Old 19th September 2012, 06:38   #1  |  Link
maxlapshin
erlyvideo
Add watermark on-fly without transcoding h264
Hi. Is it possible to append some macroblocks to each h264 slice so, that watermark will appear on screen?
I.e. something like "absolutely positioned image with alpha channel".
maxlapshin is offline   Reply With Quote
Old 19th September 2012, 19:32   #2  |  Link
Asmodian
I am pretty sure this is not possible. So many reasons why not.
The more advanced editors allow you to only re-encode around the edit points (they just re-encode that GOP). I think this is as far down that road as you can go though. It isn't possible to only re-encode a slice, or if you did you would be able to notice the line between slices. You cannot just add "extra" macro blocks, you would need to re-encode something.
Old 20th September 2012, 16:02   #3  |  Link
edison
bitmap subtitle ?
edison is offline   Reply With Quote
Old 21st September 2012, 02:13   #4  |  Link
maxlapshin
erlyvideo
bitmap subtitle means adding other stream in the same container. For example add metadata to FLV or add subtitles to MPEG-TS. It can be easily removed and I want to "embed logo" in video stream.
Old 22nd September 2012, 14:36   #5  |  Link
natt
So your criteria is not "easily removed". But if there were a way to add a burned in logo without reencoding existing video and by just adding new blocks, wouldn't it be just as easily removed?
natt is offline   Reply With Quote
h264, watermark
