30th June 2010, 05:52 | #1821 | Link |
Hi neuron2.
Can I poke you with a stick about this : http://forum.doom9.org/showthread.ph...04#post1363304 I ran into this problem again while outputting trimmed ts. Same thing. If you rename the file in the save as dialog box, dgindex doesn't automatically add the extension. Saving a dgi file is fine. You can put whatever into the save as box and it will auto add the .dgi extension.
http://www.7-zip.org/ |
30th June 2010, 13:08 | #1822 | Link |
It's not so simple. Suppose you do trimmed ts and enter "myfile", while the files myfile.trp and myfile.ts both already exist. And you want to append. How do I know which one to use? Or if just myfile.ts exists how do I know whether you want to make a new file or append to that one? And suppose someone *wants* a file with no extension? (In the case of DGI it is mandatory.) Finally, my view is if you replace a filename with one lacking an extension that was your intention. So I'm disinclined to do anything about this issue. It's not so hard to type an extension.
30th June 2010, 14:16 | #1823 | Link | |
Sorry, I'm sure this has been asked before but I couldn't find the answer. |
30th June 2010, 14:18 | #1824 | Link |
starting with ver 2013, both the 32bit and 64bit versions of dgindexnv do not open mkv files on my computer. no error, just nothing happens after adding to the file list and clicking ok. if i use 2012, it works fine. i updated my nvidia drivers with no change. ive tried alot of files, so i don't think source matters.
vista x64 sp2 9600gt 257.21 |
30th June 2010, 14:19 | #1825 | Link | |
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
30th June 2010, 14:19 | #1826 | Link | |
30th June 2010, 14:22 | #1827 | Link | |
30th June 2010, 14:34 | #1828 | Link |
i just generated a new file probably not even a month ago, i guess it was right before that. the bigger question i think, is why doesn't it throw an error if i need a new license file?
edit that was it though, thank you. Last edited by quantum5uicid3; 30th June 2010 at 14:38. |
30th June 2010, 16:30 | #1829 | Link |
Hi neuron2
I use VideoReDo TVSuite V4 for cuting my .ts(h.264) HDTV files. but when I cut at a I frame the first 22 frames gets green after I use DGDecNV. tested on a 50fps and a 25fps HDTV ts file. p and b looks to be OK too start a clip at. When I use DirectShowSource the clip's looks fine, no green frames. Any idea why it's like this? |
30th June 2010, 16:59 | #1830 | Link | |
30th June 2010, 17:31 | #1831 | Link | |
hope it works. |
30th June 2010, 17:45 | #1832 | Link |
I'm just dropping in to give some feedback on the 64-bit binaries. So far so good!
I can't give direct speed comparisons because I was using an older 32-bit x264.exe (4 months old maybe) and the latest 64-bit x264.exe. With my usual AVS script (1080i -> 720p and colormatrix()) HDTV MPEG-2 to x264 conversions are a few fps faster but really it's coin toss as to if 32-bit or 64-bit is faster on my system. No matter really, either way I'm converting at 2x real time and that makes me happy! Anyway Donald, the 2015 64-bit code is rock soild on my system. I'll test 2017 this weekend. You're updating versions faster than I can capture!!!! |
30th June 2010, 19:06 | #1833 | Link | |
Please use mediafire.com |
30th June 2010, 19:42 | #1834 | Link | |
http://download907.mediafire.com/wx1...myjj/test_i.ts |
30th June 2010, 22:41 | #1839 | Link |
Thanks, it works now. We will have to regenerate the license with every program version ?
LE: I already used 4 licenses without me wanting. From 2 refreshes ( mozilla got in a not responding state ) i had 2 new licenses. Last edited by crl2007; 30th June 2010 at 22:44. |
