Old 7th November 2019, 05:28   #17681  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
So I'm doing some more 4K encoding today, and I have been having some problems with the connection to some of the DE servers, in the other room....wasn't happening yesterday....
I got these errors, and wondering what might be causing them :-
[7/11/2019 13:35:33] TCPClient7 raised exception while attempting to sent command.(Not Connected)
[7/11/2019 13:35:47] TCPClient10 raised exception while attempting to sent command.(Not Connected)
[7/11/2019 13:40:00] TCPClient8 raised exception while attempting to sent command.(Not Connected)
[7/11/2019 13:40:00] TCPClient7 raised exception while attempting to sent command.(Not Connected)
[7/11/2019 13:46:06] TCPClient12 raised exception while attempting to sent command.(Not Connected)
[7/11/2019 13:46:30] TCPClient12 raised exception while attempting to sent command.(Not Connected)
[7/11/2019 13:56:27] TCPClient13 raised exception while attempting to sent command.(Not Connected)
[7/11/2019 13:57:53] TCPClient9 raised exception while attempting to sent command.(Not Connected)
But it seems to be going OK now, I think it takes a while for the process to "warm up".
Another thing I've noticed that might be associated with this, is some chunks will get to a certain %, and just stall there
And with all the chunks "flashing" is some way of showing that they are processing, it's a bit hard to focus in on which ones are doing this.
Not sure if the chunk "line's" are suppose to flash, but it would be a lot easier on the eyes if maybe they changed font size and/or colour, and NOT flash....just as well I'm not "epileptic".
And I have a feature request for chunks....it would be handy to have a small display of how many "chunks" are being processed, instead of having to count them.
And to top it off, how about some more DE servers, say another 4, at least. Need all the help I can get, and I have more pc's I could add to the 4K process.
And no I don't like the idea of running separate sessions with different pc's, that really doesn't speed up my process...I just want to get it done one "system", as fast as possible !!!
I do smaller basic encodes on separate pc's.
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 7th November 2019, 09:05   #17682  |  Link
mparade
Just use builtin in windows.
Could you suggest something in my case for the VPN connection to work? Admin would like to help if problem is on "his side".
Thank you for the help.
mparade is offline   Reply With Quote
Old 7th November 2019, 09:44   #17683  |  Link
GZZ
You should definitly look in your Windows system log and see if your netcard is disconnecting/reconnecting. I had a issue like yours when I had a bad driver for my 10Gbe netcard, upgrading to a newer driver helped. I think its more of a network issue then a problem in the application.
GZZ is offline   Reply With Quote
Old 7th November 2019, 10:35   #17684  |  Link
Pauly Dunne
Grumpy Old Man.
Originally Posted by GZZ View Post
You should definitely look in your Windows system log and see if your netcard is disconnecting/reconnecting. I had a issue like yours when I had a bad driver for my 10Gbe netcard, upgrading to a newer driver helped. I think its more of a network issue then a problem in the application.
I am only using the onboard 1 Gbe NIC's for DE, I doubt that there is any advantage of using a 10 Gbe, however, I am only using the Windows NIC drivers, so I will endeavour to update ALL the Intel drivers, so thanks for the suggestion.
I have to agree that it's certainly a network / cable problem, I had to swap out a patch cable yesterday, as it was dropping in & out, causing problems.
Just out of interest, what 10 Gbe NIC's are you running ?? do you use RJ45 or SFP+ connections ??
I'm gradually setting up a 10 Gbe LAN, and mainly using Mellanox NIC's. (but not for RB)
Old 7th November 2019, 13:26   #17685  |  Link
Ryushin
Ryushin's Avatar
I think the first thing is to verify that you can connect to each process. From your Ripbot machine, install nmap (they have a windows version).
Then using nmap, see if the Encoding Server ports are open on your other machines. I would run command like this from Linux:
nmap -p 1000,2000,3000,4000 192.168.9.7
My results look like this:
Starting Nmap 7.80 ( https://nmap.org ) at 2019-11-07 05:22 MST
Nmap scan report for taffy (192.168.9.7)
Host is up (0.0023s latency).
PORT STATE SERVICE
1000/tcp open cadlock
2000/tcp filtered cisco-sccp
3000/tcp filtered ppp
4000/tcp filtered remoteanything
Nmap done: 1 IP address (1 host up) scanned in 1.25 seconds
I'm running one Encoding Server on that client. The scan shows port 1000 as open, and the other ports as filtered. Filtered will be either there is nothing listening on those ports or a firewall has filtered them.
That will at least tell you if you have some kind of network problem.
Ryushin is offline   Reply With Quote
Old 7th November 2019, 13:39   #17686  |  Link
byteshare
ByteShare
byteshare's Avatar
Add "/restart-if-no-progress" to your startup script for the servers. Problem is that FFMPEG and/or AVISynth can get hung up.
Old 7th November 2019, 14:43   #17687  |  Link
Pauly Dunne
Grumpy Old Man.
Hi byteshare,
I DO have that on EVERY PC, and tbh, I don't think it works that well.
Old 7th November 2019, 14:48   #17688  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Hi byteshare,
Do ffmpeg.exe and x26x.exe still use cpu when this happens?
Old 7th November 2019, 22:25   #17689  |  Link
GZZ
First off DE encoding wont benefit from 10gbe at all and you properly need better cable (cat6a). I use it to gain better performance from my synology NAS. On avg it gives me 300-400mb/s and up to 700mb/s. So really nice when moving large uhd/bluray files.
I use RJ45 cable and a 8 port buffalo switch (mp2008).
Old 8th November 2019, 00:58   #17690  |  Link
Pauly Dunne
Grumpy Old Man.
Yes, I think I had mentioned already that 10 Gbe would be no advantage to RB....
I'm using SFP+ cables & NIC's, with a MikroTik 8 port switch.
You didn't mention what NIC's you're using...
Old 8th November 2019, 01:03   #17691  |  Link
Pauly Dunne
Grumpy Old Man.
TBH, that didn't even enter my mind, to check !!
I wouldn't really know what I was looking for, anyway.
I just watched the stalled chunk/server, for a couple of minutes, and when it hadn't progressed, I simply stopped it, and let another server take over.
I DID (once) have pop error msg stating that Encoder Stalled, and I think it was in relation to FFMPEG or similar, didn't stay up for long.
I'm using the very latest RB build, and I am going to update all my NIC drivers today, probably won't affect this...but good to do.
Old 8th November 2019, 06:24   #17692  |  Link
GZZ
Asus XG-C100C in my desktop and Intel x540-T2 in my nas.
Old 8th November 2019, 10:28   #17693  |  Link
Pauly Dunne
Grumpy Old Man.
So just a simple P2P connection between them, then.
Are you planning to expand to other pc's ??
To get the best out of 10 Gbe, you need fast drives @ both ends.
I'm just starting out with 10 Gbe, and the transfer speeds vary a LOT.
Old 8th November 2019, 18:04   #17694  |  Link
byteshare
ByteShare
byteshare's Avatar
Update today, MKVTooNix update to 39.0.0, core 2019.11.08, and scripts 2019.11.08.
@Atak Anything that could affect us or more along the lines of bug fixes?
Old 8th November 2019, 21:43   #17695  |  Link
GZZ
10GBE is more the for the fun of it. But I got 1GBE Fiber internet connection and if I use it close to 100%, then copying a file over the network will make the download/upload suffer. No problem with that on 10GBE. For the moment I dont plan on other expansions of my network.
Got 2 SSD in Raid 0 for Encoding and processing files. It gives me 1200mb/s of read/write speed. On my nas its just 4x10GB Ironwolf disc in Raid 5 (can be expanded to 8 disc).
Old 9th November 2019, 00:45   #17696  |  Link
Pauly Dunne
Grumpy Old Man.
BIG changes in Encoding Client for server "control"
Can't wait to check this out
Old 9th November 2019, 11:56   #17697  |  Link
mparade
PORT STATE SERVICE
Thank you very much for the help.
I got this result:
Nmap scan report for amd-tr4.alllight.hungary (192.168.2.24)
Host is up (0.012s latency).
PORT STATE SERVICE
2000/tcp open cisco-sccp
3000/tcp open ppp
4000/tcp open remoteanything
Nmap done: 1 IP address (1 host up) scanned in 2.33 seconds
Old 9th November 2019, 12:10   #17698  |  Link
Atak_Snajpera
I got this result:
You were supposed to do that test from work-pc to home-pc. (192.168.88.178)
Old 9th November 2019, 18:52   #17699  |  Link
mparade
From server machine:
Starting Nmap 7.80 ( https://nmap.org ) at 2019-11-09 18:52 Közép-európai téli ido
Note: Host seems down. If it is really up, but blocking our ping probes, try -Pn
Nmap done: 1 IP address (0 hosts up) scanned in 3.21 seconds
screenshot about it:
http://mammutmail.com/hu/download/aa...1b3c97600352e6
Old 9th November 2019, 19:47   #17700  |  Link
Atak_Snajpera
Ask your admin for help. I guess that your vpn has been configured to block uncommon ports (1001,1002,1003 and so on). Weird stuff...
Next time use www.postimage.org site for images because that full screen adv is driving me crazy
