1st August 2011, 18:35 | #12582 | Link | |
[Edit] Hmm... it is showing incorrectly on my other system, though. Ugghhh.... Ok, I'll do some more testing. It must be something in the difference between 64 bit and 32 bit. [Edit again] Yep. The size that I'm checking on the 32 bit system was the "size on disc" instead of the actual size. I've fixed it (again) for the next release. Last edited by jdobbs; 1st August 2011 at 18:41. |
1st August 2011, 18:50 | #12583 | Link | |
1st August 2011, 22:15 | #12585 | Link |
WARNING: Failed to integrate Subtitle_01
Just tried 38.05 with The Tourist Region A. I first tried this with 38.02. Here's the log:
[15:26:30] BD Rebuilder v0.38.05 (beta) - Source: THE_TOURIST - Input BD size: 21.82 GB - Approximate total content: [01:43:28.192] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:26:32] PHASE ONE, Encoding - [15:26:32] Extracting A/V streams [VID_00000] - [15:37:45] Reencoding: VID_00000 (1 of 1) - [15:37:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 148,848 frames - Bitrate: 5,369 Kbs - [15:37:45] Reencoding: VID_00000 - [16:32:12] Video Encode complete - [16:32:12] Reencoding audio tracks (if req'd) - [16:35:14] Multiplexing M2TS [16:35:14]PHASE ONE complete [16:35:14]PHASE TWO - Rebuild Started - [16:35:14] Rebuilding stream 00000 [1 of 1] - [16:35:14] Building ALTERNATE OUTPUT Structure - [16:37:16] Converting 1 subtitles to DVD format. - [16:37:40] Starting MPLEX. - [16:40:06] Multiplexing 1 subtitles into stream. - WARNING: Failed to integrate Subtitle_01 - [16:40:09] Building DVD File Structure. [16:42:29] - Encode and Rebuild complete - WORKFILES folder removed. [16:42:30]JOB: THE_TOURIST finished. Last edited by AGKnotUser; 1st August 2011 at 22:36. |
2nd August 2011, 00:45 | #12586 | Link | |
2nd August 2011, 03:23 | #12588 | Link | |
2nd August 2011, 04:59 | #12589 | Link | |
2nd August 2011, 07:59 | #12590 | Link |
Detected As:Bloodhound.Sonar.9
I use the "Symantec Endpoint Protection" and in the last update "BD-RB v0.38.05 (beta) - BD-RBV03805.zip" i had the following issue: the file "bd_rebuilder.exe", detected As:Bloodhound.Sonar.9. That never happens in other versions. Please advise. Last edited by gkal; 2nd August 2011 at 08:07. |
2nd August 2011, 14:47 | #12593 | Link |
As I've said before, sometimes the A/V software is as much of a pain as viruses themselves. "Heuristic detection" they call it. Hah!! That could just mean today is Tuesday.
Trend Micro Internet Security says it's ok. I encrypt the EXE and prevent startup if it has been tampered with -- just to make sure no one ever attaches a virus to it. But sometimes the randomness of encryption can set off "heuristic scanners". Last edited by jdobbs; 2nd August 2011 at 14:52. |
2nd August 2011, 22:38 | #12595 | Link | |
[15:04:21] BD Rebuilder v0.38.05 (beta) - Source: RED_BIRD_2D_WW - Input BD size: 39.22 GB - Approximate total content: [02:41:41.685] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:04:21] PHASE ONE, Encoding - [15:04:21] Extracting A/V streams [VID_00000] - [15:24:53] Reencoding: VID_00000 (1 of 1) - [15:24:53] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 232,608 frames - Bitrate: 3,276 Kbs - [15:24:54] Reencoding: VID_00000 - [16:50:56] Video Encode complete - [16:50:56] Reencoding audio tracks (if req'd) - [16:55:40] Multiplexing M2TS [16:55:40]PHASE ONE complete [16:55:40]PHASE TWO - Rebuild Started - [16:55:40] Rebuilding stream 00000 [1 of 1] - [16:55:40] Building ALTERNATE OUTPUT Structure - [16:57:54] Converting 1 subtitles to DVD format. - [16:59:55] Starting MPLEX. - [17:02:08] Multiplexing 1 subtitles into stream. - WARNING: Failed to integrate Subtitle_01 - [17:02:12] Building DVD File Structure. [17:04:51] - Encode and Rebuild complete - WORKFILES folder removed. [17:04:51]JOB: RED_BIRD_2D_WW finished. |
2nd August 2011, 23:18 | #12596 | Link |
Rambo - First Blood
This is kinda strange! Downloaded and installed 38.05 and did a Movie Only - 25 backup of Rambo. It is pretty small and no re-encode was required. I have included all logs and ini files below. The process completed quickly with no errors. But...the movie is nothing but jumpy audio and video. I thought there might be a problem with the rip (even though it played with no problem.) So...ripped again and tried it again. Same exact problem. So...reverted to 38.04. Same results. Uninstalled and reinstalled everything. Same results with 38.05. Then, as a last resort, I forced a re-encode. Everything is just fine. Any ideas on this one? Why would a re-encode solve the problem?
