1st February 2012, 21:11 | #2361 | Link |
Useless idea generator
Do you consider easier launching of AVS cutter before Interlace analysis of AVS creator ?
( for avoiding Interlace analysis of not used video parts, what can lead to improper analyzer suggestion )
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 / focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC] |
2nd February 2012, 15:37 | #2362 | Link |
As I do not have much time for developing MeGUI I focus on fixing bugs/problems, implementing simple features and features which I need for my personal use (like OneClick). Your feature request does not fit in any of those categories and therefore it is unlikely that it will be implemented by me in the next time. But... of course I will commit a patch so feel free to create the required code on your own.
2nd February 2012, 20:04 | #2363 | Link |
Hi all
1. Please, add the option "Quantizer for first pass" (select manually - 1...4) when 2-pass encoding XviD. 2. Show you how to properly use fourcc DX50 with two pass encoding Xvid? DX50 doesn't change. Thanks in advance.. Sorry for my bad english |
2nd February 2012, 21:24 | #2364 | Link |
Don't know if I'm making something wrong, but when converting old
movies dvds to MKV with Megui, the ones with AR: 4:3, without any resize applied, Megui changes AR to 3:2. No problem is source is 16:9, no matter if AR is 1.66, 1.85 or 2.35. |
2nd February 2012, 22:47 | #2365 | Link | |
Latest 1.3.2 xvid_encraw is in fact 30% slower both when encoding via command line and with MeGUI. The information about the speed of encoding via command line reported by 1.3.2 xvid_encraw is in fact wrong. I compared the duration of encoding using a stopwatch and concluded that it is slower. So there is actually nothing to change for you. MeGUI reported real fps whereas 1.3.2 xvid_encraw reported wrong fps speed via command line. |
5th February 2012, 06:19 | #2366 | Link |
Hi Zathor,
I was hoping for a few little fixups\improvements for the HD-DVD/Blu-ray Stream extractor window. * Add tick box to use input folder for output * Allow the whole window to be resized and also remembered on close. * Allow the Feature(s) and Stream(s) boxes to be manually resized vertically within the window and remembered once the window is closed. * Allow the Features(s) box to be manually sorted by name and duration, it sorts be duration by default which make encoding episode blurays annoying.
A Man Eating Duck Last edited by AMED; 5th February 2012 at 06:49. |
5th February 2012, 18:35 | #2367 | Link | ||
1+2) I have no experience with XviD and no idea if this is the intended behavior. |
5th February 2012, 18:45 | #2368 | Link |
2110 [x264] force --keyint-min 1 with Blu-ray (requires x264 revision 2149+) replaced vfw4x264 with avs4x264mod. Details: http://forum.doom9.org/showthread.php?t=162656 2109 [XviD] fixed saving of custom vbv values. Bug #3483985 2108 [AutoEncode] + [OneClick] fixed saving of custom file size values [File Size Selector] removed some default values added a control in the settings to modify custom file size values all other controls will not save anymore custom values 2107 [Job] delete intermediate files also during job deletion if specified in the settings |
6th February 2012, 12:19 | #2370 | Link | |
I agree that this does make episodes difficult to process however I can't see how sorting this will help as there is no guarantee any other sort will determine the correct order. Most will be in playlist or mt2s order but I have seen some which appear random. Where there is a single playlist for all episodes you can use the drop down list for that feature to determine the order of the single episode features otherwise always have to start each episode from the menu on a blu-ray player to determine the episode lengths and therefore the correct order. This is of course impossible if more than one episode have the same length! |
14th February 2012, 02:44 | #2371 | Link |
hi Zathor,
i would like to ask you to integrate the qaac encoder in megui. nero aac is great, i know, but the last listening tests and many users in the hydrogenaudio forum recomment the windows command line quicktime aac encoder. http://sites.google.com/site/qaacpage/ it is working with eac3to and is not only an alternative to nero aac, but also to flac! because qaac ia an alac encoder, too. - i think, a must have for megui |
14th February 2012, 06:28 | #2372 | Link | |
Practising Schemer
Sweet |
17th February 2012, 04:21 | #2374 | Link |
A feature request.....
Almost every time I use MeGUI to index a file, I find myself wishing I could just run the job, rather than have to add it to the job queue and then run it from there. Which got me thinking it'd be nice if the file indexer also had a "run it now" button, which then led me to wonder if it'd be a fun idea to be able to hold down the shift key (for example) while hovering the mouse over the "queue" button (anywhere a queue button can be found) which would change it's function from adding the job to the queue to just running it. |
17th February 2012, 17:43 | #2376 | Link |
I forgot it was there to be honest, but no that's not quite it.
I know it's only a minor thing, but it'd be nice to be able to autostart an indexing job, queue an encode, autostart the next indexing job.... that sort of thing. Being able to autostart by simply holding down the shift key when hitting the queue button (or something similar) would be a nice touch.... in my opinion. |
19th February 2012, 11:37 | #2378 | Link | ||
