29th March 2007, 16:06 | #441 | Link |
I have an interlaced PAL video that I would like to create an NTSC DVD from. I just want to confirm my understanding from reading through the thread.
1. Use Avisynth to deinterlace and resize to 720x480 2. Encode to a 720x480 25fps progressive MPEG-2 file 3. Use DGPulldown to flag the 25fps file to 29.97fps 4. Author DVD Is there anything I'm missing? Thanks in advance. |
29th March 2007, 16:34 | #442 | Link |
Everything about your procedure looks alright to me. (I think you know that you have to demux your video before step 1)
Just a little advertising here: If you happen to use DVD2SVCD, have a look at http://forum.doom9.org/showthread.ph...974#post971974 This is an automated procedure to convert PAL to NTSC with the additional bonus that the chapter points you might already have in your PAL video will also be converted. Cheers manolito |
29th March 2007, 21:32 | #443 | Link | |
1. Use AVISynth and a plugin (LeakKernelBob, SmoothDeinterlacer, etc.) to deinterlace the video to 50 (progressive) Fps. 2. Scale the video to 720x480. 3. Use ChangeFPS() or ConvertFPS() to convert/change the frame rate to 59.94 (progressive) Fps. Which one you use depends on your personal preference. ConvertFPS() blends frames. ChangeFPS() replicates frames. I prefer ChangeFPS(). 4. Divide the frames into fields and throw out every other one (SeparateFields().SelectEvery(4,0,3) or SeparateFields().SelectEvery(4,1,2), depending on your destination field polarity). 5. Encode to a 720x480@29.97 interlaced Fps MPEG-2. 6. Author DVD. Xesdeeni |
29th March 2007, 22:14 | #444 | Link |
Conclusion:
1. DGPulldown method for Progressive PAL to NTSC. 2. ChangeFPS/ConvertFPS method for Interlaced PAL to Interlaced NTSC. Thanks for the replies. Last edited by ad25; 30th March 2007 at 15:38. Reason: Better wording |
11th April 2008, 21:17 | #447 | Link |
Aging Video Hobbyist
I resurrected this old thread because I think Xesdeeni and DG aka neuron2 have done a wonderful thing creating the DGPulldown tool. Hasn't gotten enough pub IMHO and it surely deserves it (never was a "DGPulldown" thread created per se, was there?). Anyway...
I bought a pricey DVD set from Sweden (PAL) which I did not want to convert to 720x480 because I thought my media players (networked ShowCenters) would play the original ripped 25fps MPEG2. Turns out at least my analog NTSC TV didn't like the original much (jerky, prolly had something to do with 25x2 vs 29.97x2 ). Anyway, a simple DGPulldown from 25-->29.97 did the trick. Amazingly, I was able to re-mux (using IfoEdit that didn't care this was non-standard stuff) the original 720x576 and 25fps AC3 audio with a brand-new subtitle track I made for it and it all plays beautifully! Just want to say THANKS you guys especially neuron2 for exe-cuting this! |
12th April 2008, 10:23 | #449 | Link |
Life's clearer in 4K UHD
I actually did some tests a few years ago with (PAL) 720x576 MPEG-2 sources running at (NTSC) 29.970fps and 23.976fps speeds.... And vice-versa.
From what I remember, most, if not all my DVD players managed to puke out an NTSC signal... which was a positive step. I was however unable to find a DVD authoring tool that would allow me to create "non DVD standard" VOB sets suitable for burning onto DVD. Cheers EDIT: Found a thread: http://forum.doom9.org/showthread.php?t=83499
12th April 2008, 16:11 | #450 | Link |
Well, as I said IfoEdit worked for me. I had intended to sacrifice a DVD+R to try my VIDEO_TS with, and based on your post I have a better-than-zero chance of actually seeing it work on any of my NTSC players! I'll try it today!
18th April 2008, 04:36 | #451 | Link |
Well, the result plays smoothly on the one Sony (NTSC) DVD player I've tried, but it isn't displaying at the proper AR i.e. it's taller than it should be. It looks like, since the player's been told this is a 720x480 NTSC picture, and it's not, it's 720x576, that it's "too tall" at least on my 4:3 analog TV. Haven't tried it yet on my 16:9, I guess that's next.
