3rd July 2005, 16:49 | #265 | Link |
Vacuum tube addict
RC1: immediately
RC2: immediately RC3: immediately RC4: 2 seconds RC5: 4 seconds My CPU: AXP1700+, Os: Win XP SP2
130F02041B18AB "... a gdybym był młotkowym, w fabryce z młotkiem szalał..." |
3rd July 2005, 17:15 | #266 | Link |
Life's clearer in 4K UHD
P4 2.8GHz with 512MB RAM, WinXP Pro SP2
RC1: Immediately RC2: Immediately RC3: Immediately RC4: Around 6 seconds RC5: Around 11 seconds Cheers
3rd July 2005, 18:08 | #267 | Link |
Thanks, people.
akapuma, do normal VOBs open fast? I.e., is it only elementary streams that are slow? If so, I will probably restore the original pack parsing depth and add an extra open option callsed something like "deep open" that would have the longer parse depth for the files with junk at the start. Last edited by Guest; 3rd July 2005 at 18:12. |
3rd July 2005, 19:26 | #269 | Link | |
Wewkiee
...yeah...but...why on earth would I compare apples with apples? |
3rd July 2005, 23:09 | #271 | Link |
Author of avi.NET rip.NET
'neuron2'
Can I just get some clarification on the 'WAV' naming convention used.... [AC3] VTS_01_PGC_01_1 T01 3_2ch 384Kbps DELAY -31ms.ac3 [NAME]-[TRACK]-[CHANNELS]-[BITRATE]-[DELAY] [MPA] SVCD T01 DELAY 0ms.mpa [NAME]-[TRACK]-[DELAY] [WAV] VTS_01_PGC_05_1 T01 48K 16bit 2ch.wav [NAME]-[TRACK]-[BITRATE]-[CHANNELS] I notice there's no 'DELAY' for wav, is that always like that? Is that something I need not worry about? |
4th July 2005, 08:59 | #273 | Link |
Can the WAV naming scheme work more like the other formats? Meaning, add a bitrate and move the channel info forward.
eg: VTS_01_PGC_05_1 T01 48K 16bit 2ch.wav becomes VTS_01_PGC_05_1 T01 2_0ch 384Kbps 48K 16bit.wav Could you also add a frequency value for the other formats? |
4th July 2005, 09:40 | #274 | Link |
I was just messing with the MPEG-1 support and did notice something and just wondered why this happens or if it supposed to happen.
The 'Aspect_Ratio' format is usually like this: Aspect_Ratio=4:3,525 (clip was 352x288) But just done another one and the ratio is like this: Aspect_Ratio=0.6735 (clip was 352x240) Is it supposed to be using these 2 different formats? Latest RC5 was used. |
4th July 2005, 13:38 | #275 | Link | |
4th July 2005, 13:42 | #277 | Link |
1.4.0 Rc6
Here is RC6. It addresses akapuma's issue with the long open time. It now uses normal parsing depth unless the "Deep Parse" checkbox is checked on the file list dialog. Check it only to open the problematic program streams with a lot of junk before the first pack header.
http://neuron2.net/dgmpgdec/dgmpgdec140rc6.zip |
5th July 2005, 08:56 | #279 | Link |
Registered Jedi
VirtualDub-MPEG2 1.6.8 can open the M2M video now. It will automatically do a "deep parse" up to 3 MB if necessary (for M2M), but there should be no additional cost when opening a normal MPEG or m2v. If you're interested, the relevant code is in Mpeg2.cpp, in MPEGFileParser::Verify().
May the FOURCC be with you... |
