22nd January 2012, 19:12 | #201 | Link |
契約者
Thank you! Now that I know everything works, I can think about rendering some of my projects in 16 bits. However I'm still searching of some way to open image sequence directly. Intermediate transcoding to yuv444p16le really eats my time and space. Its like 2.4 size of the source sequence (which is not that small by itself).
23rd January 2012, 03:54 | #202 | Link | |
f3kdb 1.5.1 / MP_Pipeline 0.18 ffms2 builds with 10bit output hack: libav-9a60b1f / ffmpeg-1e4d049 / FFmbc-0.7.1 Built from ffms2 6e0d654 (hack a9fe004) Mirrors: http://bit.ly/19TwDD3 |
23rd January 2012, 09:00 | #203 | Link | |
契約者
There is hacked version of ffms2 that can load 16bit stuff into avisynth but it doesn't supports 4:4:4 subsampling and i was able to open only 1 image, not sequence. |
23rd January 2012, 14:53 | #205 | Link | |
23rd January 2012, 16:24 | #206 | Link |
契約者
This would be so awesome to have this kind of plugin! Will look forward to it. In the meantime I'll try to convert my current project into yuv444p16le...
I usually work with image sequences because this is the most convenient format due to various reasons and it is easy to re-render some part of he project where I made some change. There can be some other options, especially on Mac (like Prores4444) but I'm a windows user and so far don't even see a way to render into raw 16bit stream directly... (the only real option is 4:2:2 10bit, but instead of it I better chose 4:4:4 8bit). Last edited by Keiyakusha; 23rd January 2012 at 16:26. |
12th March 2012, 14:24 | #207 | Link |
Released 1.5.0. This version doesn't have any new feature, just changed some parameters to reduce confusion based on user feedback.
12th March 2012, 14:35 | #208 | Link | |
Thx for the new version. From the readme on dither_algo:
13th March 2012, 01:39 | #209 | Link | |
EDIT: Just updated the online documentation.
f3kdb 1.5.1 / MP_Pipeline 0.18 ffms2 builds with 10bit output hack: libav-9a60b1f / ffmpeg-1e4d049 / FFmbc-0.7.1 Built from ffms2 6e0d654 (hack a9fe004) Mirrors: http://bit.ly/19TwDD3 Last edited by SAPikachu; 13th March 2012 at 14:13. |
29th March 2012, 21:37 | #210 | Link |
Can anyone give me an example of how to correctly pipe 10 bit 4:2:2 to x264-10bit?
I tried Code:
ffvideosource("source.mkv") ConvertToYUY2() # (or YV16) f3kdb(output_mode=2, output_depth=10) avs2pipemod -rawvideo source.avs | x264-10bit - --demuxer raw --input-depth 10 --input-res 1280x720 --input-csp i422 (or YV16) --output-csp i422 -o output.h264 Either the complete picture or just the colors are messed up. |
30th March 2012, 02:30 | #211 | Link | |
19th April 2012, 13:17 | #215 | Link |
mp3dom, thank you for the answer, but my problem remains. With correct offset i have good 1st frame (for 16-bit I disabled dithering):
but other frames (both 8-bit and 16-bit) are messed up and shifted. 2-nd frame: Maybe, I'm doing something wrong with readv210, but I cann't realize what. I guess, it's something with offset. Script: Code:
ReadV210("I:\Test\v210_720p.mov",36,1280,720) In addition, I have not problem with coff3.mov from example. Why??? (((( Last edited by Chyrka; 19th April 2012 at 16:53. |
15th June 2012, 05:40 | #218 | Link |
契約者
I have a question regarding readv210 too. What output should i expect see when i use it? For example if I use readv210("coff3.mov", 1103, 176, 144) or different command for opening my own file readv210("comp.mov", 48, 1280, 720) i see perfectly fine YV16 video... but i kind of expected to see stacked image... And mine is probably just MSB part. Any tips?
Edit: wow i found f3kdb_dither(stacked=true) in the script, after commenting it, it seems i'm getting what i expected... probably i need to sleep more... Last edited by Keiyakusha; 15th June 2012 at 06:24. |
1st November 2012, 10:33 | #220 | Link |
precision_mode is renamed to dither_algo in 1.5.0.
avisynth, deband |
