24th January 2016, 22:02 | #35622 | Link | |
I have checked the previous build of madVR I had installed prior to the update - it was 0.80.20. So I have placed it back and rechecked. The issue still exists - queue drops to 0 after a couple minutes of playback. In fact, as you have mentioned, I have updated my GPU AMD drivers about a month ago and probably have not noticed that the issue exists since the CRIMSON driver update. So I have disabled the crossfire and restarted the PC and rechecked the playback - no queue drops - everything is smooth. I have enabled the crossfire back - the queue drops again. So I have uninstalled the crimson driver and cleaned the system from the AMD leftovers with the DDU. Then I have installed the latest crimson 16.1 hotfix drivers without the mew settings panel and the installed the CCC from the latest pre CRIMSON 15.1.1 AMD drivers. The disabled all the advanced video stuff in CCC as I did prior the CRIMSON update and rechecked the palyback with the Crossfire enabled. No queue drops - the render times are about 35 with Chroma Upscaling NNEDI3 128 with no glitches. The rendr back to normal. So my conclusion is that the new AMD CRIMSON edition settings panel, which is lack of the advanced video settings is the source of the issue. It definitely related to the way it handles the crossfire. This info might hopefully be helpful to anyone with the similar issues. Cheers |
25th January 2016, 00:34 | #35623 | Link | |
http://madshi.net/madVR93b.rar Maybe you had 3D enabled, when using an NVidia GPU? That sometimes produces crashes, when using D3D11 presentation. |
25th January 2016, 00:38 | #35624 | Link | |
I installed the latest Crimson 16.1 and the latest pre-crimson catalyst CCC (which is 15.7, not 15.1.1 by the way). 1) The dynamic range option in the old CCC has no effect on Crimson (similar to RadeonMod), so it's still not possible to select RGB Full for MadVR and 16-235 for PDVD or other apps using the Windows renderer. 2) Crimson still crushes white in 3D above 230 with PDVD, so until LAV+MadVR are able to support 3D BDMV/SSIF I have to keep PDVD for 3D Blurays. For anyone not using non-MadVR software it's a good way to get more control and the latest drivers. Back to 14.12 as far as I'm concerned.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
25th January 2016, 01:46 | #35626 | Link |
Definitely an interesting build. My observation is that it's better for MC21 but I have to do some weird stuff to get it to fully work.
With all the options checked in the 3D settings page for madvr.... Play a 3D MKV in MC21....plays in 2D but the OSD says it's D3D11 3D Pause playback, minimize the player Open up the OS display properties and head to advanced You'll see 3D is enabled. Change NOTHING....just close it Go back to MC21 and unpause....I now have 3D that works with or without the MC UI. Crazy!! EDIT: Ok, I did some different stuff and it seems I was wrong. Just pausing, taking it out of fullscreen, and bringing it back to fullscreen and unpausing is all that's needed. Sweet!
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 25th January 2016 at 01:50. |
25th January 2016, 07:52 | #35627 | Link | |
It doesn't crash at all. "Normal" videos play excellent. "Problematic" videos play too. Video starts, stops, resizes without problems. The only remaining problem is that there are two groups of greened-out lines: - bottom group. It's constant and wouldn't be a problem if they were black, not green. - a group on the video image. This group of lines is not constant, it appears on random position and at random time. Have a look at the screenshot. Ignore the size, it's taken via RDP session, image on the TV is just the same. Thank you. Last edited by bbsc; 25th January 2016 at 08:43. |
25th January 2016, 08:49 | #35628 | Link | |
link: madVR93b_Debug Do I still have to test with <v0.90.x |
25th January 2016, 09:35 | #35629 | Link |
Whoever has windows 8.1 and windows 10 , do like that, it boosted my performance in Skyrim from 28 to 60+ . windows 8.1 and windows 10 are bugged with full of bad settings that worked in windows 7 just fine. In windows 7 I got 100+ fps in skyrim. even with LOW everything the FPS stayed 28 , no way it is possible with 970 GTX and 3770K 4.3 Ghz I will get this kind of fps. This setting from here http://www.ibtimes.co.uk/windows-10-...-speed-1516413 Fixed the issue. I will do it on my laptop 8.1 too and see how it improved things. it might fix stupid bugs in the media player that we use, because we use Exclusive mode and it's like gaming, should work the same. And don't forget to disable the Xbox DVR . from Start > Xbox DVR > Log in your account without password (you can skip the password) > Settings > Xbox DVR Recording .. > disable .
