20th December 2007, 11:38 | #2101 | Link | |
20th December 2007, 11:43 | #2102 | Link | |
With Inside Man, if it's a 20bit track (which I don't know), the upper 20bit are filled with real data while the lower 4bit are always filled with zeroes. |
20th December 2007, 12:11 | #2104 | Link | |
20th December 2007, 12:32 | #2106 | Link |
Madshi need help with EAC3TO please!
I have noticed that when I EVODEMUX my HD DVD it tells me with the audio how many seconds its going to be in or out by. With one certain movie the time is +83ms and when I attempt to do it via the GUI of EAC3TO (yes I have all the nesscary files) it saids its not reconised and it fails.....help!? |
20th December 2007, 14:22 | #2108 | Link |
That's correct. @nautilus7, "dithering" involves adding a certain amount of random noise to an audio track. So obviously after dithering you can't compare audio tracks, anymore. You cannot even compare the audio tracks, if you do the same operation twice. Because of the random noise the result is different everytime.
20th December 2007, 14:23 | #2109 | Link | |
20th December 2007, 14:34 | #2110 | Link |
Retried extracting LPCM audio from Eagles HD-DVD
Just downloaded V2.10 of the program. Impressive!
Now I can directly feed it my EVO files. But... Still cannot extract LPCM audio from the Eagles HD-DVD. E:\codec_mpa>eac3to c:\hddvd\hvdvd_ts\concert1.evo test.flac EVO/VOB, 1 video track, 2 audio tracks, 1:26:36 1: VC-1 2: RAW/PCM, 2.0 channels, 16 bits, 48khz 3: DTS Master Audio, 5.1 channels, 24 bits, 48khz, dialnorm: -4dB Track 2 is used for destination file "test.flac". Demuxing 1st audio track... Reading RAW/PCM... Swapping endian... Encoding FLAC... Creating/writing file "test.flac"... Done. Seems good, but playing back test.flac file sounds like sound is played too slow (low pitch) and with static (digital noise). EVO plays correctly in PowerDVD... Helpfull if I supply a sample of the EVO file? |
20th December 2007, 16:16 | #2112 | Link |
DEMUXING HD DVD and using extensions ddp. for the audio. Taking DDP file and putting into EAC3TO GUI and putting output as wav. extension and then attempting to set audio delay to +83ms. Click on CONVERT and then it fails with the line *83 not reconised (cannot remember exactly as not at computer)
20th December 2007, 16:27 | #2113 | Link | |
20th December 2007, 18:56 | #2114 | Link |
I wanted to report another issue I just ran into. I'm not sure if what I attempted is correct or not, but basically I wanted to demux the video into an mkv and the specific audio to dts from TrueHD. The process successfully created the mkv and created the WAV files, but never created the resulting DTS. Below is the full output from the process. Note that there was no crash, just what's indicated below. Unfortunately, the created WAV files were deleted. It would be nice to keep those if the process fails.
eac3tov2 FEATURE_1.EVO+FEATURE_2.EVO 2: e:\media\video\movie.mkv 4: movie.dts EVO/VOB, 1 video track, 4 audio tracks, 2:15:09 1: Joined EVO/VOB file 2: h264/AVC 3: E-AC3, 5.1 channels, 768kbit/s, 48khz, dialnorm: -27dB, -84ms 4: TrueHD, 5.1 channels, 48khz, dialnorm: -24dB, -84ms 5: E-AC3, 5.1 channels, 448kbit/s, 48khz, dialnorm: -27dB, -84ms 6: E-AC3, 5.1 channels, 448kbit/s, 48khz, dialnorm: -27dB, -84ms Demuxing 2nd audio track... Removing dialog normalization... Writing WAVs... Creating/writing file "movie.L.wav"... Creating/writing file "movie.R.wav"... Creating/writing file "movie.LFE.wav"... Creating/writing file "movie.SL.wav"... Creating/writing file "movie.C.wav"... Creating/writing file "movie.SR.wav"... Muxing video to Matroska... ------------------------------------------------------------------------------- [mlp @ 68A4D2E0]End of stream indicated [mlp @ 68A4D2E0]Substream 1 parity check failed [mlp @ 68A4D2E0]Substream 1 checksum failed [mlp @ 68A4D2E0]Substream 1 length mismatch. The libav decoder reported an error while decoding. Waiting for DirectShow decoder thread to finish. Please wait...
Chumbo Last edited by Chumbo; 20th December 2007 at 18:58. |
20th December 2007, 19:12 | #2115 | Link |
Thanks for the new update, it's good to know that ffmpeg/libav is really reliable.
What about a linux version now? XD At least, can you tell me where I can found the patch and how to apply/use it in the linux version of ffmpeg (or libav?)? |
20th December 2007, 19:20 | #2116 | Link | |
Unfortunately, I must mux, for I must use Windows Media Center When you talk of this filter... do you mean it will play the DTS core file properly separately, or play it properly muxed? And is the filter dtsac3source.ax? |
20th December 2007, 19:25 | #2117 | Link | |
DTS-HD --> mono wavs --> SurCode DTS encode --> mux AVC and DTS versus: DTS-HD --> DTS core --> mux AVC and DTS that the former would be more ideal than the latter? To get a "normal" DTS track? |
20th December 2007, 19:29 | #2118 | Link | |
No chance in hell, sorry. |
20th December 2007, 19:32 | #2119 | Link | ||
20th December 2007, 23:50 | #2120 | Link |
madshi, i'm sorry. I don't have any hd dvd with a lossless track that needs a delay.
Actually, i remember adding a delay to letters from iwo jima hd dvd when i was making a flac some weeks ago, so i tried that movie. But, unfortunately, that was due the eac3to bug that caused truehd tracks to be out of sync (no delay needed), so nothing helpful to report. But i want to ask something... I typed: Code:
eac3to feature1.evo+feature2.evo 4: output1.flac 4: output2.ac3 Do these actions actually happen twice? |
eac3to |