But it looks like the DVD has to be either a PAL at 720x576 or an NTSC at 720x480, and since it's now a 29.97 program IfoEdit (authoring proggie) decided "NTSC". I suppose if I change it to PAL then my player will balk. Will play with this some more...glad at least my media players don't care that it's 720x576 (and display at proper AR). |
28th April 2008, 15:13 | #452 | Link |
Got 'round to trying my DGPulldown DVD (a 720x576 PAL disc that I didn't re-encode) on my 16x9 setup last night and it worked! The disc plays as if it were NTSC, but it's 576, and the AR is A-OK.
One oddity is that the DVD player's display has an odd staccato cadence about it i.e. is not at all smooth, but the picture (25fps to 29.97fps) is smooth and good. I have another PAL disc on-the-way and will use this same method to play from my upconverting HD-XA2. |
23rd April 2009, 08:17 | #453 | Link |
I've been using the 25 to 29.97 pulldown method for awhile and have been very pleased with the results (better than most commercial conversions if you ask me).
I'm working on a full DVD conversion now and saw a couple of strange things this time. First, the DVD is 1:54:57 in length. While the untouched audio in the NTSC version syncs throughout, the runtime (checked in a couple different pieces of software) shows 1:54:50. Which brings me to the second problem. I would disregard the runtime discrepancy since there is no sync issue, but the converted chapters are off. The theoretical calculation for conversion would be: 30/25 * original cell. And this is true. Examining the time of each chapter on the NTSC conversion done this way matches the PAL original. The times also show correctly when using any software that shows the time points of the chapters (ChapterXtractor, DVDRemake, etc.) BUT, while the times are right, the actual frames drift progressively until they are 7 seconds off at the end. I can account for this by changing the cell calculation to: 29.97/25 * original cell. Calculated this way the chapter breaks appear in the correct location, but the actual timestamp is wrong. Has anyone ever noticed this before? I can't make heads or tails of it. |
23rd April 2009, 14:30 | #454 | Link |
Let's address the running time first. How did you create the M2V stream that you applied pulldown to from the DVD? What are the exact steps that produced it? What is the running time of that M2V before and after applying pulldown?
24th April 2009, 00:01 | #455 | Link | |
The video was encoded with CCE 2.70 with the Frame Rate set to 25. Before pulldown the runtime shows 1:54:57.320 by VDubMod (1:54:56 according to DVD Lab Pro). After applying 25 to 29,97, the runtime is still 1:54:56 (also by DVD Lab Pro) (VDubMod shows around 1:36:ish.). Test builds of the DVD with MuxMan and DVD-lab Pro made no difference. The runtime is 1:54:50 in Media Player Classic and VLC. IfoEdit shows 1:54:50.13. PowerDVD does show the correct 1:54:57 time but it could be ignoring the pulldown flags. I tested on 3 stand alone DVD players. A very old high end Sony, a few year old mid range Panasonic and a mid range 1 year old Philips. All 3 agree that the runtime is 1:54:50. 29.97/25 * original cell still gives the correct chapters by frame but at a different time point than the original. Which all seems to make sense since 1:54:57 / 30 * 29.97 = 1:54:50. |
24th April 2009, 06:52 | #457 | Link | |
Does DGIndex default to non-drop frame in these cases when it should be drop frame? |
24th April 2009, 14:20 | #458 | Link | |
Try setting the drop frames explicitly by clicking until it is checked but not gray. I never do any chapter stuff so don't really know what you are talking about. If you can identify a problem with DGPulldown and tell me what needs to be done I will do it, but I have no time to get all wound up in chapters and authoring right now. Last edited by Guest; 24th April 2009 at 14:32. |
24th April 2009, 18:18 | #459 | Link | |
The chapters aside, I just worry when the runtime changes when it isn't suppose to. I'll test with drop frames and see if it corrects that. Edit: No, it's worse with DF. The audio desyncs and the runtime becomes 1:59:44. I guess the change in runtime is just a quirk associated with doing this. Thanks for the help. Last edited by DoctorM; 24th April 2009 at 20:33. |
