Old 7th July 2006, 15:10   #41  |  Link
killerhex
i have a problem everytime i restart or click the save to save the cofig of the player it switches to another language instead of english
killerhex is offline
Old 7th July 2006, 16:09   #42  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
You have to select and *save* the language in the options window if you want to keep it. If this doesn't work, make sure mpui.ini isn't write-protected.
LoRd_MuldeR is offline
Old 8th July 2006, 06:50   #43  |  Link
killerhex
ok it worked
Old 18th July 2006, 00:03   #44  |  Link
LoRd_MuldeR
Software Developer
*Update*
  • MPlayer/MEnocder updated to 2006-07-17
  • Fixed a bug in my MPUI build (KernelDeinterlacer was broken)
Old 22nd July 2006, 01:41   #45  |  Link
grss1982
Hi LoRd_MuldeR,
This might sound stupid, but is this player pack backwards compatible with Windows 98 SE?
grss1982 is offline
Old 22nd July 2006, 11:14   #46  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by grss1982
Hi LoRd_MuldeR,
I don't know, because I've never tested that.
MPUI is a simple Delphi app, so this should not be the problem.
But I'm not sure if those MPlayer builds are suitable for Win9x.
If you want to know, get Vitual PC, run a Win98 machine and test it...
Old 22nd July 2006, 20:31   #47  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
Last time I checked it didn't work.
I know I had to download 2 additional files from M$ to make VLC work on 98.; maybe MPUI needed those files too (sorry, forgot the names).
I will try and install MPUI again...
Razorholt is offline
Old 23rd July 2006, 00:07   #48  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
Ok.
The files I was refering to can be found at: http://www.microsoft.com/downloads/d...displaylang=en
I tried to install MPUI on my poor 98 machine but since it is a P2 it didn't work
Sorry.
Old 23rd July 2006, 11:06   #49  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by Razorholt
Ok.
Sorry.
P3 build requires SSE, which P2 doesn't have.
Get a generic build of MPlayer and it should work.
Just replace the MPlayer.exe with the one form that ZIP file!
Old 23rd July 2006, 21:55   #50  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
Thank you! I've done that and managed to play some files just fine.
One thing that didn't work was the progress bar. The Pause button doesn't seem to work either.
Old 23rd July 2006, 22:24   #51  |  Link
LoRd_MuldeR
Software Developer
Well, MPlayer cannot seek in some files. So the Seeking-Bar won't work with such files.
The Pause button should work though...
Try a simple DivX-AVI file or something!
Old 24th July 2006, 23:06   #52  |  Link
Flexy
excellent....i just discovered Mplayer yesterday (was using mpc & ffdshow before).....and then i thought that MPUI and celtic druid's builds are the best....and you provide all those in ONE package ! Nice !!!!
Flexy is offline
Old 25th July 2006, 04:08   #53  |  Link
celtic_druid
celtic_druid's Avatar
Anyone tried my win32 gmplayer build?
celtic_druid is offline
Old 25th July 2006, 04:26   #54  |  Link
LoRd_MuldeR
Software Developer
yeah. seems to work fine here, but I prefer MPUI as GUI for MPlayer...
Old 25th July 2006, 06:41   #55  |  Link
Flexy
i will try whatever you have there....playing around with mplayer and various GUIs and builds....the problem is my GF has an old Toshiba lappy w/ PIII...and i have a hard time finding a player which does NOT cause problems.
I test the PIII builds on her laptop..and i see she has terrible problems with MPUI (and the CDruid optimized mplayer build)..i don't know why...but it is extremely choppy w/ XVid et. , bringing her comp down to the knees
But with the *same* mplayer executable/build i have GOOD
results with MPF (Mplayer frontend) on her comp...must be some setting issue.
"Good" means that picture quality and speed are awesome, but in SOME movies the audio was out of sync. (Some movies more than others). But then MPUI would just slow it down to almost an halt so i cant even use it.
Flexy is offline
Old 25th July 2006, 13:03   #56  |  Link
bolke
There is a new Windows gui for mplayer. At first glance it seems to be pretty good.
http://www.dsource.org/projects/rulesplayer
bolke is offline
Old 25th July 2006, 17:03   #57  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
RulesPlayer is quite fast, yes. I could play a 720p MOV file on my 800Mhz PC... Interesting.
However, they should fix their download link. ".exe" is missing.
Old 25th July 2006, 17:05   #58  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
How about ActiveX for MPlayer? Has anybody developed it yet?
Thanks,
- Dan
Old 1st August 2006, 16:54   #59  |  Link
avih
Capture, Deinterlace
avih's Avatar
@LoRd_MuldeR:
First of all, I've seen your wrapper lately (before I was aware of this thread) and was highly impressed with its simplicity, effectiveness, functionality and small footprint. Well done
When I saw this thread I went to the sourceforge project (and home) pages and could only find version 1.10 for download. Since it's the home page of MPUI, I think that you should either upload the latest versions to sourceforge or link from the homepage to the latest available download, or state that the homepage is no longer updated and there's another homepage.
Also, It would be great if the latest version is also always available as plain zip without mplayer in the package (on top of the standard full installer). This way savvy users can check the latest version with a very small download and without any installation.
Keep the the good work mate
avih
avih is offline
Old 1st August 2006, 19:30   #60  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by avih
@LoRd_MuldeR:
avih
You can download all versions of MPUI at it's SF homepage. Both, the binary and the sources, are in ZIP files.
So if you don't want to use my package, download MPUI form it's original homepage.
http://sourceforge.net/project/showf...roup_id=155302
mplayer, mpui, smplayer, windows
