13th February 2012, 09:09 | #322 | Link |
Instead of DitherPost(), use Dither_convey_yuv4xxp16_on_yvxx(). Check this section of the Dither manual for the encoding command line. If you want straight dithering to 10 bit from DitherPost, see this post.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
15th February 2012, 22:13 | #323 | Link | |
I am confirming MT stable running QTGMC. As others have noted, the key to getting this to work right was setting SetMemoryMax. Once I set it to 512, no more rainbow glitch screens. I have Win 7 x64 and 16GB RAM installed, but parameters 1024 and up resulted in errors; I have not tried anything between 512-1024 yet.
Set to 512, the speed increase is roughly double that of regular Avisynth. Used to get 10-13FPS, but now getting about 22-26FPS on DV source 720x480. Running Win7 x64 Ultimate. 2.58 x86 Avisynth was the base install; 2.6 x86 MT avisynth.dll copied to SysWOW64 and system32 (don't know which is redundant; conflicting install instructions). Core i5-2500k, OC'ed to 4.4Ghz, everything is running swimmingly. Hope this data point helps. My exact script: Quote:
17th February 2012, 17:02 | #324 | Link | |
The Black Reaper
You are missing SetMTMode(2) before QTGMC() for your script, might want to double check your script with the first post in the QTGMC thread. |
21st February 2012, 10:20 | #328 | Link | |
typo lover
my repositories |
1st March 2012, 02:50 | #330 | Link |
I have a question. I am just wondering why the encoding process never fully uses all the cores of the CPU and the threads.
I set my MT like this SetMTMode(2,8). I thought the encoding is gonna make use of the four cores along with the hyperthreading, but when I looked at the CPU usage, it was only 18% - 20% |
1st March 2012, 04:43 | #331 | Link | |
warpsharpened
8th March 2012, 22:06 | #333 | Link |
am i missing something here, the mt.dll for avisynth 2.6 is not in the package file?
update: I was trying to multithread fft3dfilter, but the only usage i've found is through MT("....."), how do i do this? Last edited by lansing; 8th March 2012 at 22:27. Reason: update |
9th March 2012, 18:29 | #335 | Link |
AviSynth 2.6.0 MT installer -> http://www.mediafire.com/?6vq1i35kz9cqjl1
Installer source files -> http://www.mediafire.com/?g7ex29zb0c1k4xt
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th March 2012 at 13:53. |
10th March 2012, 21:36 | #337 | Link |
you can also try hqdn3d istead of ff3dfilter.
11th March 2012, 14:55 | #339 | Link |
With this version of Avisynth yesterday I tried to load a plugin for VirtualDub with LoadVirtualDubPlugin the way I've always done and then VirtualDubMod crashes, what is that?
In 2.5.8 MT I could perfectly. I'll be doing something wrong or need to install anything? Last edited by GMJCZP; 11th March 2012 at 15:28. |
