Old 14th June 2009, 00:16   #21  |  Link
Gavino
Avisynth language lover
Excellent, tritical!
Well done for getting the new function out so quickly.
Old 14th June 2009, 15:19   #22  |  Link
Undead Sega
this is wicked!
but can someone help me combine this fuction for the NNEDI+MCBob_v03c.avs??
Undead Sega is offline   Reply With Quote
Old 14th June 2009, 18:33   #23  |  Link
thewebchat
Advanced Blogging
Undead Sega: Open your mcbob.avs and search/replace all nnedi with nnedi2. Done.
thewebchat is offline   Reply With Quote
Old 14th June 2009, 20:10   #24  |  Link
Undead Sega
# MCBob v0.3:
# nnedi and nnedibob was made possible by tritical and the fellow Doom9 community who contributed CPU cycles.
# Another approach to motion compensated bobbing, build by Didée.
# ( Between-all-chairs version with some quick hacks )
# ( v0.3c: as stated above, but worse ;-) )
# ( v0.3u (unofficial): use new nnEDI interpolater by tritical, modded by Terranigma)
# Features:
# - No residual combing, due to STT (Shape Transposition Technology)
# - Works without thresholds (with adaptive thresholds instead of fixed ones)
# - Motion Search between fields of same parity, for maximum flicker/bob reduction in motion areas
# - Motion Masking adaptive to local complexity, for maximum flicker/bob reduction in static areas
# - spatial Interpolation overweights spatio-temporal interpolation
# ( in areas where the information obtained from temporal neighbors in itself was only spatially
# interpolated, use a mix of spatial and spatio-temporal interpolation )
# - error correction for temporal interpolation is fully self adaptive
# Prerequisites:
# - MVTools, preferably v1.4.13 (or newer)
# - MaskTools v2.0
# - nnEDI 1.3 +
# - RemoveGrain/Repair package
# - ReduceFlicker (if temp-NR for ME is used)
# - MedianBlur by tsp
function MCBob(clip clp, float "EdiPre", int "EdiPost", int "blocksize", int "MEdepth", float "sharpness", int "mtnmode", float "mtnth1", float "mtnth2", float "errth1", float "errth2", float "MEspatNR", float "MEtempNR")
    EdiPre    = default( EdiPre,    1.0 )  #  What bob to start with: 0.0 = dumbbob, 1.0 = nnEdiBob, inbetween = mix of both
    EdiPost   = default( EdiPost,     2 )  #  0 = no nnEDI PP / 1 = Framesized nnEdi PP / Average two Fieldbased nnEdi PP's
    bs        = default( blocksize,  16 )  #  Blocksize for motion search
    me        = default( MEdepth,     2 )  #  Search effort of motion search
    sharpness = (EdiPost==2)
     \        ? default( sharpness, 0.7 )
     \        : default( sharpness, 1.0 )  #  use slight sharpening before STT routine
    mtnmode   = default( mtnmode,     1 )  #  0 = use only same-parity motion check, 1|2 use an additional
                                           #  inter-parity check: 1 = on vertical edges / 2 = not on horizontal edges
    mtnth1    = default( mtnth1,   0.20 )  #  below this %age of local min/max is static
    mtnth2    = default( mtnth2,   0.40 )  #  above this %age of local min/max is motion
    errth1    = default( errth1,   0.40 )  #  similar for error detection
    errth2    = default( errth2,   0.60 )  #  of motion interpolation errors
    MEspatNR  = default( MEspatNR, 0.00 )  #  amount of spatial NR (for motion search only)
    MEtempNR  = default( MEtempNR, 0.00 )  #  amount of temporal NR (for motion search only)
    order = (clp.GetParity == True) ? 0 : 1
    ORDR  = (order==0) ? "TFF" : "BFF"
    ox    = clp.width()
    oy    = clp.height()
    ERTH1 = string(errth1)
    ERTH2 = string(errth2)
    MNTH1 = string(mtnth1)
    MNTH2 = string(mtnth2)
    SSTR  = string(sharpness)
    idx_1 = 10
    idx_2 = (MEspatNR==0.0 && MEtempNR==0.0) ? idx_1 : idx_1+2
    idx_3 = idx_2 + 2
# Create basic operations that we will work with
# Basic Field & Bob clips
    flatbob   = clp.Bob(1,0)
    normbob   = clp.Bob(0.0,0.5)
    ofields   = clp.SeparateFields()
    oweave    = clp.DoubleWeave()
    nnedibobbed = clp.nnEDIbob()
    bobbed    = (EdiPre == 0.0) ? normbob
     \        : (EdiPre == 1.0) ? nnedibobbed
