12th September 2011, 03:41 | #782 | Link |
I posted that because I was curious as to under what circumstances 64-bit is unstable. I understand that my experience does not cover every single plugin so I cannot say with certainty that 64-bit is as stable as 32-bit. But then, I'm also wondering based on what evidence TheRyuu says that? Has he tested every single plugin? Or is his statement based on looking at the source code and finding out that it is very poorly coded? A short explanation as such is more helpful.
16th September 2011, 15:46 | #783 | Link |
Hi.
I am now trying working with MeGui64, AviSynth64, x264_64 and 64bit filters. But I have two problems:many crashes and not many filters. So I am going back to 32 and see if it is better. I have question, whether I can have mixed chain...something like Avisynth32+x264_64...or so? After some browsing I understand, that there is no way to put filter32 in avisynth64, right? Tnx |
3rd October 2011, 18:41 | #785 | Link |
21 years and counting...
Anybody got a working sharpening filter for Avisynth64?
I need some working sharpening filter to slightly resharpen the image after noise removal. I don't like the results from warpsharp or the default sharpening filter from Avisynth. |
3rd October 2011, 19:12 | #786 | Link |
@LeXXuz: What, how, and why.
4th October 2011, 08:12 | #788 | Link |
Now we've changed from "poking in the blue" to "poking in the green". A major improvement.
21st January 2012, 19:01 | #791 | Link |
i have installed avisynth the way it was described on the first post however i have noticed that:
1. the time on the analysis it takes quite longer than the 32bit before (for the same movie) 2. After i press save on the avs script creater a video preview window opens while before it wasn't. am i doing something obviously wrong or other users experienced the same? |
11th March 2012, 05:16 | #792 | Link |
Banned
64-Bit AVISynth wont install
Windows XP 64-Bit
This is my first 64 bit operating system and I cant get this to install. It says I need Administrator privilages to install it. I am the damn administrator and the only account on the computer so thats fucked up. I go to right click it and choose Run as Administrator and that doesnt even show up in windows, its not there to even click like it is on my other computer. What should I do? i tried editing that out of the batch file where it checks for administrator privilages and it doesnt even work then. |
11th March 2012, 06:16 | #794 | Link |
Banned
Windows XP 64-Bit
I try to run MeGui in 64 bit mode enabled and thats the error I get when it starts to encode my video. avs4x264mod.exe I have AVISynth 64-Bit installed Why is MeGui giving me this error? how would I go about fixing this? |
10th June 2012, 18:55 | #796 | Link |
Master of wasting time.
This is the first time in 14 years I need to post a question here, previously everything I needed to ask has already been answered somewhere else or I had to post in another forum...
Request: Multidecimate for Avisynth in x64 http://neuron2.net/multidecimate/multidecimate.html I would only need the MultiDecimate.dll in x64, the rest of the filter does not really need to be x64. If possible without too much work: Make it accept RGB directly so ConvertToYUY2() is not needed. Reason: I record some game videos in 3968x2480 with pseudo-60-fps in fraps. Generates huge amount of duplicate/identical frames in an irregular patten. Multidecimate is the most simple way to get rid of them. BUT: I cannot encode that resolution with 32 bit virtualdub/avidemux/x264.exe or any other codec I tried. I HAVE to use x64 to just encode the video. My ugly workaround was: Since the videos were rather short and I had enough space I could save the multidecumated video as uncompressed video, 2 Minutes 40 Seconds made a nearly 400 GB .avi. But it would be SO much more elegant to have multidecimate for x64 avisynth to spare that workaround. (Results at http://www.youtube.com/watch?v=-y335WQvGzY and http://www.youtube.com/watch?v=0FhUKndMrAY , including links to the original encodings which require an OC'ed i7 just to play...) |
10th June 2012, 19:04 | #797 | Link | |
Advanced Blogging
10th June 2012, 19:29 | #798 | Link | |
I know redirection, I tried the "avs2yuv.exe input.avs - | x264-x64.exe --stdin y4m" way which I used until about ~two years ago. Since then the x264-vfw codec and avidemux x264 implementations were good enough to get rid of that workaround. But it didn't work here. Recent versions of x264 threw me an error, older versions work, but I didn't invest much time since the uncompressed workaround was the lazier way. Last edited by Jou; 10th June 2012 at 19:31. Reason: bad grammar |
4th November 2012, 21:03 | #799 | Link |
Member of a Library
Any solution for the green frames yet? My script consist only of MPEG2Source ("x.d2v"). Is the plugin buggy? I will try to learn FFMpegSource, but currently I need DGDecode. Is there another version maybe? And by the way, this is vital. It should be put into the installer. DirectShow (read: MPC-HC) doesn't work without it. I banged my head against the wall until I remembered to . * Edit: this is all on x64, of course. * Edit2: both 4/16/2010 and 3/19/2010 releases. GL Last edited by GrofLuigi; 4th November 2012 at 21:06. |
4th November 2012, 22:02 | #800 | Link | |
Why don't you use DGINDEX instead? It's more up-to-date.
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
