7th February 2005, 05:35 | #21 | Link |
It'll come back when I get the bugs out. I don't like to release buggy stuff if I can avoid it.
Having said that, why do you think the quality is better with demuxed video compared to frame-served video? I can't think of any reason for that to be true. |
7th February 2005, 06:00 | #24 | Link |
all i do is demux the vid and then work on it in vdm with some filters and then i mux the audio.
p.s im always interested in new way of encoding if u have any suggestions....? and do u have msn cause i would like to talk to you in private about some deals that i could possibly offer you....? |
7th February 2005, 06:10 | #25 | Link |
There's no difference between demuxing and opening in VDubMod versus using DGDecode to serve via the D2V file. Except that VDubMod does not honor pulldown flags and so is technically an incorrect decoder. And of course DGDecode allows you to use Avisynth scripting before sending the video to VDub. You may be getting the "poor man's IVTC" effect.
Please describe the quality difference that you observe. You can PM me with any deals you have in mind. Thank you. Last edited by Guest; 7th February 2005 at 06:12. |
7th February 2005, 06:11 | #26 | Link | |
Let's all give neuron2 a Thank You! |
7th February 2005, 08:02 | #28 | Link | |
ffdshow/AviSynth wrangler
If I tried to pull that off, I could stay at the hospital instead of working there... Last edited by Leak; 7th February 2005 at 08:05. |
7th February 2005, 10:16 | #30 | Link | |
ReMember
If I run the M2T through HDTV2MPEG the resulting MPG2 file saves and demuxes fine in DGIndex 1.2.0 RC2. I'll upload a snippet of the M2T for you tomorrow. |
7th February 2005, 12:31 | #31 | Link |
I'm afraid we've to stop
Wow, D2V structure changed drastically! Quick question: previously 2,3,12,13 values meant TFF, what's the equivalent now?
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
7th February 2005, 14:57 | #32 | Link |
@alfixdvd & Backwoods
Standing by for the failing streams... @len0x Please see the D2V format document included in the zip file. If the last digit is in this set { 2, 3, 6, 7, a, b, e, f }, the tff bit is set. In the next release I'll push the frame type to the upper nibble. Then the old 0,1,2,3 will still be visible. The end marker will then be ff. Last edited by Guest; 7th February 2005 at 15:23. |
7th February 2005, 16:07 | #33 | Link | |
Reading the D2V_format text I am confused about the following statement:
7th February 2005, 16:51 | #34 | Link |
@neuron2
Thanks for the continuous and hard work! And sorry but, with RC2 I cannot open the d2v file in Gordian Knot, while it still can be done with the d2v made with RC1. The d2v file seems complete, though. Is it a bug in RC2? Regards. |
7th February 2005, 16:54 | #35 | Link | |
7th February 2005, 16:56 | #36 | Link | |
7th February 2005, 16:59 | #37 | Link |
Hi neuron2.
I will not to send you any file, because with version 1.2.O RC2 all works fine. But with versions 1.2.0.b5 to 1.2.0.RC1, I can't play any movies from avs scripts, if the movie is Bottom Field First. What's wrong ? best regards. alfixdvd Last edited by alfixdvd; 7th February 2005 at 17:01. |
7th February 2005, 17:26 | #39 | Link | |
BTW, all of the contortions you went through in making the Info screen (for re-ordering and random access) were completely finessed by letting DGIndex put flags in the D2V. When he indexes he plays through linearly and so it is much easier for him to do all that. |
7th February 2005, 17:27 | #40 | Link | |