     \        :                   normbob.merge(nnedibobbed,EdiPre)
# Mask to check if motion compensation has delivered only the neighbor's spatial interpolated part
    black    = Blankclip(ofields).mt_lut("0").Trim(1,1).Loop(Framecount(clp))
    white    = Blankclip(ofields).mt_lut("255").Trim(1,1).Loop(Framecount(clp))
    interpol = Interleave(black,white,white,black).AssumeFieldbased().AssumeParity(ORDR).Weave()
# Vertical Edge mask, needed for more safe motion masking
    Vedge  = bobbed.mt_Edge("1 0 -1 2 0 -2 1 0 -1",0,255,0,255,U=1,V=1)
    Vedge2 = Vedge.mt_Inpand(mode="vertical").mt_Inpand(mode="vertical").mt_Expand(mode="vertical").mt_Expand(mode="vertical")
    Vedge  = mt_Lutxy(Vedge,Vedge2,yexpr="y 2 - 2 * x > x y 2 - 2 * ?") #.mt_Expand()
    Hedge  = bobbed.mt_Edge("1 2 1 0 0 0 -1 -2 -1",0,255,0,255,U=1,V=1)
    Hedge = Hedge.mt_logic(Hedge.temporalsoften(1,255,0,255,2),"max")
# If requested, do flicker reduction before searching motion vectors
    (MEspatNR==0.0) ? bobbed : bobbed.Merge(bobbed.minblur(2,uv=3),MEspatNR)
    (MEtempNR==0.0) ? last : last.Merge(reduceflicker(2),MEtempNR)
    srch=last
# Perform Motion Search
    lmbda = 128
    pnw   =  40
    bw_vec2 = srch.SelectEven().MVAnalyse(isb=true, truemotion=false,delta=1,lambda=lmbda,pel=2,searchparam=me,sharp=2,blksize=bs,overlap=1*bs/2,pnew=pnw,idx=idx_1)
    fw_vec2 = srch.SelectEven().MVAnalyse(isb=false,truemotion=false,delta=1,lambda=lmbda,pel=2,searchparam=me,sharp=2,blksize=bs,overlap=1*bs/2,pnew=pnw,idx=idx_1)
    bw_vec3 = srch.SelectOdd() .MVAnalyse(isb=true, truemotion=false,delta=1,lambda=lmbda,pel=2,searchparam=me,sharp=2,blksize=bs,overlap=1*bs/2,pnew=pnw,idx=idx_1+1)
    fw_vec3 = srch.SelectOdd() .MVAnalyse(isb=false,truemotion=false,delta=1,lambda=lmbda,pel=2,searchparam=me,sharp=2,blksize=bs,overlap=1*bs/2,pnew=pnw,idx=idx_1+1)
# Create RAW motion interpolation
    alt_1   = bobbed.SelectEven().MVFlowInter(bw_vec2,fw_vec2,time=50.0,thSCD1=64*18,thSCD2=227,idx=idx_2)
    alt_2   = bobbed.SelectOdd() .MVFlowInter(bw_vec3,fw_vec3,time=50.0,thSCD1=64*18,thSCD2=227,idx=idx_2+1).DuplicateFrame(0)
    alt     = Interleave(alt_2,alt_1)
# Create motion interpolation of "nothing new" mask
    interpol_1   = interpol.SelectEven().MVFlowInter(bw_vec2,fw_vec2,time=50.0,thSCD1=64*8,thSCD2=127,idx=idx_3)
    interpol_2   = interpol.SelectOdd() .MVFlowInter(bw_vec3,fw_vec3,time=50.0,thSCD1=64*8,thSCD2=127,idx=idx_3+1).DuplicateFrame(0)
    interpol_comp= Interleave(interpol_2,interpol_1)
    nothing_new  = mt_lutxy(interpol,interpol_comp,"x y * 255 / 255 / 1 2 / ^ 160 *")
# Error check of motion interpolation
# Errors that are neutralized by errors in direct vertical neighborhood are not considered, because bob-typical.
# Remaining error is checked against [min,max] of local error to decide if it's valid or not.
# Build error mask, neutralize vertical-only errors
    altD     = mt_Makediff(bobbed,alt,U=3,V=3)
    altDmin  = altD.mt_Inpand(mode="vertical",U=3,V=3)
    altDmin  = altDmin.mt_Deflate().mt_Merge(altDmin,Vedge,U=4,V=4)
    altDmax  = altD.mt_Expand(mode="vertical",U=3,V=3)
    altDmax  = altDmax.mt_Inflate().mt_Merge(altDmax,Vedge,U=4,V=4)
    altDmm   = mt_Lutxy(altDmax.mt_Expand(mode="horizontal",U=3,V=3),altDmin.mt_Inpand(mode="horizontal",U=3,V=3),"x y -",U=3,V=3)
    altDmm   = altDmm.mt_Inflate().mt_Merge(altDmm,Vedge,U=4,V=4)
    altD1    = altD .mt_Lutxy(altDmin,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=3,V=3)
    altD1    = altD1.mt_Lutxy(altDmax,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=3,V=3)
    altD2    = altD.Repair(altD1,1)
# Build correction mask by combining:  error mask  +  "nothing new" mask  +  a scenechange mask
    corrmask = mt_Lutxy(altD2,altDmm,"x 128 - abs 2 - y 2 + / "+ERTH1+" - "+ERTH2+" "+ERTH1+" - / 255 *",U=3,V=3).mt_Expand(U=3,V=3)
    sc       = corrmask.BilinearResize(64,64)
    sc       = mt_LutF(sc,sc,mode="average",expr="x 255 0.6 * > 255 0 ?").PointResize(ox,oy)
    corrmask = corrmask.mt_Logic(nothing_new,"max",U=2,V=2)
    corrmask = corrmask.mt_Logic(sc,"max",U=2,V=2)
