9th February 2008, 23:54 | #1041 | Link | |
Hey Now!
9th February 2008, 23:58 | #1042 | Link |
DTS MA Questions
Can anyone tell me why HD MA will sometimes be converted to DTS ES and then others to regular DTS 2 channel when using the newest version of tsremux? For example, X-MEN 3 converts to DTS ES and Planet of the Apes converts to 2 channel DTS
10th February 2008, 00:37 | #1043 | Link |
TSRemux v20 crashes when loading a vob file. v0.0.16 works though. Also works if I uncheck "Use async I/O". :-)
************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at TsRemux.TsRemux.EnableCbxMlp() at TsRemux.TsRemux.backgroundWorker2_RunWorkerCompleted(Object sender, RunWorkerCompletedEventArgs e) at System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e) at System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- TsRemux Assembly Version: 0.0.20.0 Win32 Version: 0.0.20.0 CodeBase: file:///E:/downloads/low/tsremux/tsremux_080209.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. Last edited by DanielCardenas; 10th February 2008 at 00:59. |
10th February 2008, 15:48 | #1048 | Link |
Hey Now!
With TSremux .20 I am having issues with bluray. with .19 I do not have the issues. After I remux a m2ts to bluray using .20 the resulting structure will play in powerdvd or standalone
bd players but does not have audio (yes I unchecked bypass audio align). in .19 it does work in standalone players and powerdvd with audio with the Same Source. This could be just because of Tsmuxer not properly setting the dts audio correctly. I will just have to use .19 for these sources. Last edited by jamos; 10th February 2008 at 18:16. |
11th February 2008, 06:14 | #1050 | Link | |
11th February 2008, 09:54 | #1051 | Link | |
use 'r'
P.S. i'd like to buy this BD30 player, so can you please answer me, do it have "variable zoom" function as panasonic's dvd-players? Last edited by n0mag!c; 11th February 2008 at 12:27. |
11th February 2008, 17:59 | #1052 | Link | |
11th February 2008, 18:45 | #1053 | Link |
Yep I second that, its one of the best if not the best blu-ray player, the only future proof player with no limit on firmware updates it will support the BD 2.0 specs when they come out. It's also the best dvd upscaller and a nice media center
11th February 2008, 19:04 | #1054 | Link |
does someone know exactly whats the current status on seamless branching movies with audio delay regarding .mkv remuxing (not with tsremux .mkv funtions, but mkvmerge etc.)? when you demux video & audio with xport from the .m2ts file, which was created by joining all the single files with copy /b, there will be a bit too much audio e.g. on average ~2.5ms for LPCM tracks or ~16ms for eac3 tracks for each joined .m2ts file (which can add up depending on their number). does someone know whether this would be the same when the with copy /b joined file is processed with tsremux 1st?
11th February 2008, 22:26 | #1055 | Link |
Thunderbolt8, I asked drmpeg (in PM) about the seamless branching issue. I hope he gets back to me about it one day.
My question is: Is the additional audio packet at the end of each m2ts segment repeated in the next audio segment? If so, is there a way to detect this additional audio packet and delete it, or does the audio need to be re-encoded? |
12th February 2008, 07:41 | #1056 | Link | |
First, thanks for working on this tool! Here are a few questions/notes/observations/suggestions: 1.) Does TsRemux include or get periodically updated to include all of the demuxing fixes that are added to xport.exe? (According to http://www.w6rz.net/ , xport was "Updated 11/25/2007 - current version is 1.00" ). 2.) Is TsRemux at least as robust at demuxing .ts as xport? (This is important for handling potentially broken broadcast ATSC streams, and I'd like to use whichever tool is a better ATSC stream demuxer in my scripts.) 3.) Can TsRemux functionally replace xport (i.e. does TsRemux have all of xport's features) (assuming a command line version of TsRemux is created)? 4.) How about TsRemux vs Evodemux ... is there anything Evodemux can do that TsRemux cannot? 5.) Have you considered adding GaveUp's AC3 bitrate header fixing code (from AC3 Cutter) as an AC3 processing option? This changing of the bitrate headers is important for maintaining sync when transcoding broadcast ATSC streams that switch between multiple different AC3 bitrates all in the same program. A common example is 384 kbps 5.1 AC3 for the main program and 192 kbps 2.0 stereo AC3 for the commercials. The source code for the last version (AC3 Cutter 0.3) is available in the zip file package: http://forum.doom9.org/showthread.php?t=92325&page=2 http://www.64k.it/andres/data/a/AC3_Cutter_v0.3.zip 6.) Any thoughts about a command line version? This has been requested several times: http://forum.doom9.org/showthread.ph...ne#post1091937 http://forum.doom9.org/showthread.ph...ne#post1077931 http://forum.doom9.org/showthread.ph...ne#post1070483 http://forum.doom9.org/showthread.ph...ne#post1012089 http://forum.doom9.org/showthread.ph...ne#post1008821 http://forum.doom9.org/showthread.ph...ne#post1001708 If anyone is thinking of creating a command line wrapper for TsRemux, let me suggest the GPL open source tool AutoHotKey from http://www.autohotkey.com/. For Linux users, it works fine under WINE per http://appdb.winehq.org/objectManage...rsion&iId=8043. |
12th February 2008, 09:24 | #1058 | Link | |
Furthermore, the PS3 has been reported all over the web to be the best DVD upscaller; it outputs a better upscalling quality than other upscalling DVD players. Due to its cell processor it has more power for picture quality processing. But of course for DVD upscalling to actually take place you need to enable 2 things in the PS3 settings: - DVD upscalling (under DVD options) - and 1080p (under supported screen sizes) My guess is that you haven't enabled "DVD upscalling" |
12th February 2008, 15:44 | #1059 | Link | ||||||
Answers:
