20th July 2011, 16:48 | #9863 | Link |
change you file to other folder use english name like c:\aaa\a.avi
first.. and some new mp4 file is ,not work ,output full Gray video but use mkvtoolnix change it to mkv is ok..(maybe is use this software encode file,the x264 ver have this Problem) tp file cannot open ,change to ts is ok.. use the last x264 2019 base3.0 profile ,avs2yuv use 30% cpu,x264 only use 6% cpu..this one is real issue? Last edited by god_md5; 20th July 2011 at 16:54. |
20th July 2011, 16:51 | #9864 | Link | |
20th July 2011, 17:23 | #9866 | Link | |
The Black Reaper
2. Output directory contains "illegal" characters, that is due to your windows user name. Change your output directory to "D:\" . |
20th July 2011, 17:36 | #9867 | Link | |
If I understand you correctly, I changed the path but it is not nothing changed!
20th July 2011, 17:47 | #9868 | Link |
use mkvtoolnix change to mkv,some openavi is h264+mp3 have issue.
ripbot look like is use Haali Media Splitter open mp4 with ffdshow clsd ver is full grey screen..(like all for the ipad mp4 file) x264 ver issue? but use mkvtoolnix change to mkv is work.. Last edited by god_md5; 20th July 2011 at 17:51. |
20th July 2011, 18:35 | #9870 | Link |
Edit ripbot264.ini file in notepad
change temp directory to C Code:
StoreTempFilesin=C
20th July 2011, 19:03 | #9871 | Link | ||
21st July 2011, 04:05 | #9875 | Link | |
21st July 2011, 06:37 | #9877 | Link | |
http://forum.doom9.org/forum-rules.htm Last edited by Guest; 21st July 2011 at 06:40. |
21st July 2011, 10:13 | #9878 | Link |
@atak
RipBot seems to have problems with packed bitstreams (avi). Audio won't be recognized. Code:
General Format : AVI Format/Info : Audio Video Interleave File size : 178 MiB Duration : 21mn 20s Overall bit rate : 1 167 Kbps Writing application : VirtualDubMod 1.5.10.2 + BXAudHdrFix (build 2547/release) Writing library : VirtualDubMod build 2547/release Video ID : 0 Format : MPEG-4 Visual Format profile : AdvancedSimple@L5 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Muxing mode : Packed bitstream Codec ID : XVID Codec ID/Hint : XviD Duration : 21mn 20s Bit rate : 1 029 Kbps Width : 512 pixels Height : 384 pixels Display aspect ratio : 4/3 Frame rate : 25.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.209 Stream size : 157 MiB (88%) Writing library : XviD 1.1.0 (UTC 2005-11-22) Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 21mn 20s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 19.5 MiB (11%) Alignment : Split accross interleaves Interleave, duration : 40 ms (1.00 video frame) Interleave, preload duration : 500 ms |