# Create a first bob from motion interpolation, not yet error corrected ...
# ***( temporarily changed ... yet unsure what works best )***
    Interleave(bobbed,alt).AssumeParity(ORDR)
    SeparateFields().SelectEvery(8,0,3,5,6).Weave()
    naked= last
    naked2 = last.vinverseD(1.6) # flatbob #
    naked_mm = naked.mt_Edge("min/max",0,255,0,255,U=1,V=1)
    edibb_mm = nnedibobbed.mt_Edge("min/max",0,255,0,255,U=1,V=1).mt_Expand(mode="vertical")
    check2   = mt_LutXY(naked_mm,edibb_mm,"x y / 3 - 5 3 - / 255 *")
    corrmask = corrmask.mt_Logic(check2,"max",U=2,V=2)
# ... and build a motion mask from this one.
# ***( temporarily changed ... tickertapes might suffer. )***
    stc = bobbed .removegrain(2)# oweave.removegrain(11)
    mm         = stc.mt_Edge("min/max",0,255,0,255,U=3,V=3)
   #  mm = mm .mt_Logic(mm.DuplicateFrame(0),"max",U=3,V=3).mt_Logic(mm.DeleteFrame(0),"max",U=3,V=3)
    #  max = stc.mt_expand(U=3,V=3)
    #  max = max.mt_logic(max.Duplicateframe(0),"max",U=3,V=3).mt_logic(max.Duplicateframe(0).Duplicateframe(0),"max",U=3,V=3)
    #  min = stc.mt_inpand(U=3,V=3)
    #  min = min.mt_logic(min.Duplicateframe(0),"min",U=3,V=3).mt_logic(min.Duplicateframe(0).Duplicateframe(0),"min",U=3,V=3)
    #  mm = mt_LutXY(max,min,"x y -",U=3,V=3)
    diff2prev1 = mt_LutXY(stc,stc.DuplicateFrame(0),"x y - abs",U=3,V=3)
    diff2prev2 = mt_LutXY(stc,stc.DuplicateFrame(0).DuplicateFrame(0),"x y - abs",U=3,V=3)
    diff2prev12 = (mtnmode==0) ? diff2prev2 :
     \            (mtnmode==1) ? diff2prev2 .mt_Merge(diff2prev1,Vedge,U=2,V=2)
     \                         : diff2prev1 .mt_Merge(diff2prev2,Hedge,U=2,V=2)
    motn       = diff2prev12.mt_Logic(diff2prev12.DeleteFrame(0),"max",U=3,V=3).mt_Logic(diff2prev12.DeleteFrame(0).DeleteFrame(0),"max",U=3,V=3)
    notstatic  = mt_LutXY(motn,mm,"x 1 - y 1 + / "+MNTH1+" - "+MNTH2+" "+MNTH1+" - / 255 *",U=3,V=3).mt_Expand(U=3,V=3).mt_Inpand(U=3,V=3)
   # notstatic  = notstatic.mt_Logic(notstatic.RemoveGrain(4),"max",U=3,V=3).mt_Expand(U=3,V=3).mt_Inpand(U=3,V=3)
# Now do the error correction of the "naked" MC-bob
    naked .mt_Merge(nnedibobbed,corrmask,luma=false,U=3,V=3) .VinverseD(2.7-sharpness)
    repaired = last
# If requested, sharpen the corrected MC-bob up a little
# ( pre-sharpen for EdiPost = 0 | 1 )
    shrpbase  = last#.MinBlur(1,1).Merge(RemoveGrain(12,-1),0.23)
    shrp      = mt_LutXY(shrpbase,shrpbase.RemoveGrain(11,-1),"x x y - abs 16 / 1 1 x y - abs 1 4 / ^ + / ^ 16 * "+SSTR+" * x y - x y - abs 1.3 + / * 1 x y - abs 16 / 1 4 / ^ + / +",U=2,V=2)
    # \ .Repair(repaired,1,0)
    shrpD     = mt_Makediff(shrpbase,shrp)
    (sharpness==0.0 || EdiPost==2) ? last : last .mt_Makediff(MergeLuma(shrpD.MinBlur(1,uv=1),shrpD.RemoveGrain(12,-1),0.24),U=2,V=2)
# If requested, do additional PP via nnEDI2
oweave.mt_merge(last,notstatic,luma=false,U=3,V=3)
    AssumeTFF()
    edisingle = nnedi(dh=true,field=1).LanczosResize(ox,oy,0,-0.5,ox,2*oy+0.001,taps=3)
    edidouble = merge(nnedi(field=1),nnedi(field=0),0.5)
    edidoubleD = mt_makediff(last,edidouble,U=3,V=3)
    (EdiPost==1) ? edisingle : \
    (EdiPost==2) ? edidouble : last
# ( post-sharpen for EdiPost = 2 )
    edidoubleshrpD = mt_makediff(edidouble,sharpness==1.0?edidouble.removegrain(20):edidouble.removegrain(20).merge(edidouble,1.0-sharpness),U=3,V=3)
    edidoubleshrpD = edidoubleshrpD.repair(edidoubleD,13)
