20th August 2011, 05:52 | #12741 | Link |
JDobbs, about the aften error:
I've remember first trying this on an earlier build using "the prestige" and ended up with the same error message. Since then I kept HD audio. FWIW, here's the ini in case I have something set wrong. In the audio encoding options in setup I believe I had the "do not re-encode AC3 (bluray only)" and "use 448 kb for AC3 encoding" checked. [Options] VERSION=0.38.0.9 MODE=0 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 TARGET_SIZE=23500 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 AUTO_BLANK=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=50500 [Paths] SOURCE_PATH=R:\ WORKING_PATH=D:\TEMP\BD_REBUILDER\WORKING FOLDER\ Last edited by sonate; 20th August 2011 at 06:39. |
20th August 2011, 11:46 | #12742 | Link | |
As I always demux the movie through HD-DVD Blu-Ray Stream Extract to check which language is Spanish (Castillian) and Spanish (Latino), (as lately almost every BluRay comes with both) and the same for the subs, I think I forgot to check movie only and that gave me the BluRay result. In any case, I will check it later. Thanx again |
20th August 2011, 13:36 | #12743 | Link |
CORE i7 and SDD
HI
i have a new PC : I7 intel 2600 K @overclocking a 4.43 ghz 16 mo ram and sdd hyper 240 go i'm watercooling I m' tow 2 pass in slow mode with CRF ABR diseabled (it' s the best mode ?) i dont understand why my eight core Cpu are only 30% load ? cpu is 44 % fps 72.4 in process in video configuration in FFDSHOW.. : what's the best codec libavocdec for avc or ffmpeg ? in audio configuration in FFDSHOW what's the difference between liba 52 en libavcodec it important ? thanks for you tips |
20th August 2011, 13:50 | #12744 | Link | |
The two MPG decoder options just use different libraries within FFDSHOW. From my experience I don't see any difference between "libavcodec" and "libmpeg2" in terms of speed or quality. But that could change depending upon the processor -- so I'd suggest you try both. Of course the only time it will be used is when your sources is MPEG-2. As for "liba52" and "libavcodec" for AC3 -- I've always left it at the default (liba52) so I can't really comment. I'd guess it'll be more-or-less the same answer. |
20th August 2011, 14:07 | #12745 | Link | |
20th August 2011, 16:00 | #12746 | Link |
It should be turned on, right?
I'm running a few other movies to see if this happens all the time. I set the output size to something above 50 gb so I wouldn't have to wait for a video re-encode. I'm assuming this won't have any bearing on the command to convert HD audio to AC3, and you will tell me otherwise if my assumption is wrong. |
20th August 2011, 18:48 | #12747 | Link |
Well interesting........ tried Deja-vu no error message but the application didn't continue after BD reb said audio encoding started. Question, do I need to install another encoder for the directshow workaround? the applicable avs: #Created by BD Rebuilder - v0.38.09 (beta) LoadPlugin("D:\Temp\BD_Rebuilder\tools\nicaudio.dll") audio=DirectShowSource("D:\TEMP\BD_REBUILDER\WORKING FOLDER\WORKFILES\AUD_00014_4352.mkv").Amplify(1.2) audio = (AudioChannels(audio) > 6) ? GetChannel(audio,1,2,3,4,7,8) : audio ConvertAudioTo16bit(ResampleAudio(audio, 48000)) Also tried "midnight express" which recoded the Dolby trueHD into AC3 480kbs perfectly. So at least now I know it works on my system. |
20th August 2011, 22:01 | #12748 | Link | |
No you shouldn't need anything extra for the workaround. Will the MKV file (AUD_00014_4352.mkv) play if you double-click it? Last edited by jdobbs; 20th August 2011 at 22:05. |
20th August 2011, 23:40 | #12749 | Link | |
No error message, and I aborted and restarted a few times to see what would happen. The .mkv file does play. I'd post an image of the folder, but Doom9 is rejecting every image file I try to upload. |
21st August 2011, 00:24 | #12750 | Link |
No problems here with the new 38.0.9 build . Three Blu's copied thus far with it (movie only) with DTS-DTS/HD everything went perfect and Blu's looks great . Seems the new build de-codes faster too (maybe my imagination ?) , but my files sizes are all about the same and the decoding just seemed to blaze through these last few movies (with no firmware update on my burner) .
Anyway ....Cudo's to the new build ! |
21st August 2011, 04:10 | #12751 | Link | |
21st August 2011, 04:16 | #12752 | Link |
Incredible Jdobbs! Expect another donation soon then. I've been wondering all day what I'm gonna do with "Drag me to Hell". They didn't employ seamless branching, so there are 2 very large titles on the disc. I'd prefer blank the theatrical title
21st August 2011, 05:52 | #12754 | Link |
THat's exactly what I thought. Pretty poor. Perhaps lazy. Don't know about the coding involved. It is currently an obstacle for people who like to backup too. Perhaps that's why. Yes, they are independent. That's confirmed. I looked right at the files. They should have used seamless branching, and added some more extra features. I love gag reels!
21st August 2011, 08:27 | #12755 | Link | |
Regarding "Drag Me To Hell"
A review from "Blu-ray.com" seems to indicate that MOST scenes are different in the two versions (as opposed to many other two-version videos with some additions only to a few scenes), making it necessaryto have two completely separate versions on the disc:
21st August 2011, 17:13 | #12759 | Link |
Both unrated and theatrical versions appear on many titles. That's why they segment the movies - so they can use segments in both, insert additional segments or leave out segments in the various versions without duplicating the footage.
21st August 2011, 21:27 | #12760 | Link | |
What is unusual is that in the example he gave they aren't segmented -- there are two complete movies with no shared segments. Last edited by jdobbs; 21st August 2011 at 23:21. |
