Old 4th July 2018, 17:27   #6241  |  Link
LigH
LigH's Avatar
If you read the last pages of the FFMS2 and L-SMASH Source threads, you will see it's not just you.
New German Gleitz board
Old 4th July 2018, 18:04   #6242  |  Link
leon
Yeah, thanks.
FFMS2 is getting the job done right now for me, but it occasionally can't decode the very last frame.
leon is offline   Reply With Quote
Old 4th July 2018, 18:59   #6243  |  Link
imsrk48
imsrk48's Avatar
How can i select multi tracks in avs script creator method for Encoding multi audio mkv
Sent from my P4 using Tapatalk
imsrk48 is offline   Reply With Quote
Old 4th July 2018, 19:08   #6244  |  Link
imsrk48
imsrk48's Avatar
how to hardcode a .ass subtitle into mkv container using avs script creator any solution or this?
Old 4th July 2018, 19:43   #6245  |  Link
kuchikirukia
@kuchikirukia
Please add the log file.
Seems a MediaInfo-AviSynth conflict.
[Warning] Log for job392 (audio, 00003-002.mkv -> 00003-002.m4a)
-[Information] [7/4/2018 2:37:18 PM] Started handling job
-[Information] [7/4/2018 2:37:18 PM] Preprocessing
-[Warning] [7/4/2018 2:37:18 PM] MediaInfo
--[Information] [7/4/2018 2:37:18 PM] File: F:\Video\BDMV\STREAM\00003-002.mkv
--[Information] General
---[Information] Format: Matroska
---[Information] FormatString: Matroska
---[Information] FileSize: 6267504073
---[Information] PlayTime: 00:21:57.324
---[Information] Attachments: Benguiat_Bk_BT_Bold.ttf / Benguiat_Bk_BT_Bold_Italic.ttf / AGCrownStyle.ttf / Benguiat.ttf / Europe.ttf
--[Information] Video
---[Information] ID: 1
---[Information] StreamOrder: 0
---[Information] Width: 1920
---[Information] Height: 1080
---[Information] FrameCount: 31584
---[Information] FrameRate: 23.976
---[Information] FrameRateOriginal:
---[Information] FrameRateMode: CFR
---[Information] ScanType: Progressive
---[Information] Codec: V_MPEG4/ISO/AVC
---[Information] CodecString: AVC
---[Information] Bits Depth: 8
---[Information] Format: AVC
---[Information] AspectRatio: 1.778
---[Information] AspectRatioString: 16:9
---[Information] Delay: 0
---[Information] Title:
---[Information] Language:
---[Information] LanguageString:
---[Information] Default: Yes
---[Information] DefaultString: Yes
---[Information] Forced: No
---[Information] ForcedString: No
--[Information] Audio
---[Information] ID: 2
---[Information] StreamOrder: 1
---[Information] Format: DTS
---[Information] FormatProfile: MA / Core
---[Information] FormatSettingsSBR:
---[Information] FormatSettingsPS:
---[Information] Muxing Mode:
---[Information] SamplingRate: 48000
---[Information] SamplingRateString: 48.0 kHz
---[Information] Channels: 6
---[Information] ChannelsString: 6 channels
---[Information] ChannelPositionsString2: 3/2/0.1
---[Information] BitRateMode: VBR / CBR
---[Information] Delay: 1
---[Information] Language: ja
---[Information] LanguageString: Japanese
---[Information] ID: 3
---[Information] StreamOrder: 2
---[Information] Format: AAC
---[Information] FormatProfile: LC
---[Information] FormatSettingsSBR: No (Explicit)
---[Information] Channels: 2
---[Information] ChannelsString: 2 channels
---[Information] ChannelPositionsString2: 2/0/0
---[Information] Title: Track 1 English 2.0
---[Information] Language: en
---[Information] LanguageString: English
---[Information] Default: No
---[Information] DefaultString: No
--[Information] Text
---[Information] ID: 4
---[Information] StreamOrder: 3
---[Information] Codec: S_TEXT/ASS
---[Information] CodecString: ASS
---[Information] Title: Subtitle Track 2 English
--[Warning] Text
---[Information] ID: 5
---[Information] StreamOrder: 4
---[Information] Title: Subtitle Track 1 Signs And Songs
---[Information] Language: zxx
---[Information] LanguageString: zxx
---[Warning] [7/4/2018 2:37:19 PM] The language information "zxx/zxx" is unknown. The default MeGUI language has been selected instead.