    (EdiPost==2) ? edidouble.mt_adddiff(edidoubleshrpD,U=3,V=3) : last
# STT (Shape Transposition Technology) Routine:
# Simply weaving the corrected output with the original fields is bad, because the risk of
# creating unwanted residual combing is too high.
# Instead, the vertical "shape" is taken off the corrected output, and transposed
# onto the fixed "poles" of the original fields' scanlines. Et Voila.
    synthbob   = last.AssumeParity(ORDR).SeparateFields().SelectEvery(4,0,3).Weave().Bob(1,0)
    mapped_new = flatbob.mt_makediff(mt_makediff(synthbob,last,U=3,V=3),U=3,V=3)
    newfields  = mapped_new.AssumeParity(ORDR).SeparateFields().SelectEvery(4,1,2)
    mappedbob  = Interleave(ofields,newfields).SelectEvery(4,0,1,3,2).AssumeParity(ORDR).Weave()
# Finally, for static areas use just original fields
    mappedbob
    #bobbed
    oweave.mt_merge(last,notstatic.mt_inpand(Y=2,U=2,V=2),luma=false,U=3,V=3)
# Lastly, set correct parity for the bobbed clip
    (order==0) ? AssumeTFF() : AssumeBFF()
    return(last)
#  Helper functions below  #
## Function nnEDIbob, courtesty of tritical:
    # slow, but accurate nnEDI-bob, always dumb ;)
Function nnEDIbob(clip Input)
	    Input.nnedi(field=-2)
# Helper to simplify script
function AssumeParity(clip clp, string "order")
order == "TFF" ? clp.assumeTFF() : clp.assumeBFF()
return(last)
# Kill Combing Function
function VinverseD(clip clp, float "sstr", int "amnt", int "uv")
uv   = default(uv,3)
sstr = default(sstr,2.7)
amnt = default(amnt,255)
uv2  = (uv==2) ? 1 : uv
STR  = string(sstr)
AMN  = string(amnt)
vblur  = clp.mt_convolution("1","50 99 50",U=uv,V=uv)
vblurD = mt_makediff(clp,vblur,U=uv2,V=uv2)
Vshrp  = mt_lutxy(vblur,vblur.mt_convolution("1","1 4 6 4 1",U=uv2,V=uv2),expr="x x y - "+STR+" * +",U=uv2,V=uv2)
VshrpD = mt_makediff(Vshrp,vblur,U=uv2,V=uv2)
VlimD  = mt_lutxy(VshrpD,VblurD,expr="x 128 - y 128 - * 0 < x 128 - abs y 128 - abs < x y ? 128 - 0.25 * 128 + x 128 - abs y 128 - abs < x y ? ?",U=uv2,V=uv2)
mt_adddiff(Vblur,VlimD,U=uv,V=uv)
(amnt>254) ? last : (amnt==0) ? clp : mt_lutxy(clp,last,expr="x "+AMN+" + y < x "+AMN+" + x "+AMN+" - y > x "+AMN+" - y ? ?",U=uv,V=uv)
return(last)
# Nifty Gauss/Median combination
function MinBlur(clip clp, int r, int "uv")
uv   = default(uv,3)
rg4  = (uv==3) ? 4 : -1
rg11 = (uv==3) ? 11 : -1
rg20 = (uv==3) ? 20 : -1
medf = (uv==3) ? 1 : -200
RG11D = (r==1) ? mt_makediff(clp,clp.removegrain(11,rg11),U=uv2,V=uv2)
 \    : (r==2) ? mt_makediff(clp,clp.removegrain(11,rg11).removegrain(20,rg20),U=uv2,V=uv2)
 \    :          mt_makediff(clp,clp.removegrain(11,rg11).removegrain(20,rg20).removegrain(20,rg20),U=uv2,V=uv2)
RG4D  = (r==1) ? mt_makediff(clp,clp.removegrain(4,rg4),U=uv2,V=uv2)
 \    : (r==2) ? mt_makediff(clp,clp.medianblur(2,2*medf,2*medf),U=uv2,V=uv2)
 \    :          mt_makediff(clp,clp.medianblur(3,3*medf,3*medf),U=uv2,V=uv2)
DD    = mt_lutxy(RG11D,RG4D,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=uv2,V=uv2)
clp.mt_makediff(DD,U=uv,V=uv)
return(last)
every one of them???
Old 14th June 2009, 20:44   #25  |  Link
Gavino
Yes.
An alternative is to do what thewebchat suggested at post #6, create a wrapper function called nnedi that just calls nnedi2.
In the longer term, it might be useful to use the new function nnedi2_rpow2 where appropriate instead of nnedi2 directly. But that requires more thought and care.
Old 14th June 2009, 20:50   #26  |  Link
Chainmax
Huh?
Chainmax's Avatar
Thanks for a new release of such a great plugin, tritical
From examining the comparison pics, nnedi2 v2 looks a wee bit softer and with far less artifacts (if any) than nnedi v1.3. The white fences and house walls in the second lighthouse comparison are a really good indicator of the lack of artifacting, it's pretty amazing.
I especially like that now nnediresize2x.avs is no longer needed and we can simply use nnedi2_rpow2(qual=3,rfactor=2,cshift="spline36resize") instead. By the way, how does the resizer choice affect the output of the cshift parameter?
One thing, though: there were some cases (I think they were with animated content, not sure though) where EEDI2 would yield better results than NNEDI v1.3. Would it be possible for you to incluse EEDI2 in that comparison?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 15th June 2009, 01:23   #27  |  Link
tritical
Exactly the same way it affects any other resizing operation. If you specify cshift, this line gets added to the end of the constructed filter chain with the enlarged result from nnedi2 as the input:
xxxresize(fwidth,fheight,hshift,vshift,rfactor*owidth,rfactor*oheight)
Where 'xxxresize' is the resizer you specified with 'cshift', and owidth/oheight are the original input image width/height. fwidth/fheight are set equal to rfactor*owidth and rfactor*oheight if you don't specify them. hshift/vshift are the shifts to cancel the center image shift introduced by nnedi2. So if you don't set fwidth/fheight there wont be much, if any, difference between resizers because the scaling factors are so close to 1.
