goto :Skip :Process_File "d:\eac3to\eac3to.exe" "%~nx1" "%~n1.wav" -log="%~n1_WAV.txt" goto :eof :Skip if [%1]==[] ( Set "Pattern=%EXTLIST%" CALL :START ) :ARGS if [%1]==[] ( Set "Pattern=" Set "EXTLIST=" if NOT "%DISLOC%"=="" ( Set "DISLOC=" ENDLOCAL ) pause goto :eof ) if NOT EXIST %1 ( SHIFT goto :ARGS ) if /I "%~f1"=="%CD%" ( Set "Pattern=%EXTLIST%" CALL :START SHIFT goto :ARGS ) Type NUL pushd "%~f1" 2> nul if NOT "%errorlevel%"=="0" ( if /I NOT "%CD%\"=="%~dp1" ( pushd "%~dp1" Set "DoPop=1" ) Set Pattern="%~nx1" ) else ( Set "Pattern=%EXTLIST%" ) CALL :START if "%DoPop%"=="1" ( popd Set "DoPop=" ) SHIFT goto :ARGS :START for %%y in (%Pattern%) do ( CALL :Process_File "%%~fy" ) goto :eof Last edited by ndjamena; 20th January 2014 at 02:12. |
20th January 2014, 16:47 | #12595 | Link |
Is it necessary to use an external decoder to convert DTS to AC3 ? Is a better quality with an external decoder ? I would like to extract DTS core from DTS-HD MA or HR in order to have a DTS stream and convert it to AC3. Thanks ! |
21st January 2014, 09:08 | #12600 | Link |
Core DTS can support 6.1 with the DTS-ES extension, although its usually only used if you have no DTS-HD, and eac3to should be able to decode it as 6.1 as well.
I have never seen 7.1 in core DTS.
eac3to |
