Old 5th October 2015, 01:11   #33361  |  Link
Sunset1982
got a GTX 960 too. Could help with testing some settings...
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 5th October 2015, 01:56   #33362  |  Link
Anima123
There's power state issue by using madVR, when I switched the image doubler from NNEDI3 64 neurons to super-xbr, there's a lot of dropped frames, and the present queue cannot be filled.
Using less gpu-intensive algorithms can decrease the speed of the fan, and hence the noise. How would I do to let the GPU chose the power-state correctly?
Anima123 is offline   Reply With Quote
Old 5th October 2015, 01:57   #33363  |  Link
seiyafan
Currently when I use ctrl-J for stats it only shows the present time but not rendering time, how do I make rendering time to show up?
Thx!
seiyafan is offline   Reply With Quote
Old 5th October 2015, 02:05   #33364  |  Link
leandronb
Posts: n/a
hi guys. i am using madvr version 0.88.16.
i am having a problem with a single avi file.
i use my display mode swith like this:
1080p60, 1080p59, 1080p50, 1080p30, 1080p29, 1080p25, 1080p24, 1080p23
my avi file is at 29,970fps but when i go fullscreen at madvr it changes the screen refresh rate to 24p, so the video is unwatchable.
when i delete all the lines and leave only 1080p29 it go to correct screen refresh rate. but if i add 1080p29, 1080p23, it prefer 1080p23.
anyone know how to solve this?
Old 5th October 2015, 02:05   #33365  |  Link
aufkrawall
What GPU?
Old 5th October 2015, 02:29   #33366  |  Link
Anima123
Originally Posted by aufkrawall View Post
What GPU?
nVidia 880M
Old 5th October 2015, 04:39   #33367  |  Link
Asmodian
Thx!
Did you change any of the "when and how shall the GPU be flushed:" settings?
You need a 'wait' step for "... after last render step" to be able to display rendering times.
Have you tried changing the flush options? Using 'flush & wait (loop)' for "... after last render step" might help.
madVR options explained
Old 5th October 2015, 05:18   #33368  |  Link
har3inger
Subtitles glitch out now. When a file is first launched and full-screen'd, subs don't render until you right click the video frame or do something else to kick it out of full screen exclusive. From that point on they render fine.
Problem is fixed upon reverting to 0.89.5
Edit: This is on xySubfilter/LAVsplitter/MPCHC btw. Running in D3D11 render path, using FSE, with 64 bit build.
har3inger is offline   Reply With Quote
Old 5th October 2015, 05:20   #33369  |  Link
Warner306
Originally Posted by Magik Mark View Post
Warner306, Excellent guide you got there. Is it possible to update this using GTX 960? Thanks again
I have two guides I maintain. The intent was to show settings for a low, medium and high scenario. I don't think it is possible to log settings for a large number of graphics cards because there are too many variables involved and it would become too convoluted. Thanks for the offer, though.
Old 5th October 2015, 06:19   #33370  |  Link
krille
Subtitles in Potplayer does not work with 0.89.6.
krille is offline   Reply With Quote
Old 5th October 2015, 06:45   #33371  |  Link
Telion
Hi madshi!
I have a little request regarding toggle debanding keyboard shortcut behaviour. Let me explain a bit first. I usually use either a high debanding or no debanding during several files in a series. If I'd switch through GUI, it's all plain and simple - the radiobutton is always at "high" position and I can just toggle only the checkbox. Obviously I want to speed up things by using keyboard shortcuts, but the different story begins here. For example, I start from debanding at "high" but off and want to turn it on. So I press Ctlr-Alt-Shift-A twice (OSD shows off->high) and then hit F2 to save. Everything goes as expected. Afterwards, I want to switch it back off and repeat the same sequence, OSD showing high->off. But now it turns out that not only the checkbox was toggled - the radiobutton was also set to "low" value, so next time I'd need to press Ctlr-Alt-Shift-A four times, going all the way through off->low->medium->high. I humbly ask you to change this behaviour so that the radiobutton won't get reset from its initial value if the final result of keypresses is "off" at the moment of releasing all keys in the shortcut combination. It's not that I'm too bothered with two extra keypresses - I just want to get used to the same keypress sequence for toggling debanding on and off and pay no attention to its initial state or OSD.
Telion is offline   Reply With Quote
Old 5th October 2015, 07:38   #33372  |  Link
dimitrik
On the latest nvidia driver 355.98 I got a black screen with FSE and full screen windowed mode. I tried all settings but got nowhere.
I downgraded to the last "safe" driver which according to the forum was 353.49 and all is well again.
Did anyone else have this issue?
Nvidia GTX 660Ti.
dimitrik is offline   Reply With Quote
Old 5th October 2015, 08:56   #33373  |  Link
wanezhiling
latest PotPlayer 1.6.56603 beta (02/10/2015), default settings
latest madVR 0.89.6, default settings
no any problem: http://i.imgur.com/9ZT7HZM.png
Old 5th October 2015, 09:59   #33374  |  Link
krille
I am using the latest stable version of Potplayer 64 bit.
Old 5th October 2015, 10:42   #33375  |  Link
wanezhiling
http://i.imgur.com/xmQky03.png
Still works fine.
Initialize your pot or madVR, then try to find where the problem is by yourself.
Old 5th October 2015, 10:47   #33376  |  Link
rafi.hamid
Warner306
I appreciate, and have some questions
with Windows 10 64bit and TV Panasonic TX-55AX630 it is necessary to install ReClock or its fine without it?
and what about external LAV filter I need it or the integrated lav filter from htpc 64bit is OK?
Sent from my iPad using Tapatalk
rafi.hamid is offline   Reply With Quote
Old 5th October 2015, 10:49   #33377  |  Link
rafi.hamid
sorry I mean mpc-hc 64bit
Old 5th October 2015, 11:49   #33378  |  Link
jkauff
ReClock is 32bit only.
Old 5th October 2015, 12:04   #33379  |  Link
krille
Still works fine.
Problem solved, my mistake. Sorry...
Old 5th October 2015, 14:22   #33380  |  Link
panetesan2k6
Still works fine.
One question: That OSD is from PorPlayer or I can get the same in MPC-HC? I'm interested in monitoring CPU and GPU usage.
Thanks
panetesan2k6 is offline   Reply With Quote