Also, I just realized that how I coded it wont work for bicubicresize because the syntax is
bicubicresize(clip clip, int target_width, int target_height, float b, float c, float src_left, float src_top, float src_width, float src_height)
It also has the limitation that you can't pass extra arguments to the resizer ala gauss/blackman/lanczos/bicubic. I'll fix these issues in the next version.
I'll add eedi2 images when I get a chance. However, I think its unlikely that eedi2 could beat nnedi/nnedi2 for image enlargement. Sometimes it is better for deinterlacing interpolation because it is more aggressive at connecting lines - especially thin high contrast lines. However, that comes at the price of lots of artifacts. Whereas, nnedi/nnedi2 are trained to minimize mse, which doesn't always equate to connecting every line or smoothing every edge depending on how other similar neighborhoods need to be handled. eedi2 is also limited from the standpoint that it forms the output value as an average of one pixel from the line above and one pixel from the line below, both at equal distances from the center. nnedi2 formulates the output as a linear function of all pixels in the local neighborhood (2 lines above/below, 5 pixels left, 6 pixels right, so 48 pixels total). nnedi formulated the output as a non-linear function of a local neighborhood involving 100 pixels... it had significantly more problems with overfitting the training data. nnedi also had spatial continuity problems due to the use of hard k-means clustering, with each cluster having a separate small network. nnedi2 simply uses one large network for all patterns.
tritical is offline   Reply With Quote
Old 15th June 2009, 02:41   #28  |  Link
th3obr0
What to do if it says height is not mod2? I used to get this error with the previous version. How to solve that?
Nice plugin, sir. Would come in handy .
th3obr0 is offline   Reply With Quote
Old 15th June 2009, 03:36   #29  |  Link
mikenadia
nnedi2_rpow2(rfactor=8,cshift="lanczosresize",fwidth=width*7,fheight=height*7)
Nice plug-in. I was wondering if they will be a difference between the above line and applying three times ( after or before each iteration of NNEDI2 ) lanczos resize with the resize factor of (7/8)^(1/3).
Edit: Initial Size=Size0. If downsizing after enlarging.
Enlarge by 2. Resize to Size1=int(Size0*2*(7/8)^(1/3)).
Enlarge by 2. Resize to Size2=int(Size0*4*(7/8)^(2/3))
Enlarge by 2. Resize to Size0*7.
Last edited by mikenadia; 15th June 2009 at 18:47. Reason: following Gavino's comment.
mikenadia is offline   Reply With Quote
Old 15th June 2009, 09:46   #30  |  Link
Gavino
Well, you couldn't do that anyway, because you can only resize to integer sizes and 7^(1/3) is not a rational number.
Old 15th June 2009, 13:21   #31  |  Link
Archimedes
I have problems with the cpu optimizations.
LoadPlugin("plugins\NNEDI2\nnedi2.dll")
ImageSource("clown__original.png", end=0, use_DevIL=False, pixel_type="RGB24")
nnedi2_rpow2(rfactor=2)
Opening with VirtualDub i received the following error code:
VirtualDub crash report -- build 31536 (release)
Disassembly:
0227a380: 0000            add    [eax], al
0227a382: 0f59af50010000  mulps  xmm5, [edi+150]
0227a389: 0f59b710020000  mulps  xmm6, [edi+210]
0227a390: 0f59bfd0020000  mulps  xmm7, [edi+2d0]
0227a397: 0f58c4          addps  xmm0, xmm4
0227a39a: 0f58cd          addps  xmm1, xmm5
0227a39d: 0f58d6          addps  xmm2, xmm6
0227a3a0: 0f58df          addps  xmm3, xmm7
0227a3a3: 0f28a1a0000000  movaps xmm4, [ecx+a0]
0227a3aa: 0f28ec          movaps xmm5, xmm4
0227a3ad: 0f28f4          movaps xmm6, xmm4
0227a3b0: 0f28fc          movaps xmm7, xmm4
0227a3b3: 0f59a7a0000000  mulps  xmm4, [edi+a0]
0227a3ba: 0f59af60010000  mulps  xmm5, [edi+160]
0227a3c1: 0f59b720020000  mulps  xmm6, [edi+220]
0227a3c8: 0f59bfe0020000  mulps  xmm7, [edi+2e0]
0227a3cf: 0f58c4          addps  xmm0, xmm4
0227a3d2: 0f58cd          addps  xmm1, xmm5
0227a3d5: 0f58d6          addps  xmm2, xmm6
0227a3d8: 0f58df          addps  xmm3, xmm7
0227a3db: 0f28a1b0000000  movaps xmm4, [ecx+b0]
0227a3e2: 0f28ec          movaps xmm5, xmm4
0227a3e5: 0f28f4          movaps xmm6, xmm4
