Old 25th February 2017, 22:45   #4821  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by NikosD View Post
x264 is a lot different than x265 due to AVX2 optimizations.
Yes, I agree that using x264 RyZen is going to have a party.
But x265 has a lot of AVX2 optimizations and it's not possible for RyZen 7 to catch the performance of an Intel 8C/16T.
Rysen seem to have really good AVX/AVX2 implementation too ... Almost as good as Kaby lake
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 25th February 2017, 22:46   #4822  |  Link
NikosD
I certainly don't believe that.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 26th February 2017, 00:02   #4823  |  Link
nevcairiel
Even AMD documentation says that AVX/AVX2 is implemented using 128-bit processing units (and not 256-bit), so they have about half the throughput as Intel - which would have quite a strong impact on x265 performance.
Anyway, we'll see actual believable results in a week or so, not "leaked" results or AMD marketing results.
Old 26th February 2017, 00:08   #4824  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
March the 2nd is really close, it's just four days from now. I guess we can all stop and wait for the official benchmarks. Also, there are rumors that AMD has already shipped a million Ryzen CPUs so we'll have a lot of data to chew on.
birdie is offline   Reply With Quote
Old 26th February 2017, 00:10   #4825  |  Link
LigH
LigH's Avatar
I'll be curious too. AMD used to be "notorious" for well optimized die designs vs. "brute force" preferred by intel. And even if RyZen is not as powerful as people may hope for, we still have to thank AMD for pushing intel (and Nvidia?) back to a solid ground, regarding price management ... — Thanks birdie for the link a page ago.
New German Gleitz board
Old 26th February 2017, 00:45   #4826  |  Link
pingfr
Anyone could take a quick peek at these settings and tell me if I'm missing a tweak here and there, thanks?
C:\x26x>x265.exe --crf 18 --aq-mode 1 --ctu 64 --qg-size 32 --deblock -1:-1 --me star --bframes 6 --rc-lookahead 60 --ref 5 --b-adapt 2 --tu-intra-depth 4 --tu-inter-depth 4 --merange 92 --weightp --weightb --scenecut 40 --rd 4 --limit-ref 0 --limit-modes --tskip --rect --amp --max-merge 5 --subme 7 --b-intra source.y4m -o out.hevc
Thanks!
Edit: Also what about --cutree ?
pingfr is offline   Reply With Quote
Old 26th February 2017, 03:08   #4827  |  Link
aymanalz
Thanks!
merange 92 is insanely high. What is the video resolution?
aymanalz is offline   Reply With Quote
Old 26th February 2017, 07:18   #4828  |  Link
divxmaster
Thanks!
I would add
--rskip --no-sao --no-open-gop
and I prefer
--psy-rdoq 1.1
Cheers,
Divxmaster
divxmaster is offline   Reply With Quote
Old 26th February 2017, 07:29   #4829  |  Link
troica
Hello guys is this x265 and HM reference model the same?
troica is offline   Reply With Quote
Old 26th February 2017, 08:11   #4830  |  Link
Selur
Selur's Avatar
they both implement the same standard, but x265 has lot of optimizations.
HM = example on how it could be done for academic purposes
x265 = real world implementation which is a lot faster and usable
Old 26th February 2017, 08:59   #4831  |  Link
WhatZit
I'm constantly amazed why people keep pursing gigantic strings of parameters to try and solve a problem that's already been solved.
--tune grain, along with its built-in rc-grain algorithm, fundamentally changes the encoding decisions x265 makes by weighting towards quality over compression (aka high-frequency retention).
The settings contained in these presets...
...retain more detail the slower you go. So much so that you can easily drop your non-grain CRF's BACK one or two notches at the slower presets.
I suspect that most people who don't understand tunegrain have just left the rest of their options at "veryslow CRF18" when "slow CRF20" would probably produce comparable visual quality, faster encodes and smaller filesizes.
This is my current command line, which replaced something 20+ parameters long:
--profile main10 --tune grain --deblock=-6:-6 --no-strong-intra-smoothing
Note that I haven't included the CRF or preset? That's because preset+CRF is ALL I change to adjust speed/filesize whilst still retaining quality for ANY encode, depending on the source.
Now, I'll admit that tunegrain could still undergo some tweaks for speed, and others have suggested the parameters to do that. Myself, I couldn't be happier about ditching the pursuit of endless quality experiments with this-command-line and that-command-line.
WhatZit is offline   Reply With Quote
Old 26th February 2017, 09:07   #4832  |  Link
troica
Are they both programmable using visual studios? My thesis is about wireless video transmission using HEVC with HM, but I dont really know how to start using visual studios
Old 26th February 2017, 09:11   #4833  |  Link
Selur
Selur's Avatar
not sure what you understand under 'programmable', but both can be compiled with MSVC and iirc both have an API and can be compiled as libraries.
-> no clue how to best start
Old 26th February 2017, 09:54   #4834  |  Link
troica
Thanks. I wanted to do generate a log file using HM model that takes the difference in the SNR, quantization parameter etc per frame, ctu, and slice number. Is there such a thing, or should I code manually to do such thing?
Old 26th February 2017, 11:12   #4835  |  Link
Boulder
Pig on the wing
Boulder's Avatar
This. What I've done is choose --preset slower --tune grain --CRF 21 as the baseline, then picked some recommended settings to tune performance (--limit-refs 3 --limit-tu 3 --rskip) and some quality-related ones from the bottom two presets (--tu-inter-depth 4 --tu-intra-depth 4 --max-merge 4). Produces 10-30% smaller files than x264 with my preferred settings at CRF 18, and seems to keep detail better.
Old 26th February 2017, 12:11   #4836  |  Link
pingfr
1920x1080.
Old 26th February 2017, 12:15   #4837  |  Link
pingfr
Originally Posted by divxmaster View Post
I would add
and I prefer
--psy-rdoq 1.1
I suppose --rskip stands for the "recursion skip", however both veryslow and placebo presets have the value set at 0. I suppose that means they are kind of --no-rskip?
Also I would assume --no-sao disables SAO setting it to 0, whereas every preset excepted for ultrafast and superfast have the value set to 1, makes me to actually WANT the SAO.
Now can some kind soul explain what is the rdoq-level? why is it set at 2 and how to make sure to keep it set at 2 from the command line args?
Old 26th February 2017, 12:35   #4838  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
@pingfr
you don't want SAO. It blurs things so if you want to preserve detail as much as possible, disable it and disable strong-intra-smoothing as well
Old 26th February 2017, 12:38   #4839  |  Link
pingfr
@froggy1: Noted. Any idea why the "best presets" have it enabled then?
Old 26th February 2017, 12:40   #4840  |  Link
microchip8
microchip8's Avatar
The presets of x265 are optimized for (very) low bitrate where at those levels, blur is preferred over other compression artifacts. That's why most have SAO and intra smoothing enabled. Also the x265 presets haven't been optimized in a long time. If you want to squeeze out as much detail as possible, you'll need to tweak manually (IMHO)
