25th June 2018, 12:25 | #5461 | Link |
Perfect, thanks - is that the latest build from
https://sourceforge.net/projects/mpc...vn%20trunk%29/ (24th May) or https://yadi.sk/d/hlf1lfC8mKU58/!_last (25th June) |
25th June 2018, 13:13 | #5462 | Link |
Last SVN - on yadi.sk
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
25th June 2018, 13:27 | #5463 | Link |
Wonderful, thank you so much. I notice a small difference in this version, in that the audio buffer can be set - default, 50ms, or 100ms. It is set at 50ms, is that the correct setting, or should it be 'default' or 100ms? What does this setting do? Thanks again.
25th June 2018, 17:35 | #5464 | Link |
@iSeries
If there are no problems, then do not change anything (standard value is 50 ms).
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
27th June 2018, 11:11 | #5465 | Link |
Hi, is there any way to turn the top menu bar black without skinning windows 10?, I have an oled TV and i'm trying to minimise bright areas on menus and stuff. I know I can remove this but I prefer the menu bar to be there permanently.
27th June 2018, 13:58 | #5466 | Link |
mclingo
Black menu not implement yet, sorry.
3rd July 2018, 15:43 | #5467 | Link |
After reinstalling Windows and all my other programs on Windows 10 Pro (64-bit), MPC-BE's audio level is too low. I tried changing some setting in Audio options, but with no success. Is there a setting that I could adjust to fix this?
3rd July 2018, 16:28 | #5468 | Link |
I need more information:
1.) Everytime I reinstall windows, the volume in the taskbar is set to 67. Did you already put that to 100? -> In case of powered external speakers or AVR with passive speakers. If built in speakers in Notebook, the speaker will be very loud ;-) 2.) How are the speakers connected? External speakers with analog 3,5 mm plug or digital like SPDIF Toslink, ... maybe AVR with passive speakers OR built in speakers in Notebook or built in speakers in monitor and connected with HDMI? 3.) Is only MPC-BE audio level too low or also other players you may have, don't install any other just for testing, just try built in WMP. What audio renderer/settings do you use? |
3rd July 2018, 17:13 | #5469 | Link | |
@Zinglar
Stereo tracks or 5.1? Quote:
If the first, then you have a problem not related to the player.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 3rd July 2018 at 18:31. |
4th July 2018, 04:25 | #5470 | Link |
MPC-BE 1.5.2 (build 3788) beta with a digital signature.
4th July 2018, 15:49 | #5472 | Link |
Hi, sorry for being late in replying. After reinstalling Windows I set the volume in the taskbar to 50 which is what I had before the reinstallation. The speakers are external with 3.5 mm plug connections. I tried to play a video on another software and the audio was much higher there. Anyway, before reinstalling Windows the audio level with MPc-BE was pretty good.
@EncodedMango, I tried the Loudness Equalisation and there is a big improvement. Thanks everyone for your assistance! |
4th July 2018, 16:37 | #5473 | Link |
Timestamps are not accurate as shown in ctrl + G.
I read presentation times of both audio and video stream in packet by ffprobe. Some video stream have a 100 millisecond offset but mpc-be always shows time zero for the first frame. |
4th July 2018, 22:59 | #5474 | Link |
Upload sample.
7th July 2018, 15:10 | #5475 | Link |
Soul Seeker
My brother has a problem with mpc-be, the keys are working before going in fullscreen, after that he has to click with the mouse, so they can start working again. Video renderer is madvr, tried with any other renderer same problem
7th July 2018, 22:02 | #5477 | Link |
I have been using the MPC-BE v1.5.2 (build 3656) on my laptop without any issues. I have recently updated to the latest version and the laptop crashes with a BSOD. I’d like to know what has been majorly changed in the new visions to cause my laptop to crash. BSOD crash info: Caused by driver--dxgkrnl.sys (DirectX Graphics Kernel) System specs: Windows 10_x64 Core i5-2540M Intel HD Graphics 3000--latest drivers available for win10x64 directx_Jun2010_redist--installed I have tried few new Nightly Builds without a success. It seems like something has changed in the new builds which is specific to my laptop. Please help me to troubleshoot this. Thank you guys! |
7th July 2018, 22:31 | #5480 | Link |
Do you use any external filters like madvr or lav filters? If so, did you update any of them in the meantime.
Worth a try to reset settings and set it up new. I have also a little Intel HD based PC here. I test my hd4600 tomorrow, already late here in bavaria. |