0227a3e8: 0f28fc          movaps xmm7, xmm4
0227a3eb: 0f59a7b0000000  mulps  xmm4, [edi+b0]
0227a3f2: 0f59af70010000  mulps  xmm5, [edi+170]
0227a3f9: 0f59b730020000  mulps  xmm6, [edi+230]
0227a400: 0f59bff0020000  mulps  xmm7, [edi+2f0]
0227a407: 0f58c4          addps  xmm0, xmm4
0227a40a: 0f58cd          addps  xmm1, xmm5
0227a40d: 0f58d6          addps  xmm2, xmm6
0227a410: 0f58df          addps  xmm3, xmm7
0227a413: f20f            db     0fh      <-- FAULT
0227a415: 7cc1            jl     0227a3d8
0227a417: f20f            db     0fh
0227a419: 7cd3            jl     0227a3ee
0227a41b: f20f            db     0fh
0227a41d: 7cc2            jl     0227a3e1
0227a41f: 0f2900          movaps [eax], xmm0
0227a422: 81c700030000    add    edi, 00000300
0227a428: 83c010          add    eax, 10h
0227a42b: 83ea04          sub    edx, 04h
0227a42e: 0f857dfdffff    jnz    0227a1b1
0227a434: 8b442410        mov    eax, [esp+10h]
0227a438: 8b542414        mov    edx, [esp+14h]
0227a43c: 33c9            xor    ecx, ecx
0227a43e: 0f280488        movaps xmm0, [eax+ecx*4]
0227a442: 0f58048f        addps  xmm0, [edi+ecx*4]
0227a446: 0f290488        movaps [eax+ecx*4], xmm0
0227a44a: 83c104          add    ecx, 04h
0227a44d: 83ea04          sub    edx, 04h
0227a450: 75ec            jnz    0227a43e
0227a452: 5f              pop    edi
0227a453: c3              ret
0227a454: cc              int    3
0227a455: cc              int    3
0227a456: cc              int    3
0227a457: cc              int    3
0227a458: cc              int    3
0227a459: cc              int    3
0227a45a: cc              int    3
0227a45b: cc              int    3
0227a45c: cc              int    3
0227a45d: cc              int    3
0227a45e: cc              int    3
0227a45f: cc              int    3
0227a460: 57              push   edi
0227a461: 8b4c2408        mov    ecx, [esp+08h]
0227a465: 8b7c240c        mov    edi, [esp+0ch]
0227a469: 8b442410        mov    eax, [esp+10h]
0227a46d: 8b542414        mov    edx, [esp+14h]
0227a471: 0f2801          movaps xmm0, [ecx]
0227a474: 0f28c8          movaps xmm1, xmm0
0227a477: 0f28d0          movaps xmm2, xmm0
0227a47a: 0f28d8          movaps xmm3, xmm0
0227a47d: 0f5907          mulps  xmm0, [edi]
Built on Aegis on Sat Mar 28 15:17:50 2009 using compiler version 1400
Windows 5.1 (Windows XP x86 build 2600) [Service Pack 3]
EAX = 02389a50
EBX = 00000000
ECX = 014d2350
EDX = 00000004
EBP = 024dfef8
ESI = 02389a50
EDI = 014d3640
ESP = 024dfecc
EIP = 0227a413
EFLAGS = 00010206
FPUCW = ffff027f
FPUTW = ffffffff
Crash reason: Illegal instruction
Crash context:
An SSE2 (Pentium 4/Athlon 64) instruction not supported by the CPU was executed in module 'nnedi2'.
Pointer dumps:
EAX   02389a50: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ECX   014d2350: bd582d8e bbbb6667 3b0b3536 3c91e728 3b0b3536 bd582d8e 3b0b3536 3c91e728
ESI   02389a50: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
EDI   014d3640: bf489640 3de50f20 bc95bba8 3ee5be34 bf1d7202 beb635a4 bed43c6b bc04f6ba
ESP   024dfec8: 00244c20 014d3640 0227b768 014d2350 014d3640 02389a50 00000004 022e03dc
      024dfee8: 014d2278 00000000 0227c9d3 022e0217 000000e0 0227c9ff 02389a50 7c802530
      024dff08: 024dff74 7c80a0db 014d2350 02335664 022e03d0 02389a50 014d3640 00000005
      024dff28: fffffe40 00000204 00000180 000000cc 42957556 00000000 00055294 000000c0
EBP   024dfef8: 000000e0 0227c9ff 02389a50 7c802530 024dff74 7c80a0db 014d2350 02335664
      024dff18: 022e03d0 02389a50 014d3640 00000005 fffffe40 00000204 00000180 000000cc
      024dff38: 42957556 00000000 00055294 000000c0 00000380 000001c0 014d9c60 000001c0
      024dff58: 000001c0 0227cb52 014d0000 7c920222 014db4c0 00000000 7c920222 024dffac
Thread call stack:
0227a413: nnedi2!0000a413
0227b768: nnedi2!0000b768
0227c9d3: nnedi2!0000c9d3
0227c9ff: nnedi2!0000c9ff
0227cb52: nnedi2!0000cb52
7c920222: ntdll!RtlAllocateHeap [7c910000+100c4+15e]
02271555: nnedi2!00001555
022715fa: nnedi2!000015fa
7c80b729: kernel32!GetModuleFileNameA [7c800000+b56f+1ba]
-- End of report
Changing the opt parameter to 2 (use sse routines) helps.
