1st November 2007, 21:46 | #2341 | Link |
Like said before:
What you want can be accomplished by simply enabling the resize filter, crop is not needed. Set dividing borders to 100% for top and 0% for bottom. Of course this has no effect on black borders that are added by the renderer. Those are the ones that you only see in fullscreen.
MPC-HC 2.2.1 |
1st November 2007, 23:36 | #2342 | Link |
ffdshow crashes when deinterlacing is switched on and deinterlacing method is either Kernel bob or Kernel deinterlacer. This with the newest clsid build 1589 (both generic and icl10), it works fine with the 1578 build. Happens with any video clip, tested with Zoom player and DVBviewer (digital tv broadcasts).
2nd November 2007, 10:34 | #2343 | Link | |
3rd November 2007, 18:18 | #2344 | Link |
Hi everyone, long time lurker, first time poster.
Thanks for all the hard work on ffdshow! I have noticed that since the inclusion of 7.1 audio option, AC3 encoding no longer works via spdif using digital connection. It only outputs 2 channel PCM. This is regardless of of the speaker matrix chosen. Going back to builds prior to the 7.1 audio matrix addition, AC3 encoding works fine with digital out. Analog out works fine for the 7.1 matrix. |
3rd November 2007, 18:36 | #2345 | Link | |
i |
3rd November 2007, 22:05 | #2346 | Link |
I've been trying to find some information on the "closed caption" subtitle feature. Is this supposed to be support for closed captions in DVB MPEG streams? If yes, is there any trick to enable it or is it not finished? Trying to get it to work with streams from a DVB-C card, but without any luck. Cheers. Last edited by phunqe; 3rd November 2007 at 22:09. |
4th November 2007, 12:05 | #2348 | Link |
Because ffdshow is only a decoding filter, not a source filter.
The idea of creating a DirectShow source filter based on libavformat has been brought up a couple times in the past. It would be an excellent NEW project. Its too much work to be part of ffdshow.
MPC-HC 2.2.1 |
4th November 2007, 12:29 | #2349 | Link |
Could someone compile a "test" version of ffdshow, containing the new Dolby E-AC3 and True-HD patches/decoders, from mplayer, like Kurtnoise13 did with his mplayer and ffmpeg builds? You can find the patches on his site. Thanks.
http://kurtnoise.free.fr/index.php?dir=misc/
If you need an MC on a party, I'm the man 4 you! :) |
4th November 2007, 12:57 | #2350 | Link | |
4th November 2007, 17:23 | #2352 | Link |
I could add the EAC3 decoder to libavcodec. That's easy. Actually using it is a whole different case.
The problem is making ffdshow able to recognize EAC3. It must be able to see the difference between normal AC3 audio and EAC3. It should do so based on the information given by the source filter in the graph. To be precise, ffdshow selects the decoder based on the FourCC/AudioTag. If someone can tell me which tag is used by EAC3, then maybe there is a small chance that I can make it work.
MPC-HC 2.2.1 |
6th November 2007, 08:26 | #2355 | Link |
Media Control author
I have brought a few modifications to the AC3 encoding in revision 1595 : there was an issue with some HT receivers having no sound when "Maximize SPDIF compatibility" is unchecked. So to people who had this issue : could you retest rev 1595 and untick the option (in codec section / AC3) ? Otherwise, the new 7.1 matrix works for me in 5.1 but only when I select 3/0/2 mixing |
6th November 2007, 14:26 | #2358 | Link | |
6th November 2007, 14:40 | #2359 | Link |
On Vista, if I choose Connect to: "DirectSound" and enable "Apply only to S/PDIF output", set Multichannel device: "SPDIF interface (SoundMAX Integrated Digital HD)", the player (MPC homecinema) freezes.
I don't know if this is ffdshow's problem or driver's problem. Can anybody reproduce? |
6th November 2007, 15:19 | #2360 | Link | |
Please try agin with "Maximize SPDIF compatibility" unchecked and Multichannel device set to default device |
