2nd March 2014, 15:36 | #201 | Link |
For the two clips you mentioned. Benchmarked with DXVAChecker 3.0.1 in EVR renderless mode, on my HD4600
Cat: LAV DXVA2-Native: 981 fps MS DS: 960 fps Vortex: LAV DXVA2-Native: 410 fps MS DS: 372 fps Important to note is that the MS DS decoder seems to generally have at least twice as much CPU usage according to DXVA Checker. Of course all VPP options are disabled, I double checked just in case.
2nd March 2014, 15:38 | #202 | Link |
No.
Not EVR renderless, in EVR option.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
2nd March 2014, 15:45 | #203 | Link |
That only brings the results closer together
Cat: LAV 783 fps, MS DS 778 fps Vortex: LAV 291 fps, MS DS 290 fps Note that I run every file 6 times, then take the average from the last 5 runs (ignoring the first, since it always varies a lot)
2nd March 2014, 19:05 | #204 | Link |
I've also tested the two clips, in nevcairiel's method - 6 times for each and abandon the first time.
OS: Windows 8 Graphic: HD4000 Render: EVR Mode: DXVA2 Native LAVFilters: latest nightly DXVA Checker : 3.0.1 Cat: LAV : 256.4fps 9% MS DS : 262fps 12.4% Vortexx: LAV : 180.6fps 11.2% MS DS : 157.4fps 17.6% Hmm...I got a result different from both of you If you would like to see results of MPC-BE and ArcSoft, see the detailed material here. |
2nd March 2014, 19:11 | #205 | Link |
Your results are too low for both clips, for both decoders and for HD 4000.
I'm pretty sure you haven't disabled all VPP functions in Intel's control panel.
2nd March 2014, 19:21 | #206 | Link |
I checked it before testing and made sure the options you mentioned is set all right.
I think maybe it's the driver problem. I've tried many times to update the Intel graphic driver but all failed with BSOD or black screen... hence I have to use the old oem driver plubished in June 2012. I'm going to update to Windows 8.1 and try again if the new driver works properly. Last edited by qtwebkit; 2nd March 2014 at 19:26. |
2nd March 2014, 19:26 | #207 | Link |
OEM driver from 2012?
You have to update it ASAP. Maybe it's time for a format or even better a Win 8.1 upgrade. The progress is great between those 2012 drivers and the nowadays drivers.
2nd March 2014, 19:32 | #208 | Link |
Yes, I'll handle it immediatly. As soon as I finnish, I will test again and post my result, maybe tomorrow.
Things become more complicated as I upgrade to Windows 8.1. The performance seems benifit little from the new driver(Jan 28,2014), about 277fps for in Cat and 180fps in Vortexx for LAV, merely no improvement in Vortexx. I've just found something else maybe ralated to this weird problem. I try to run the decoders with EVR Renderless, the result is much closer to nevcairiel's. Cat: LAV : 677fps MS DS : 682fps Vortexx LAV : 297fps MS DS :253fps But EVR Renderless shows nothing but a black screen during benchmark, while EVR will show video but end up with a very low score Last edited by qtwebkit; 3rd March 2014 at 05:54. |
3rd March 2014, 20:30 | #209 | Link |
A friend tested the two clips with his HD4000, Windows 8.1 x64, both x64 and x86 filters, but result very close to mine.
performance of x86 filters(x64 scores quite close to x86) Cat: LAV : 290fps MS DS : 293fps Vortexx: LAV : 198fps MS DS : 187fps Despite the small gap between our results, we are both too slow comparing with yours. And the same problem, or bug? Black screen in EVR renderless. Last edited by qtwebkit; 3rd March 2014 at 20:33. |
3rd March 2014, 20:47 | #210 | Link |
EVR renderless is not supposed to show an image.
3rd March 2014, 21:11 | #212 | Link | ||
Can you see the clock of iGPU with GPU-Z for example, during benchmarking ? HD4000 should be faster than my GT1. Are you sure you have an HD4000 and not an HD2500 ? Quote:
For me LAV is 340 fps for EVR renderless and Vortexx Right EVR renderless shows maximum potential of decoder, because it doesn't have to display the decoded frames, that's why the screen is black and you could go to 3000 fps or more for low resolution/ low bandwidth clips.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 3rd March 2014 at 21:14. |
3rd March 2014, 21:37 | #214 | Link |
Well you do have HD4000 with 16 EU's while I have 10.
Your iGPU goes to maximum at 1GHz which is 10% slower than mine which goes up to 1.1GHz. All of the above don't explain your inferior performance compared with my GT1. I have to repeat myself just one more time because I can't think of anything else. Are you sure that ALL VPP functions are disabled in control panel ? They can push performance down A LOT.
3rd March 2014, 22:28 | #215 | Link | |
Yes,I'm quite sure everyting in the 3 options
I've been trying to exclude my omissions and turn to my friends for help, who also did all the settings as you said, but end up with the same problem . Thank you for your concern on my problem, as well as nevcairiel. |
4th March 2014, 18:21 | #217 | Link |
Can you benchmark this ?
ftp://helpedia.com/pub/multimedia/x264/testvideos/2160p%20samples/DucksTakeOff_2160p50.x264.CRF24.mkv It's an UHD file so you have to check 4K box in LAV properties.
5th March 2014, 06:30 | #219 | Link |
Mine are: 99/146
There is a bottleneck in your system, but I can't tell where.
5th March 2014, 13:14 | #220 | Link | |
Can you check this driver: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23644 It is the first official driver with API 1.8 support, maybe there is something different for decoding as well. |