Archimedes is offline   Reply With Quote
Old 15th June 2009, 18:41   #32  |  Link
tritical
Thanks for the report. You must have been the only person with a cpu without sse3 to try it because the automatic optimization detection wasn't correct. For opt=0 it always used sse3 routines. For right now you'll have to set opt manually for processors without sse3. Fixed in next version.
Are you saying you get that error when height is actually mod 2? Or just that you get that error on images that don't have mod 2 height? In the second case, just crop a line or add a line and remove it later. I'll remove that restriction for dh=true operation in the next version.
Maybe, you are free to try . I think it's unlikely to make any useful difference.
Old 15th June 2009, 20:20   #33  |  Link
Gavino
Originally Posted by tritical View Post
nnedi2_rpow2(int rfactor, int qual, bool pscrn, string cshift, int fwidth, int fheight, int threads, int opt)
It will use nnedi2 to enlarge by a power of 2 (rfactor) while minimizing relative luma/chroma shifting as much as possible. With a secondary goal of minimizing image center shifting when possible. It can then automatically correct for any image center shifting using the resizer you specify with 'cshift', and if you do specify 'cshift' it also gives you the option to set a new output width/height (fwidth/fheight).
Do you think it's worth adding an option to correct the remaining chroma shift as well (using MergeChroma with a specified resizer)?
Old 15th June 2009, 22:01   #34  |  Link
mikeytown2
Resize Abuser
mikeytown2's Avatar
To make a successful xxxresize, simply name them src_left, src_top, src_width, src_height. That's what I call for in KBE. You can see the code in ZoomBoxIt().
mikeytown2 is offline   Reply With Quote
Old 15th June 2009, 23:34   #35  |  Link
Archimedes
Here another comparison.
Source:
Spline36Resize:
EEDI2:
NNEDI:
NNEDI2:
NNEDI and NNEDI2 after strong sharpening and decent denoising (using identical parameters in both cases).
NNEDI + SuperSlowSharpen + dfttest:
NNEDI2 + SuperSlowSharpen + dfttest:
Old 17th June 2009, 20:59   #36  |  Link
tritical
I did some tests, and on images with bright colors it is worth it. So I decided to make that correction automatic (always invoke spline36resize at the end of the chain to correct vertical chroma shift when enlarging yv12).
That's what I did. Before I was passing without names because I thought they all took the same first 6 parameters. Didn't notice bicubicresize had b/c in the middle instead of at the end.
New version should be ready soon.
Old 18th June 2009, 01:33   #37  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Nice work, as always, tritical!!!
Very very impressive, a nice step up from NNEDI.
As soon as things stabilize I will be using this on everything!
~MiSfit
Old 18th June 2009, 22:49   #38  |  Link
tritical
I updated the zip archive to v1.2, changes:
+ remove mod2 height restriction when dh=true
+ more assembly optimizations/tweaks
- fixed automatic cpu detection
- fixed issues with nnedi2_rpow2
     - always correct yv12 vertical chroma shift
     - use arg names when invoking resizers
     - allow users to pass optional resizer arguments (ep0/ep1 parameters)
Will try to update the example images later. I'd like to get nnedi2/nnedi/eedi2/spline36 enlargements of each, with all properly centered. If anyone wants to have another resizer included please say so.
Old 19th June 2009, 00:49   #39  |  Link
shoopdabloop
Lanczos4 maybe?
shoopdabloop is offline   Reply With Quote
Old 19th June 2009, 11:49   #40  |  Link
Archimedes
tritical, thank you for updating, but the problem with cpu detection still exists.
nnedi2_rpow2(rfactor=2) results in:
Disassembly:
01e7b640: 8d348e          lea    esi, [esi+ecx*4]
01e7b643: 660f6f2e        movdqa xmm5, [esi]
01e7b647: 660f6f5e10      movdqa xmm3, [esi+10h]
01e7b64c: 660f            db     0fh
01e7b64e: 3a0f            cmp    cl, [edi]
01e7b650: dd05660f6f14    fld    qword ptr [146f0f66]
01e7b656: 4e              dec    esi
01e7b657: 660f6f644e10    movdqa xmm4, [esi+ecx*2+10h]
01e7b65d: 660f            db     0fh
01e7b65f: 3a0f            cmp    cl, [edi]
01e7b661: e205            loop   01e7b668
01e7b663: e91d030000      jmp    01e7b985
01e7b668: eb06            jmp    01e7b670
