6th June 2006, 07:53 | #441 | Link | |
Jeanl, very very nice application your DVDSubEdit !!! Cheers, SD |
6th June 2006, 07:55 | #442 | Link |
You guys will have to give me some time!
jeanl
A few PgcEdit guides. DVDSubEdit a free tool to edit subtitles directly inside the vob. |
6th June 2006, 08:05 | #443 | Link | |
6th June 2006, 08:46 | #444 | Link | |
No modification seems possible at all to the picture contents, apart by using DVDSubEdit, since, apparently, with this type of asset no program can make a valid sst from subs without stop commands. Even with formats different from sst the problem of automatically decompiling such type of assets seems unsolved: tryed for example the usage of the very basic DVD SupTools (DVDSupDecode + DVDSupEncode), that fails too in this case... Well, thanks for the references to the sst format... Hem, to say the truth I have read the page you pointed out at least three other times... So, sigh, let me go reading it again... Hopefully this time I will not miss some important points... SD Last edited by Sir Didymus; 6th June 2006 at 09:11. |
6th June 2006, 10:01 | #445 | Link | |
reMember
Guides for DVDSubEdit |
6th June 2006, 10:45 | #446 | Link | |
http://rapidshare.de/files/22341335/Wimb.zip.html (436 kb). Thank's jeanl and mpucoder. But... one thing. May be it's a not subtitles bug. Today I watch this movie on PowerDVD 6.0. All is Ok. Flashing appear in PowerDVD 7.0 only. Who is right? I don't know. Maybe you helps me. I can't uploading a big files like VOB. Maybe you can detect an error by .sup file only. |
6th June 2006, 11:33 | #447 | Link | |
6th June 2006, 16:29 | #448 | Link |
This is what I get as the interpretation of the first sub
time commands 0 set_color 1023 00:00 set_contr 3330 set_darea 0,719,2,574 set_dspxa 0x0006,0x04c1 sta_dsp cmd_end 3 set_color 1023 00:01 set_contr 6660 cmd_end 7 set_color 1023 00:02 set_contr 9990 cmd_end 10 set_color 1023 00:03 set_contr ccc0 cmd_end 14 set_color 1023 00:04 set_contr fff0 cmd_end 119 set_color 1023 01:09 set_contr ccc0 cmd_end 123 set_color 1023 01:10 set_contr 9990 cmd_end 126 set_color 1023 01:11 set_contr 6660 cmd_end 130 set_color 1023 01:12 set_contr 3330 cmd_end 133 set_color 1023 01:13 set_contr 0000 stp_dsp cmd_end edit: the time column contains the stm value first (clock ticks/1024) and then ss:ff Last edited by mpucoder; 6th June 2006 at 18:04. |
6th June 2006, 17:47 | #449 | Link | |
Straight to video
I should vow to stop posting in the wee hours of the morning... |
6th June 2006, 18:26 | #451 | Link |
This suggests a very simple UI for adding a fade-in/out:
- Two check boxes for fade in and fade out - Number of frames for fade-in - Number of frames for fade-out - Perhaps a button to remove the fades in one shot. and of course, the traditional "apply to all"... I suspect going linearly may not be the best way to do it. mpucoder, do you know if the transparency encoding in SPUs is somewhat "perceptual" (i.e., if you go linear, you'll get a nice even fade in/out)? Jeanl
6th June 2006, 18:37 | #452 | Link | |
Straight to video
i.e. a linear transparency progression like so: 3->6->9->12->15->12->9->6->3->0, with a stop at the last DCSQT. EDIT: Here's the DVDSubEdit dump of a DVDMaestro 5-frame fadein/out (NTSC), in case anyone wants to see. Last edited by kumi; 6th June 2006 at 18:55. |
6th June 2006, 19:43 | #453 | Link | |
Straight to video
Track 1 shows a linear fade using all 16 available transparency values. Looks pretty good to my eyes (as decoded by ivivideo.ax v6.0.6.56) Track 2 shows noticeable stuttering, because it has more steps than available transparency values. (I wrote "xx-color fadein" in the subs... i meant "xx-value fadein" of course Last edited by kumi; 7th June 2006 at 04:04. |
6th June 2006, 20:07 | #454 | Link | |
Cheers, SD Edit: just to be totally sure, I did also a quick check with the Philips Verifier... Not a single one of the reported "glitches" is related to the sup asset... I am very confident, if you burn your title and test it with a standalone, it will be ok! Edit2: indeed, the fade-in fade-out test title of kumi is playing fine also in Power DVD 7.0... Last edited by Sir Didymus; 6th June 2006 at 20:50. |
20th June 2006, 23:45 | #456 | Link |
I was surfing www.google.com searching for a program that can extract/replace individual subtitles due to problems like mispellings, and other typos...
When I quickly found DVDSubEdit's original topic :O I checked through all 29 pages... and although DVDSubEdit cannot replace subs yet... Wow! I've favorited this on my long list of programs I like to check progress on. Very professional and easy to use Just wanted to throw out my personal thank you~Jeanl
*Critical Error* ARG! Work darn you! |
20th June 2006, 23:48 | #457 | Link |
Thanks! Your feedback is highly appreciated!
I haven't worked on DVDSubEdit much in the past couple months, but development isn't on hold! It's just that I have some other stuff competing for attention (like, construction work at my house! ) Jeanl
18th August 2006, 13:23 | #458 | Link |
I`ve tried to extract some subpictures from a dvd menu to a .ppm file. When I place this subpicture over the original background the subpicture looks stretched. I don`t know if this is a bug or are there some settings in dvdsubedit which i can adjust? I`ve uploaded a photoshop project with the original background, a subpicture ripped with suprip, and a subpicture ripped with dvdsubedit for comperision. http://www.yousendit.com/transfer.ph...F7192B1B121784 The purpase of ripping to .ppm is that I wish to ad an extra button in the menu. |
18th August 2006, 17:01 | #459 | Link |
borry, this might be a bug, I'll have to look into it, but I'm busy these days (remodelling of our house)...
jeanl
