Old 13th May 2011, 07:34   #7721  |  Link
oddball
Bug report.
Entering 1080p60 in custom display switching in MadVR results in two instances of madHcCtrl in Task Manager. MPC (any version I think) crashes because of this. It only happens on the secondary display. If I open MPC on the main PC display and hit play it only loads one instance of MadVR. 1080p23 only loads one instance on any display. Just tested with 0.58 which does not exhibit this behaviour.
OK I've looked a little deeper and it appears to be that in 0.61 when switching to 60Hz from another refresh rate MadVR is not releasing the previous instance or is loading a new instance of madHcCtrl. If the display is already set to 60Hz it only loads one instance. In 0.58 when it switches there only ever remains a single instance of madHcCtrl.
oddball is offline   Reply With Quote
Old 13th May 2011, 08:10   #7722  |  Link
Qaq
AV heretic
Originally Posted by Andy o View Post
Cyberlink's PowerDVD 9, 10 and 11's decoder can be used in "HAM" mode with madVR to use ATI Stream.
10 is better. And it seems like HAM uses OpenCL technology, not Stream.
Qaq is offline   Reply With Quote
Old 13th May 2011, 08:37   #7723  |  Link
Andy o
I haven't noticed a difference between 9, 10 and 11, I can only do smoothly up to 24p, and that's just barely. Is there a link to more info on this, and how it's using OpenCL?
Andy o is offline   Reply With Quote
Old 13th May 2011, 09:49   #7724  |  Link
Mark_A_W
3 eyed CRT supporter
I don't know which AMD CPU you have, but most modern (since the dual core era) CPUs can decode 1080p H.264. Have you tried ffdshow's ffmpeg-mt decoder (multithreaded)? It has helped me in the past.
If that doesn't help, Cyberlink's PowerDVD 9, 10 and 11's decoder can be used in "HAM" mode with madVR to use ATI Stream and that relieves the CPU a bit, but it doesn't work well for some of us. You can still try it though.
I think most phones can do it these days...
Mark_A_W is offline   Reply With Quote
Old 13th May 2011, 10:01   #7725  |  Link
Qaq
AV heretic
I haven't noticed a difference between 9, 10 and 11, I can only do smoothly up to 24p, and that's just barely. Is there a link to more info on this?
Personal experience only. Links to russian forums won't help to mach I guess. In short words: 10 works a bit better with bad encoded videos.
Some people found HAM showing Bitstream with Nvidia cards. If that's true, HAM doesn't use ATI Stream and what is left? Can't check it by myself.
Old 13th May 2011, 11:39   #7726  |  Link
nlnl
Does Cyberlink HAM mode provide access to hardware deinterlacing (vector adaptive?)?
nlnl is offline   Reply With Quote
Old 13th May 2011, 11:50   #7727  |  Link
pacemaker1000
thanks
i will probably stick with TMT3 and keep the m2ts in its bd file structure
pacemaker1000 is offline   Reply With Quote
Old 13th May 2011, 12:03   #7728  |  Link
pacemaker1000
can someone explain why with no dropped frames or glitches i still get repeat frames every few minutes. ( i dont see them though just notice it in the stats)
Old 13th May 2011, 12:22   #7729  |  Link
nevcairiel
If your display refresh rate is higher then the video frame rate, madVR will need to repeat a frame once in a while to keep sync with audio in check. If your refresh rate is lower then the audio, it'll have to drop frames.
If you do not see them, then don't worry too much about it. Maybe madVR will at some point be able to track repeated frames as well, which would give you an indication if the estimated statistic was right.
Old 13th May 2011, 12:43   #7730  |  Link
pacemaker1000
thanks
my refresh rate for 23.976 is 23.977 so i would have thought that the repeated frames would be a lot less tham every few minutes?
Old 13th May 2011, 12:58   #7731  |  Link
nevcairiel
Every ~9.5 minutes, if my calculation isn't totally off.
Old 13th May 2011, 13:25   #7732  |  Link
pacemaker1000
thanks
should reclock make it better?
Old 13th May 2011, 13:29   #7733  |  Link
nevcairiel
Originally Posted by pacemaker1000 View Post
thanks
If you let ReClock do its job, then yes, it'll make that better.
Old 13th May 2011, 14:04   #7734  |  Link
Qaq
AV heretic
Can't say. In my system for 1080i video CPU load is about ~50%, deinterlacing looks ok, CCC keeps VA stable. You can take 1080i video and check the difference with EVR CP for HAM and DXVA. I didn't try it.
UPD. Look at that post: http://www.avsforum.com/avs-vb/showp...1&postcount=14
Old 13th May 2011, 14:43   #7735  |  Link
VresiBerba
How do you get subtitles when using madVR. I have MPC-HC 3104 (x86) and madVR 0.61 and I just can't get subtitles to work. The .srt file has the same file name and is in the same folder but still it doesn't load, and when I drag and drop the .srt file into the MPC-HC window, playback stops and it says 'cannot render the file'.
Help.
VresiBerba is offline   Reply With Quote
Old 13th May 2011, 23:51   #7736  |  Link
bozokaydin
I am using amd x6 1090t with asus gtx 580 direct cuii on my htpc with lg pk550 full hd tv. i want the maximum possible quality settings for 1080p playback. Are there any hints, twekas, mods that can use full specs of my graphics card about madvr? Thanks.
bozokaydin is offline   Reply With Quote
Old 14th May 2011, 00:36   #7737  |  Link
zamadatix
Is there any way to use frame interpolation with MadVR?
zamadatix is offline   Reply With Quote
Old 14th May 2011, 00:44   #7738  |  Link
fairchild
Yes but you need a powerful system to run MadVR + realtime frame interpolation. (if by frame interpolation you meant something like frame doubling)
Check out InterFrame
MPC-HC/MPC-BE, Lav Filters, MadVR
CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S
fairchild is offline   Reply With Quote
Old 14th May 2011, 05:26   #7739  |  Link
Andy o
madshi, I have 1080i59, 1080p23, and 1080p50 in that order, in the auto rate change options. When I play a 59/60p video, madVR switches to the 23p option. Is it supposed to work that way? I'd rather have it switch to 1080i59. I don't have 1080p59 in the options cause I'd rather have the 29.97 fps videos play at 1080i59, and if I have 1080p59 there, 1080i gets ignored in its favor.
Old 15th May 2011, 04:25   #7740  |  Link
hawkson
What is the minimum system to achieve MadVR and FI such Interframe/SVP?
Please list the least expensive configurations neccessary to achieve Madvr+FI on 1080p
Thanks
Also, which is best bang for the buck for HTPC applications
NVIDIA or AMD?
hawkson is offline   Reply With Quote