01e7b66a: 8d9b00000000    lea    ebx, [ebx+00]
01e7b670: 660f6f1e        movdqa xmm3, [esi]
01e7b674: 660f6f4610      movdqa xmm0, [esi+10h]
01e7b679: 660f            db     0fh
01e7b67b: 3a0f            cmp    cl, [edi]
01e7b67d: c3              ret
01e7b67e: 06              push   es
01e7b67f: 660f6f144e      movdqa xmm2, [esi+ecx*2]
01e7b684: 660f6f4c4e10    movdqa xmm1, [esi+ecx*2+10h]
01e7b68a: 660f            db     0fh
01e7b68c: 3a0f            cmp    cl, [edi]
01e7b68e: ca068d          retf   8d06
01e7b691: 348e            xor    al, 8eh
01e7b693: 660f6f2e        movdqa xmm5, [esi]
01e7b697: 660f6f5e10      movdqa xmm3, [esi+10h]
01e7b69c: 660f            db     0fh
01e7b69e: 3a0f            cmp    cl, [edi]
01e7b6a0: dd06            fld    qword ptr [esi]
01e7b6a2: 660f6f144e      movdqa xmm2, [esi+ecx*2]
01e7b6a7: 660f6f644e10    movdqa xmm4, [esi+ecx*2+10h]
01e7b6ad: 660f            db     0fh
01e7b6af: 3a0f            cmp    cl, [edi]
01e7b6b1: e206            loop   01e7b6b9
01e7b6b3: e9cd020000      jmp    01e7b985
01e7b6b8: eb06            jmp    01e7b6c0
01e7b6ba: 8d9b00000000    lea    ebx, [ebx+00]
01e7b6c0: 660f6f1e        movdqa xmm3, [esi]
01e7b6c4: 660f6f4610      movdqa xmm0, [esi+10h]
01e7b6c9: 660f            db     0fh      <-- FAULT
01e7b6cb: 3a0f            cmp    cl, [edi]
01e7b6cd: c3              ret
01e7b6ce: 07              pop    es
01e7b6cf: 660f6f144e      movdqa xmm2, [esi+ecx*2]
01e7b6d4: 660f6f4c4e10    movdqa xmm1, [esi+ecx*2+10h]
01e7b6da: 660f            db     0fh
01e7b6dc: 3a0f            cmp    cl, [edi]
01e7b6de: ca078d          retf   8d07
01e7b6e1: 348e            xor    al, 8eh
01e7b6e3: 660f6f2e        movdqa xmm5, [esi]
01e7b6e7: 660f6f5e10      movdqa xmm3, [esi+10h]
01e7b6ec: 660f            db     0fh
01e7b6ee: 3a0f            cmp    cl, [edi]
01e7b6f0: dd07            fld    qword ptr [edi]
01e7b6f2: 660f6f144e      movdqa xmm2, [esi+ecx*2]
01e7b6f7: 660f6f644e10    movdqa xmm4, [esi+ecx*2+10h]
01e7b6fd: 660f            db     0fh
01e7b6ff: 3a0f            cmp    cl, [edi]
01e7b701: e207            loop   01e7b70a
01e7b703: e97d020000      jmp    01e7b985
01e7b708: eb06            jmp    01e7b710
01e7b70a: 8d9b00000000    lea    ebx, [ebx+00]
01e7b710: 660f6f1e        movdqa xmm3, [esi]
01e7b714: 660f6f4610      movdqa xmm0, [esi+10h]
01e7b719: 660f            db     0fh
01e7b71b: 3a0f            cmp    cl, [edi]
01e7b71d: c3              ret
01e7b71e: 08660f          or     [esi+0fh], ah
01e7b721: 6f              outsd
01e7b722: 144e            adc    al, 4eh
01e7b724: 660f6f4c4e10    movdqa xmm1, [esi+ecx*2+10h]
01e7b72a: 660f            db     0fh
01e7b72c: 3a0f            cmp    cl, [edi]
01e7b72e: ca088d          retf   8d08
01e7b731: 348e            xor    al, 8eh
01e7b733: 660f6f2e        movdqa xmm5, [esi]
01e7b737: 660f6f5e10      movdqa xmm3, [esi+10h]
01e7b73c: 660f            db     0fh
01e7b73e: 3a0f            cmp    cl, [edi]
EAX = 020aff28
EBX = 0149afb8
ECX = 00000150
EDX = 01e7b6c0
EBP = 00000000
ESI = 01eb02f0
EDI = 020afee0
ESP = 020afee0
EIP = 01e7b6c9
EFLAGS = 00010206
FPUCW = ffff027f
FPUTW = ffffffff
Crash context:
An instruction not supported by the CPU was executed in module 'nnedi2'.
Pointer dumps:
EAX   020aff28: 7c91e920 00000280 00000138 00000005 0006ffd4 0000012c 01eb0590 00000540
EBX   0149afb8: 00000001 00000001 00000001 00000000 00000000 01eb0050 01ed56f0 01efad90
EDX   01e7b6c0: 1e6f0f66 466f0f66 3a0f6610 6607c30f 4e146f0f 4c6f0f66 0f66104e 07ca0f3a
ESI   01eb02f0: e3e1e0c6 dad3d6d6 b4ccd5dc d5ccb4bc d6d3dadc e0e1e3d6 b8e0c5c6 bcc5b3a3
EDI   020afee0: 000002a0 01eb059c 01e7f8c4 01eb02f7 00000150 0149b090 020aff28 7c802530
ESP   020afee0: 000002a0 01eb059c 01e7f8c4 01eb02f7 00000150 0149b090 020aff28 7c802530
      020aff00: 0149afb8 020aff74 7c80a0db 0149b090 fffffd60 00000150 0149b180 01492140
      020aff20: 000001c4 00000005 7c91e920 00000280 00000138 00000005 0006ffd4 0000012c
      020aff40: 01eb0590 00000540 000002a0 000002a0 000002a0 0149a160 01e7fa35 01f20564
Thread call stack:
01e7b6c9: nnedi2!0000b6c9
01e7f8c4: nnedi2!0000f8c4
01e7fa35: nnedi2!0000fa35
7c92005d: ntdll!RtlFreeHeap [7c910000+ff2d+130]
01e71752: nnedi2!00001752
01e717f7: nnedi2!000017f7
-- End of report
However nnedi2_rpow2(rfactor=2, opt=3) works fine.
