30th December 2004, 18:02 | #201 | Link |
1. Could you send me the rebuilder.ini and rebuilder.inf files?
I can't reproduce the crash. PM me for details. 2. Small VodID doesn't take much space, so I prefer leave them untouched, as DVD-RB decided. To change their bitrate, you have to uncheck "hide vod-id..." as you noticed 3. 100% doesn't means "no compression". You will do a CCE pass, using the same bitrate of the original cell. If you want the original cell, it's not simple! You have to demux the original .m2v stream from the VOB. RB-Keeper did this job, but I think it's not compatible with current DVD-RB. 4. Yes, duration is wrong. As I'm in PAL land, I've a question: is it always wrong? DVD-RB reports always a 23.976 framerate, so RB-Opt is wrong in calculation. Are DVD's *ALWAYS* at 29.97, so it's safe to use always a framerate of 29.97? The same thing happens for the external player. DVD-RB uses the right framerate in remuxing, so the output will be always fine. 5. Linking Vob-ID is useful (and "mandatory") if you tweak single cells, but it cause no harm. It can be used to group items, and doesn't mess navigation. It affects only the bitrate distribution. |
30th December 2004, 19:12 | #202 | Link | |
DVD-RB User
(if you are not a vip, use the ReJig-Mode.) after encoding copy them back. don't forget to set the related cells in rb-opt to 100%
m00! |
30th December 2004, 20:56 | #203 | Link | |
31st December 2004, 01:31 | #204 | Link | ||||
With this new RB 0.70 "No Compression" mode, could RB-Opt apply that to only certain Vob-IDs while still compressing others? Quote:
Or, could RB be modified to save the original frame rate somewhere like rebuilder.ini so that RB-Opt can read it? Quote:
31st December 2004, 10:53 | #205 | Link | |
31st December 2004, 10:58 | #206 | Link | |
31st December 2004, 14:06 | #207 | Link | |||
Size is small and you'll have no problems. Quote:
19th January 2005, 13:25 | #208 | Link |
Is Rb-Opt working with Dvd-Rb 0.70+?
My question refers that I did some encodes tweaking the end credits bitrate and after saving the changes in Rb-opt, I opened the .Ecl in notepad and noticed that the avg bitrate for this cell was not modified. I linked all Vts in rb-opt and decreased bitrate of the last cell to 1800 avg. and when checked in notepad still was over 2800. Other parameters like CCE's filters, quality precission, bias were correctly modified and saved except the one concerning bitrates.
Tks. |
19th January 2005, 21:27 | #209 | Link | |
Re: Is Rb-Opt working with Dvd-Rb 0.70+?
Do you find the modified value (1800)? It's the fastest way to check. I haven't tested RB-Opt with the newer versions of CCE. Probably I'll post an updated version next week (now working to ECLPro...) |
2nd February 2005, 17:47 | #210 | Link |
RB-Opt v0.16
This is an intermediate version, just with a bugfix and initial
support for CCE 2.70 (OPV mode). I hope for the weekend to have a full CCE 2.70 support. CHANGES: - Added compatibility to CCE 2.70 in OPV mode - Fixed a bug in "Reset Bitrates" options - Added QLB matrix (used in QuEnc by Nic and Dragongodz) KNOWN ISSUES - Filters don't work properly with CCE 2.70. Please, avoid filters usage with this CCE version. - Quantizer Characteristics for CCE 2.70 limited to 64 (and not to 100). RB-Opt v0.16 Mirror by DVDRebuilder.com |
2nd February 2005, 19:50 | #211 | Link | |
Banned
a great tool. As I mentioned in another thread, I noticed some undersizing issues at low Q-values using Rebuilder with CCE 2.70. Using RB-Opt, the same project came in perfectly at 4.32 Gb. |
2nd February 2005, 21:00 | #212 | Link | |
Master of Chaos
Wizards First Rule: People are stupid. They will believe anything. Either because they want it to be true, or they fear that it is true. |
12th February 2005, 08:59 | #215 | Link |
I know of just one program to check matrices:
Restream Anyway it needs the .m2v or .mpv file, so you have to demux a VOB to check the matrices. The format of the eclpro matrices is simple: it's plain text starting with a tab, and then a row of the matrix. Example: Code:
08 16 20 23 27 30 32 34 16 16 23 24 29 31 34 38 20 23 27 28 30 35 38 40 23 24 28 29 35 39 40 44 27 29 30 35 39 42 45 50 30 31 35 39 42 46 54 59 32 34 38 40 45 54 62 72 34 38 40 44 50 59 72 84 17 19 21 23 25 27 29 31 19 21 23 25 27 28 29 33 21 23 25 27 29 30 32 37 23 25 27 30 31 34 40 45 25 27 29 31 38 46 54 60 27 28 30 34 46 58 72 74 29 29 32 40 54 72 90 100 31 33 37 45 60 74 100 124 The second 8 lines are the non intra matrix. |
12th February 2005, 10:11 | #216 | Link |
thanks robot1 for your answer
i might give you this link : http://www.dvdcreation.net/download.php?id=4776 Matrix Extractor v1.10 is really great and allow extracting the matrices from a vob file and export them in the registry or in plain text before encoding i've used this setting in my rebuilder.ecl file qmat= 08 08 09 11 13 13 14 17 08 08 11 12 13 14 17 18 09 11 13 13 14 17 17 16 11 11 13 13 13 17 18 20 11 13 13 13 16 17 20 24 13 13 13 16 17 20 24 29 13 12 13 17 19 23 28 34 12 13 17 19 23 28 34 41 08 08 08 09 09 09 09 10 08 08 09 09 09 09 10 10 08 09 09 09 09 10 10 10 09 09 09 09 10 10 10 10 09 09 09 10 10 10 10 11 09 09 10 10 10 10 11 11 09 10 10 10 10 11 11 11 10 10 10 10 11 11 11 11 in the vob files created, the matrices are 8 8 8 8 8 8 8 9 8 8 8 8 8 8 9 9 8 8 8 8 8 9 9 8 8 8 8 8 8 9 9 10 8 8 8 8 8 9 10 12 8 8 8 8 9 10 12 15 8 8 8 9 10 12 14 17 8 8 9 10 12 14 17 21 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 i'll try to investigate, if you could give me a hint edit : i've used cce to encode Last edited by kheops; 12th February 2005 at 10:14. |
13th February 2005, 02:06 | #220 | Link |
RB-Opt v0.16Beta
An EXCELLENT and friendly tool...
I couldn't get right output size on my In Extremo DVD, but once I used RB and set higher bitrate I hit 4.6Gb size. I was lucky, but that's also a proof this tool works!
This Planet Earth Is Great To Visit, But You Wouldn't Want To Live There ... |