[Status] LABEL=RAMBO_FIRST_BLOOD VERSION=v0.38.05 (beta) SOURCE_SIZE=19456284672 SOURCE_VIDEO_SIZE=19456284672 TARGET_SIZE=24641536000 REDUCTION=1.26650778478083 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=-1 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00001] USE_ORIGINAL=1 AUDIO=11001 PGS=101 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641536000 NSTART=27000000 NEND=278640136 NSIZE=15816392704 FLINK=0 MLINK=0 [15:22:26] BD Rebuilder v0.38.05 (beta) - Source: RAMBO_FIRST_BLOOD - Input BD size: 18.12 GB - Approximate total content: [01:33:11.586] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:22:26] PHASE ONE, Encoding - [15:22:26] Extracting A/V streams [VID_00001] - [15:32:03] Reencoding: VID_00001 (1 of 1) - [15:32:03] Collecting video information - [15:32:03] Keeping original video (no reencode) - [15:32:03] Reencoding audio tracks (if req'd) - [15:32:03] Multiplexing M2TS [15:43:20]PHASE ONE complete [15:43:20]PHASE TWO - Rebuild Started - [15:43:20] Rebuilding BD file Structure [15:53:34] - Encode and Rebuild complete - WORKFILES folder removed. [15:53:37]JOB: 17392276_A019157 finished. [Options] VERSION=0.38.0.5 MODE=2 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 TARGET_SIZE=23500 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=1 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 AUTO_BLANK=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 [Paths] WORKING_PATH=C:\USERS\PUBLIC\VIDEOS\BD25\ SOURCE_PATH=M:\RIPS\RAMBO_FIRST_BLOOD\ - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.11.96.14, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.38.0.5, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
3rd August 2011, 01:22 | #12598 | Link |
With the audio/video problems I did not burn to BD. I used MPC provided in your directory and Nero Cineplayer on two different PC's. One win7 64 and the other XP. Have done dozens of these smaller BD's that did not require re-encode and never saw that problem before. Nothing new installed on either computer (except Windows updates) in months. Oh well, as I said...I got it to make a good backup, just thought you might know what gives... Thanks
3rd August 2011, 02:49 | #12599 | Link |
NORTON 360 "SONAR" DISABLES 38.05 Beta on WIN7
BUG - NEW 38.05 DETECTED AS A VIRUS
My Norton Premier 360 detected the NEW 38.05 release's BD_rebuilder.exe file as a HIGH threat and automatically DISABLED it. I'm using Windows 7 Home edition on that PC. Logging in as administrator didn't help. I installed 38.05 several times before I finally noticed the little Norton box flashing in the right corner. Sure enough, Norton had flagged the Bd_rebuilder.exe file as a HIGH THREAT VIRUS. Even after turning OFF the "Remove risks automaticaly" option in Norton360 Premier, it still kept distroying the BD.exe file. I had to DISABLE the Norton Sonar function to make the NEW 38.05 BETA work. I'm also using BD rebuilder (OLD release 38.04) on another computer with O/S "Win 7 Ultimate" with the SAME "NORTON 360 premier edition" with NO problems - so that leads me to think that only the NEW BD 38.05 BETA causes the "Premier Norton 360's" Sonar function to treat BD.exe files as a virus. I'm sure there is a way to "just exclude BD_Rebuilder.exe" from Norton's new Sonar scan in the Premier edition, but I still need to figure out how. (Not as obvious as other Virus programs I've used) I'll try to re-post later on how to do that. Synthea |
3rd August 2011, 03:20 | #12600 | Link | |
Two other A/V packages (Trend Micro Titanium and McAfee) have verified that there is no virus. I just recompiled into v0.38.06. Try downloading this one -- then let me know if your "wonderful" A/V detection software accepts it so I can update it in the first post. Last edited by jdobbs; 3rd August 2011 at 03:53. |