Should fix a lot of input lag and other things too. Last edited by x7007; 25th January 2016 at 09:39. |
25th January 2016, 17:39 | #35631 | Link |
http://madshi.net/madVRbbsc2.rar Yes, please. It's important to know if it's a new problem and which exact build introduced it. Well, unfortunately I don't have any idea about that one. Nobody else has reported this specific problem yet. I would ask for a debug log, but if it only occurs after an hour of playback, by that time the debug log will probably have filled the rest of your harddisk free space, no matter how large it is... |
26th January 2016, 01:33 | #35634 | Link |
I'm having issues getting 3D to work. I'm a noob so maybe I missed something.
1) I have windows 10 and the latest 6th generation NUC with Intel Iris Pro 540 Graphics. (NUC6i5syk). 2) I installed madVR v.0.90.3 and the latest LAV filters fromt he nightly builds (0.67.0-65). This is what I did: 1) I set the display control panel to have 3D "on". 2) In madVR I turned off "exclusive mode". I enabled "use Direct3D11 for presentation (is this correct?) and also check marked "present a frame for every VSync" (Is this a needed step too?) 3) I didn't touch any settings in madVr's stereo 3D area besides the default that si checked "enable stereo 3d playback" When playing a 3d mkv made using makemkv, I see that LAV filters is using the "msdk mvc" decoder. on playing a movie, the projector correctly switches resolution to 1920x2205 for framepacked 3D. However the image that shows up is frozen and the movie doesn't play any further. At that point I cannot exit out of my MPC-BE player and need to kill it using the task manager. I'm stuck because it looks like it all correctly switches to 3d and I have a proper 3d image on screen, but it is frozen and refuses to play the movie. I also tried setting my scaling algorithms to the most basic but still same issue. Any advice what I'm doing wrong or what step I'm missing? |
26th January 2016, 09:52 | #35635 | Link |
Problem with autodetected black bars
Hi!
I'm trying to run a automatic CIH setup by cropping the bottom and top part om my ~2,37:1 screen, using only an active screen area of 1920x810, but I cant get it to work. By work I mean always setting the height of the active area of the image to 810 pixels, unless the AR is wider than 2,37:1 of course. What i've done is: Screen config: Define visible screen are by cropping masked borders: 135 bottom and 135 top. Zoom control: [x] automatically detect hard coded black bars [x] zoom small black bars away [x] crop black bars In mpc-hc the video frame is set to touch window from inside. For now the only option that seem to do anything is "if there are big black bars ... zoom the bars away completely", but this option also crops bottom and top content from 16:9 content and doesn't respond to changes in AR in a movie at all. Am I missing something? Other than not having to manually set the zoom for cinescope content within a 16:9 video I would be happy to be able to watch grand budapest hotel showing a minimum of black bars throughout the movie. I'm using Windows 10, MPC-HC, Madvr v0.90.3 and a Sony vpl-hw20 (which doesn't have a lens memory function). |
26th January 2016, 11:03 | #35637 | Link | ||
One more thing to test would be to run natively encoded cinemascope, 16:9 and 4:3 movies (without any black bars inside of the encoded video area), just to check whether the video is zoomed correctly in your setup then? FWIW, with Budapest Hotal don't always expect instant detection of new black bar configurations. Depending on the situation detection *can* be instant, but it can sometimes also take 10-15 seconds. Once one specific black bar configuration was detected, though, switching back to it again should be instant then. Hmmm... Doesn't that only affect AR and not the whole zoom? Not sure, though. |
26th January 2016, 12:12 | #35638 | Link | |
I'm not sure whether I've applied this on my laptop that has SSD (win8.1) but I'll check it this evening and if not I'd definitely set this! Thanks for mentioning!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
26th January 2016, 12:28 | #35640 | Link | |