--[Information] Chapters
---[Information] 00:00:00.000: :Chapter 02 Part 1
---[Information] 00:09:16.556: :Chapter 03 Part 2
---[Information] 00:20:11.210: :Chapter 04 End Theme
---[Information] 00:21:26.285: :Chapter 05 Next Episode Preview
-[Information] [7/4/2018 2:37:19 PM] Trying to open the file with LWLibavAudioSource()
-[Information] [7/4/2018 2:38:01 PM] Successfully opened the file with LWLibavAudioSource()
-[Warning] [7/4/2018 2:38:02 PM] Channel count mismatch! The input file is reporting 6 channels and the AviSynth script is reporting 2 channels
-[Information] [7/4/2018 2:38:03 PM] AviSynth script
--[NoImage] ClearAutoloadDirs()
--[NoImage] AddAutoloadDir("C:\Program Files (x86)\MeGUI\tools\avs\plugins")
--[NoImage] LoadPlugin("C:\Program Files (x86)\MeGUI\tools\lsmash\LSMASHSource.dll")
--[NoImage] LWLibavAudioSource("F:\Video\BDMV\STREAM\00003-002.mkv")
--[NoImage] # detected channels: 6
--[NoImage] # detected channel positions: 3/2/0.1
--[NoImage] return last
-[Information] [7/4/2018 2:38:03 PM] Command line used: --ignorelength --threading -v 1280 --no-delay - -o "{0}"
-[Information] [7/4/2018 2:38:03 PM] AviSynth script environment opened
-[Information] [7/4/2018 2:38:04 PM] Script loaded
-[Information] [7/4/2018 2:38:04 PM] Output Decoder
--[Information] [7/4/2018 2:38:04 PM] Channels: 2
--[Information] [7/4/2018 2:38:04 PM] Bits per sample: 32
--[Information] [7/4/2018 2:38:04 PM] Sample rate: 48000
-[Information] [7/4/2018 2:38:04 PM] Job command line: C:\Program Files (x86)\MeGUI\tools\qaac\qaac.exe --ignorelength --threading -v 1280 --no-delay - -o "F:\Video\BDMV\STREAM\00003-002.m4a"
-[Information] [7/4/2018 2:38:04 PM] Process started
-[Information] [7/4/2018 2:38:04 PM] Standard output stream
-[Information] [7/4/2018 2:38:04 PM] Standard error stream
--[Information] [7/4/2018 2:38:04 PM] qaac 2.67, CoreAudioToolbox 7.10.9.0
--[Information] [7/4/2018 2:38:04 PM] 00003-002.m4a
--[Information] [7/4/2018 2:38:04 PM] AAC-LC Encoder, CVBR 320kbps, Quality 96
--[Information] [7/4/2018 2:38:28 PM] 63210496/-1 samples processed in 0:23.515
--[Information] [7/4/2018 2:38:28 PM] Overall bitrate: 329.164kbps
--[Information] [7/4/2018 2:38:28 PM] Optimizing...29%
--[Information] [7/4/2018 2:38:28 PM] Optimizing...56%
--[Information] [7/4/2018 2:38:28 PM] Optimizing...98%
--[Information] [7/4/2018 2:38:28 PM] Optimizing...done
-[Information] [7/4/2018 2:38:28 PM] MediaInfo
--[Information] [7/4/2018 2:38:28 PM] File: F:\Video\BDMV\STREAM\00003-002.m4a
---[Information] Format: MPEG-4
---[Information] FormatString: MPEG-4
---[Information] FileSize: 54443454
---[Information] PlayTime: 00:21:56.885
---[Information] [7/4/2018 2:38:28 PM] The language information is not available for this track. The default MeGUI language has been selected.
-[Information] [7/4/2018 2:38:28 PM] Postprocessing
--[Information] [7/4/2018 2:38:28 PM] Deleting intermediate files
---[Information] [7/4/2018 2:38:28 PM] Successfully deleted F:\Video\BDMV\STREAM\00003-002.mkv.lwi
-[Information] [7/4/2018 2:38:28 PM] Job completed
Encoding from an avisynth script with just the LWLibavAudioSource line comes back with no errors but it's still 2 channels, and shows detected 2 channels in the log's avisynth script instead of 6 like before.
Adding stream_index=1 encodes the DTS-MA track.
