30th March 2011, 12:40 | #121 | Link | |
MPC internal splitter: problem Haali Splitter: problem LAVSplitter: works The renderer doesn´t matter. Since all other decoders I´ve tested (ffdshow, mpc internal, DivX, Microsoft, DiAVC trial) work with haali/mpc splitter the bug is probably in your decoder. |
30th March 2011, 12:41 | #122 | Link |
Lesson learned: use LAV Splitter!
I'll do some tests once i'm working on the decoder again, but from my past experience, there really has been a cycle of bugs surrounding the MPC splitters, the mpc decoders and ffdshow, where they all rely on the bugs of the other to work properly, and no-one is really doing it just right.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 30th March 2011 at 12:49. |
30th March 2011, 12:53 | #123 | Link |
just wondering,..
would it be possible to use this decoder (on a windows system) with mplayer/mencoder by modifying the codecs.conf similiar to Code:
videocodec lavcuvid info "LAV CUVID Decoder" status working fourcc AVC,avc fourcc VSSH fourcc X264,x264 fourcc h264,H264 driver dshow dll "LAVCUVID.ax" out YV12 Cu Selur |
30th March 2011, 12:56 | #124 | Link |
I have no idea how those setups work, but two things:
- the fourccs are AVC1 and avc1 (FourCC kinda implies its always 4 :P) - It can only output NV12, not YV12
30th March 2011, 13:03 | #126 | Link |
4x2GB Kingmax DDR2-800. Your question reminds me of some BIOS options related to VGA performance in my Gigabyte board. Gonna try tweaking. I tried these youtube video with latest flash player and those play fine (only problem is my internet speed, 1.5Mbps). Unrelated note, the first video also reminds me how I dislike trance/house/club/psychedelic music, funny how other ppl in their twenties like them but I simply can't.
Home PC: Core i5-2400, 8GB RAM, nVidia GTX560Ti, Windows 7 64bit SP1. Work PC: Intel Xeon X3220 (Core 2 Q6600), 4GB RAM, Intel G45, Windows 7 64bit SP1. |
30th March 2011, 13:15 | #127 | Link |
http://forum.doom9.org/showthread.php?t=141441 <- easier way (also should be more performant then going stdout)
@thuan memory speed seems not to be the problem as nev also said he uses pinned memory try a new driver with a newer nvcuvid.dll you can also test different nvcuvid.dll by just pushing them in LA CUVIDs main filter directory if you want to seperate 3D from Video in Nvidias driver (works only reliable though if they didn't made major CUDA branch changes that impact also nvcuvid or and nvcuvenc)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 30th March 2011 at 13:33. |
30th March 2011, 13:30 | #128 | Link | |
1. for the .ax file to be registered,.. 2. the use of directshow splitters ("also should be more performant then going stdout" -> shouldn't do much of a difference decoding with mencoder/ffmpeg and piping to x264 was on par with x264 and internal decoding, last time I checked ) -> played a bit around with the codecs.conf of mplayer, but didn't get it working,.. (may be I'll try it again some time) Cu Selur |
30th March 2011, 13:37 | #129 | Link |
Hehe yeah it would require a controlled Dshow environment else Dshow Hell is guaranteed, and yeah i myself use mencoder and piping and yet have to see lower performance same as stan and you use it reliable for their encoding frameworks (oldshool)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 30th March 2011 at 13:42. |
30th March 2011, 13:51 | #130 | Link |
@cruNcher: Indeed trying to change these settings in my BIOS did little to the whole problem, albeit setting Robust Graphic Booster at Turbo and set memory speed to integer multiple of my FSB seems to make the problem a "little" less severe but it is still nowhere acceptable. I'm using the latest 267.91 now and still the same problem. I'm thinking Gigabyte did something to this graphic board BIOS that causes it to conflict with newer nvidia driver. The only configuration I know that work is 258.96 with DXVA or CoreAVC CUDA, unfortunately lav cuvid is not compiled to be compatible with that driver version so I can't test. I also don't think it's a broken windows installation as I have tried to reinstall once and still only 258.96 works.
I'm torn between getting a GTS 450 board and waiting for a fix. Considering I'm only of minority (seen some other had this problems too), likely it will be the same as that ATI chroma upsampling problem that I reported to ATI a few years ago (the respondents said the screenshots I sent them looks fine lol, that guy must have worked with 14in CRT). We are at the mercy of manufacturers. @selur: I don't think that is going to work as this DirectShow filter is only a wrapper of CUDA calls included in a Windows DLL that works with Windows driver.
30th March 2011, 14:05 | #131 | Link |
As you can read in CoreCodecs CoreAVC 2.5 changelog they use some ASM modifications for the CUDA Part i guess LA CUVID uses plain the Nvidia API but not really any optimization yet be it Colorspace Conversion or maybe other parts, though unfortunately the issue im facing Personally with both is not RAW Performance related at all and i don't found the reason for it yet.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
30th March 2011, 17:39 | #133 | Link |
As i understand it, GPUDirect is just a smart way to copy data between two CUDA cards, without ever seeing the CPU.
30th March 2011, 18:42 | #135 | Link |
finally its out that Drivers nvcuvenc.dll also fixes a very pesky Encoder bug that caused strange moving chroma
30th March 2011, 19:22 | #136 | Link |
Thanks alot navcairiel, very impressive stuff with the decoder. Strangely, and maybe I'm hoping you could explain if this is something that could be improved up on or not, but using this or the coreavc decoders with my GTX295 / core i7 920 setup on Windows 7, I get more frame drops than with ffdshow ffmpeg software decoder.
I am using madVR and some avisynth scripts that change the frame rate from ~24 -> 50fps so I'm not sure if anything in this chain, is known to cause a bottleneck somewhere gpu wize thats causing the frame drops. Its only 1 or 2 frame drops a second but I am now getting 0 with the software decoders... Not a big deal but just thought I should mention it and I'm here if you need any tests / trials done to see if this can be resolved. I'd love to use your decoder, and even push my avisynth scripts further (quality wise) due to the freed up cpu. Im using the 270.51 drivers released today. Testing today with a blu-ray vc1 Last edited by mark0077; 30th March 2011 at 19:28. |
30th March 2011, 20:25 | #138 | Link |
very container dependent if it's inside PS/TS it wont surprise
30th March 2011, 20:29 | #139 | Link | |
That goes for mark0077 as well. The next version of LAV Splitter will have LAV CUVID in the list of decoders to autodetect it should be off.
30th March 2011, 21:13 | #140 | Link |
I am still noticing dropped and delayed frames in madvr still with vc-1 actually on both my 9400m and gtx 260
I am also getting poor performance for h264 for my 2 computers each with vp2 cards (a gtx 260 and an 8600gt) . But especially for the 8600gt; 1080p video was unwatchable. For the gtx 260, it was almost perfect. Last edited by mindbomb; 31st March 2011 at 03:07. |
