1st October 2003, 02:48 | #21 | Link |
Tell me how you created the input to Decomb and also post your AVS script. Did you for example use DVD2AVI with force film enabled? Decomb should not cause a shortening of the movie length. Something is wrong with your process.
1st October 2003, 10:54 | #22 | Link |
Elvis Imitator
After reading some posts about hybrid NTSC clips on the forum I first checked the clip with DVD2AVI. It was mainly FILM, about 88%. Therefore I did not check "Forced Film" and made the project file. I checked the video with virtual dub. It turned out to be telecined. So I wrote that Avisynth script according to the helpfile of Decomb:
LoadPlugin("D:\Program Files\AVISynth 2.5\Decomb500.DLL") LoadPlugin("D:\Program Files\AVISynth 2.5\MPEGDecoder.DLL") MPEGsource("F:\Ripps\THX - Wow.d2v") ConvertToYUY2() Telecide(guide=1,order=1) Decimate(mode=3,threshold=1.0) ConvertFPS(25) BilinearResize(720,576) I also tried TMPEG. Made inversed telecined (both ways: 24fps smoothness prioritized and 24fps motion prioritized) and with 25fps for the destination video. This time the PAL clip had the same duration as the NTSC original and the audio also fit, but the video was choppy which was extremely noticeable in fast motion scenes. I also tried to do only decomb with avisynth and change the framerate afterwards with VirtualDub. That had also the effect, that the final PAL clip played absolutely smooth, but was 20 seconds shorter and I couldn't get audio in sync. |