So it indicates a problem with LSMASH's default -1 for stream_index (pick the first audio track), no?
kuchikirukia is offline   Reply With Quote
Old 4th July 2018, 20:22   #6246  |  Link
LigH
LigH's Avatar
Again, and again, and again:
You "hardcode" subtitles into the contained video stream, using the AVS Script Creator. Not into a container. If you see the subtitles in the preview window of MeGUI, they will also be contained in your newly encoded video. Even if you first create a raw video stream without any container; it doesn't matter.
ASS is a text script just like SRT. And the AVS Script Creator provides several different text subtitle filters, some of them supporting ASS better than others. Test it using the preview window of MeGUI before encoding.
Old 4th July 2018, 21:06   #6247  |  Link
tebasuna51
tebasuna51's Avatar
@kuchikirukia
To avoid a mistake between tracks the 00003-002.m4a is english or japanese?
If it is japanese seems there are a confl¡ct between MediaInfo-AviSynth.
The BDMV\STREAM\00003-002.mkv is a mix of m2ts?
In BD's is possible have a m2ts intro 5.1 and after m2ts only 2.0.
maybe the DTS-MA is
Old 5th July 2018, 01:56   #6248  |  Link
hello_hello
Use the File Indexer under the Tools menu to extract the audio (or create scripts if it can't be extracted) and they'll be loaded into the audio section.
Old 5th July 2018, 09:59   #6249  |  Link
Gser
I swear all of his posts have been like this. It's like he doesn't even bother finding out anything about video encoding himself, comes here to be given out everything on a silver platter and then throws the platter out the window.
Gser is offline   Reply With Quote
Old 5th July 2018, 12:19   #6250  |  Link
Zetti
Is it possible but I don't know if it is useful.
I'm not sure if a DTS 1536 Kb/s make by ffdcaenc is better than an AC3 640 Kb/s make by ffmpeg, more compatible and 42% of size.
BTW you can use BeHappy to use ffdcaenc with AviSynth support.
EDIT: seems there are also some incompatibility with hardware players
https://forum.doom9.org/showthread.p...23#post1845723
I will try it.
Zetti is offline   Reply With Quote
Old 5th July 2018, 12:21   #6251  |  Link
kuchikirukia
@kuchikirukia
English. It's choosing the English 2.0 track instead of the first Japanese 5.1 DTS-MA track.
maybe the DTS-MA is
The mkv is a mux of the 5.1 DTS-MA from the JP BD with the English of the US BD. The DTS-MA is the 2nd track of the JP BD, since that m2ts also includes a 2.0 Japanese LPCM track. I cut that out since it's redundant.
The DTS-MA is entirely 5.1.
Old 5th July 2018, 22:04   #6252  |  Link
tebasuna51
tebasuna51's Avatar
Then
don't work as expected selecting the first audio track showed by MediaInfo.
You can try this avs, changing the stream_index parameter until select the japanese track:
ClearAutoloadDirs()
LWLibavAudioSource("F:\Video\BDMV\STREAM\00003-002.mkv", stream_index=1)
Old 5th July 2018, 23:11   #6253  |  Link
kuchikirukia
Then
Yes, I said that above:
Old 6th July 2018, 04:35   #6254  |  Link
imsrk48
imsrk48's Avatar
okay I'll try and if not work then???
Old 6th July 2018, 04:36   #6255  |  Link
imsrk48
imsrk48's Avatar
Sorry for this Sir it's not happen again
Old 6th July 2018, 04:37   #6256  |  Link
imsrk48
imsrk48's Avatar
I'll tried then I'm come here not before testing
Old 6th July 2018, 07:44   #6257  |  Link
LigH
LigH's Avatar
@imsrk48: It's all guessing and hear-say without MeGUI log files. With a log, we could possibly point you at a specific line and tell you: "Here, look, you did not include subtitles in your AviSynth script, that's why they don't appear" or such ... often it's just a simple mistake, but hard to discover if all we have is your promise that you did it all as you said.
Old 6th July 2018, 08:54   #6258  |  Link
tebasuna51
tebasuna51's Avatar
Sorry, I don't see your last post edition:
Yes, seems a problem with that.
To be sure please load 00003-002.mkv in MkvToolNix to know if the track order is the same than MediaInfo say:
- Video
- DTS-MA
- AAC
- ASS
- ASS
Old 6th July 2018, 13:31   #6259  |  Link
imsrk48
imsrk48's Avatar
okay great I'll send log file after some time
Old 7th July 2018, 11:15   #6260  |  Link
Zathor
Originally Posted by DS2902 View Post
After upgrading to 2867, it stopped running
Please check the test build and report back:
https://sourceforge.net/p/megui/bugs/924/
Zathor is offline   Reply With Quote
